Whirlpool Duet Washer does not spin properly - Washing Machines
  • Washing Mach... Master
  • 17,130 Answers
Possible there is friction at the spindle shaft of the agitator.
Use your hand to check for free movement, if not the assembly must be reset.
Check the drive and the capacitor to the motor.
Posted on Jan 24, 2013
  • 8 Answers
SOURCE: squeeking noise on whirlpool washer duet ghw9100lw2
If your machine is 5 years old or so you might want to check out my post at:
http://www.fixya.com/support/t1254687-duet_washer_very_loud_when_spinning
Posted on Nov 18, 2008
aborcass
  • 2651 Answers
SOURCE: Whirlpool front load washer, Clicking noise during spin cycle
i would open the door nad with your hand (glove on if preferred), feel around the intereior of drom for prhaps a nails, or hair clip that has gotten caught in one of the many holes in tub
Posted on Dec 21, 2008
  • 106 Answers
SOURCE: Whirlpool Duet stuck on spin cycle
Press 'end of cycle' for over 3 seconds. Perhaps you have to check your filter, maybe clogged.
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: Whirlpool Duet Washer 'Control Locked'
Press cancel or if that doesn't work unplug the washer from the main socket - this should clear all the settings so that you can reset the washer.
Bev K
Posted on Mar 24, 2009
SOURCE: Whirlpool Duet Washer Trouble Code F25
TOP SOLUTION
The thing is most people have never used a washing machine before, its alright. If you like calling Whirlpool they will track your phone number and in the future they know you like to buy repair parts. The front load washer for the home is a new concept especially with steam etc. use patience and common sense. no washer can really wash 15 pairs of jeans and spin 150 miles an hour several times a week in this you must see the problem . so use common sense when filling the drum and do not use the highest spin cycle unless you are washing very light items. to fix f25 (happened to me after 1 month and I purchased a floor model) the fix is easy and does not involve a circuit board even though there are many buttons that light up. A repair man would love to order you any part you want plus markup, suggest the balancing mechanism and you will have made a new friend. give it up if you know you had to push on the door , maybe take a running jump to get it to close.you cannot wash a months worth of clothes all at once 1. unplug unit 2. remove 2 to 3 screws from bottom of front panel 3. next gently check connections, some may need tightening but again be patient and use appropriate pliers but mainly use gentle pressure 4.many will discover how simple it would be to work on the washer especially if you opted for the pedestals (worth every penny) 5. notice the drain trap cleaning access white and circular and turns, with a towel underneath open and clean trap at least once a year ...before replacing panel do a test rinse and spin. you will notice that once the f25 code appears there is no resistance to turning the drum this only helps to protect certain parts, once the appropriate wire is no longer loose this resistance is no longer...test but still be patient wait while the machine goes through the motions. don't start pushing every button. drum starts turning properly then replace panel. there is taped to the panel a manual with a breakdown of all the error codes. remember this is a very expensive piece of merchandise and will do for you what dry cleaners would have done for you (yes it has a wash by hand button and the machine will not spin to remove water in clothes on this selection, it will only turn to agitate , just remove clothes, hand wring out into the drum then hang or place in a plastic bag and refrigerate for a day or so until you can hang items)** I was able to my surprise wash a 110 year old linen tablecloth using this feature (soak items that require special stain removers and rinse before putting them in this machine. this machine is fantastic BUT be patient, and do not overload and do not spin everything on the highest setting. In being patient I was able to wash a king size comforter and the slip covers of a 90" sofa (not together) the machine can do this, not every day, but choose the correct setting such as bulky or heavy duty and select appropriate settings. I know for the money one should not have to take off the front panel but remember the machine weighs 200 pounds and coming from whatever factory one can only imagine what happens to machines that are abused in transportation. The key is to be patient and use common sense, if waiting on the machine to finish or the door to unlock ( the reason for the multiple locking steps is to allow those who have decided to get into the machine the opportunity to get out) then I will use the dreaded word of multitask otherwise enjoy the experience. I know I love mine!!!
Posted on Jul 20, 2009
My whirlpool duet washer front loader wont wring out the clothese properly. We have replace the drain pump and cleared all the hoses and filters. It also doesn't seem to go in to real fast spin.
