Question about China Risingmed 2012 Ce Digital Portable Ultrasound Scanner Machine
Portable Digital 1-channel Channel ECG EKG Machine
How to load paper
How to load paper - Fixya
www.fixya.com > Forum > EKG/ECG Machines
39 mins ago - How to load paper - EKG/ECG Machines question. ... Machines. Open Question ... Aug 30, 2012 ' Schiller Cardiovit At 2 Light Ecg Machine.
Loading paper into the MAC 1200 ecg machine - Fixya
www.fixya.com/.../t4590309-loading_paper_into_mac_1200_ecg_mach...
Apr 19, 2010 - loading paper into the MAC 1200 ecg machine how to load the paperinto the machine? ... Ge Medical Systems Ge Marquette Mac 1200 question.
Contec ECG Monitor & pulse oximeter Ekg printed sheet ...
www.hcuck.com/search/p1207318-contec_ecg.../ekg_printed_sheet
Question about Ge Medical Systems EKG/ECG Machines ... Open the . ... ...ekg-manual The paper is is backwards, there are 4 ways to load paper BUT only 1 ...
Electrocardiograph (EKG / ECG) Questions and Answers
Dec 21, 2015 | Medical
Cardiocare 2000 (Bionet) machine won't print full page!
hi, if i want to start running unit. after that always on display data error, plz turn off. why? what can i do for that? thax
Jan 22, 2013 | Life Science Bionet Cardiocare 2000 12...
Whats the size paper
50mm x 100mm
Discount Cardiology sells the ekg paper that you need
Sep 15, 2012 | Life Science Eli 50i Mortara Single...
My ECG machine is not functioning because of open signal is alert all the time when i was start up the ECG machine
hi,
You have to check the patient cable of your machine . If any one of it lead is oppen then it will indicate open signal.
ok
Aug 05, 2011 | Life Science Bionet Cardiocare 2000 12...
Do you have a poster for correct lead placement for AT-2 plus ECG? thanks!
hi,
If you need to know how to place the leads then whach the following video. All 12 channel ecg machines have the same lead placement
Jun 23, 2011 | Schiller Welch Allyn Cardiovit At 2...
What's the difference between a single channel ECG/EKG and a multiple channel?
a single channel records one leads at a time and a three channel records threeat a leads time
Jan 11, 2011 | Schiller Cardiovit At 1 Ecg Machine
Ekg machine states left leg fail, but none of the leads are reading anything. works sometimes, but does this occasionaly. Does anyone else have these complaints?
hi,
ur machines patient cable have some problem in its left leg lead ,it may be broken inside. no ecg will come if any of the lead have problem. machine sences all the leads is it proper or not , then only it will process th ecg and give printout. u have to replace the patient cable of ur machine. or try to replace the left leg lead if it is repairable one type patient cable.
ok
Jan 10, 2011 | Life Science Bionet Cardiotouch 3000 12...
Does the schiller at1 have one channel capabilities and if so, does it use smaller paper?
hi,
it has single channel capability. but will use the same paper for printout. can't use any small paper.
ok
Dec 17, 2010 | Schiller Cardiovit At 1 Ecg Machine
Just ordered a schiller at1 ekg machine, just realized it is 3 channel, does it have a 1 channel mode where just one tracing will print?
hi,
u can make it single channel one by changing its setup. it will print single trace in the same paper. when u select this option it use more paper than the three trace.
ok
Dec 06, 2010 | Schiller Cardiovit At 1 Ecg Machine
Don't know the difference between a one channel and three channel
Bionet CardioCare 2000 Interpretive EKG for around $1200 is a good user friendly model...
below is a link to shop for new & used machines
http://www.cardiacdirect.com/index.php?page=products&id=1
I hope this is helpful.
Jan 03, 2009 | Schiller Cardiovit At 1 Ecg Machine
China Risingmed 2012 Ce Digital Portable Ultrasound Scanner Machine Logo
15 people viewed this question
Top China Risingmed Office Equipment & Supplies Experts
jasbo
jasbo
Are you a China Risingmed Office Equipment and Supply Expert? Answer questions, earn points and help others