First, make sure your machine is not overloaded. Overloading will not allow the machine to spin out properly. Also, make sure its fairly level. Next, make sure that all the shocks on the drum are properly attached and in working order (after you pull off the access panel, the shocks are readily visible -- there are typically 4 of them, 2 in front, 2 in back). Their heads slip into a slot and then twisting them locks them in. Finally, I would pull of the drain line leading from the drain filter to the tub basin. Once its off, stick your hand up into the basin. All kinds of yuck tends to collect there, semi-obstructing the drain line, which permits more water to remain in the basin, which doesn't allow your machine to spin as quickly as it otherwise would.
Feb 24, 2013 | Whirlpool GHW9100L Front Load Washer
Whirlpool Duet front load washer brand new will not spin dry about every 3rd. load.
make sure you use it well by following the knobs or setting or check the knob maybe its not proper indicated or check the back hardware maybe something is not plug.
Apr 04, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Duet GHW9150P Front Load Washer: i have a code it is f06 and then washer stops spin...
Drive Motor Tachometer Error. The control is unable to properly detect motor speed and the washer will shut down.If a failure occurs during high-speed spin the door will be unlocked after 3 minuts. Check wireharness connections between the drive motor/Techometer and the motor control unit also check between the motor control unit and the central control unit. Check the drive motor, the motor control unit, and wire harness.
May 17, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Monthly Cleaning Protocol
  1. Hello. here it is: Use only the proper amount of HE (high-efficiency) detergent in your Duet. Whirlpool has stated that using too much detergent or fabric softener in the Duet can ruin a high-speed spin bearing responsible for spinning the basket. The replacement part is approximately $600. Whirlpool also claims that using too much detergent or softener can cause fungus growth.
  2. If you have mold and mildew problems with your Duet, check the filter trap. Unplug the washer and remove the three screws in the seam between the door and the bottom panel to remove the bottom panel. The Duet drain pump has a design flaw that leaves about a cup of water in the filter trap under the tub. Clean out that filter with bleach every month or two to eliminate mold problems.
  3. Put small items in a mesh bag before washing. There is a good chance they will get lodged in the Duet's filter trap, if you don't. Check the filter trap mentioned in Step 2 monthly to make sure there aren't any small items blocking the filter.
  4. Remove your detergent dispenser every month and wash with warm water and bleach to prevent mold buildup. Remove the fungus smell from your washer with Affresh washer cleaner. Always keep the washer door open when not in use.
Apr 18, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Spin cycle very slow
have you cleaned your pump filter? using correct detergent HE an proper atmount? all this will cause problems. IS YOUR DRAIN HOSE CLEAN?
May 15, 2009 | Whirlpool Duet GHW9150P Front Load Washer
WHIRLPOOL GHW9150PW4 DUET WASHER DOESN'T SPIN AFTER START
F/06 Drive Motor Tachometer Error
The control is unable to properly detect motor speed and the machine will shut down. If a failure occurs during high-speed spin, the door will be unlocked after 3 minutes.
  • Check wire harness connections between the Drive Motor/Tachometer and the Motor Control Unit (MCU), and between the MCU and the Central Control Unit (CCU)
  • Check the Drive Motor
  • Check the MCU
  • Check the Wire Harness
Mar 11, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Feb 28, 2009 | Whirlpool Duet 3.8 cu. ft. Front Load...
Whirlpool Duet not functioning during spin cycle.
In front of the machine below the door you have a panel. There are 3 torx screws holding it from under. Unscrew and pull panel down & then towars you. You will see the pump assembly right in the centre big black hoses.
You need a pair of pliers & a shop-vac if you have one, or towels & a bucket. Use the pliers to unscrew the pump filter, it is white in colour. When you unscrew this water will begin to leak out; use towels or shop-vac to mop up. Do this till all the water is mopped. Remove the drain trap completely, you will find all sorts of junk, clean out completely & refit carefully, in reverse order.
Hope u appreciate this, u can rate me........
Feb 28, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Off-Balance Duet Washer
spin basket surport is defective..put unit in spin without clothes do it bang and clang,,sound like train ,or airplane,,if so contact whirlpool your under warrranty for spin basket..onthejob
Feb 04, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Washing Machines Logo
13 people viewed this question
Top Washing Machines Experts
