Epson stylus photo px720wd tells me scanner unit open while it is closed
gwbm
  • 353 Answers
SOURCE: epson stylus dx7400
Apart from the fact this DX7400 problem is mis-filed under Epson Stylus C86, it seems probable the poster has sorted it by now!
Posted on Mar 28, 2009
SOURCE: epson stylus cx8400 cannot recognize ink cartridges
I had the same problem except it would not recognize any of the ink cartridges. I kept hitting the OK button over and over again with the same cartridges in place not removing them at all and it finally recognized them. Decided to go to maintenance on the printer to do a test, and it went right back to not recognizing the cartridges. So i pressed the OK button over and over again until it finally recognized all the cartridges again, but this time i did not try and go into the maintenance to do a test run. Plugged it up to the computer and it has been working ever since. So press the OK button until it recognizes the cartridges, and run no tests on it is what my solution was for the problem. Really is a pain but it works now.
Posted on Apr 06, 2009
SOURCE: All lights flashing on the Epson Stylus photo 870
Unfortunately, the Russian software does not work on a Mac, and it crashes at launch when installed in WZ98 under Virtual PC. However, I found this on another site, and it worked immediately:
The sequence to reset the waste ink counter is as follows:
WASTE INK ROM RESET ONLY 870, 1270
1. Turn the printer off using the power button on the panel of the printer.
2. Disconnect the interface cable at the back of the printer.
3. Hold down the "LOAD/EJECT" and "CLEANING" buttons simultaneously.
4. Turn the printer on. Release all buttons as soon as paper out light flashes.
5. Quickly press (within 3 seconds while PAPER OUT light is flashing) the "CLEANING" button for 10 seconds.
6. Release the button and the printer will initialize.
7. Once initialization is complete, turn the printer off.
8. Reconnect the interface cable.
9. Turn the printer on
Works great, no muss...no fuss!
Posted on Apr 29, 2009
websnail
  • 419 Answers
SOURCE: reset ink-pad counter on epson stylus photo 1400
The simplest way to do this is to grab a copy of the A10_IPR utility that Epson distribute to their customers...
The utility is available to North American customers if you register no this site page http://www.epson.com/ipr/
The utility is also know to be available in the wild if you search for "waste ink ipr".
Just remember to scan any download using a virus and malware scanner before you attempt to use it as some utilities contain trojans or similar nasties.
Hope that helps.
Posted on May 12, 2009
seanpwright
  • 2030 Answers
SOURCE: Epson Stylus TX100 printer Woeks but scanner not
It is a scanner as well, but you have to access the scanner through the software that came with it
Posted on Aug 27, 2009
Epson Stylus Photo PX720WD Fatal Error
Dipak, typically, Epsons offer more than "fatal error". Was there anything else showing that describes the problem?
Jun 09, 2015 | Epson Office Equipment & Supplies
Horizontal pink lines on print every inch or so.
Do the magenta lines go outside the picture into the white border? If so, the print head has gone bad, and the cost to replace a print head is more than a new printer.
May 12, 2015 | Epson Stylus Photo PX720WD A4 All-in-One...
Epson px720wd does nozzle-cleaning and -test fine, but turns off as soon as it starts printing!
Well this is not easy to diagnose without seeing it but when you say "Turns off" I presume you mean loses all power and is dead. The only difference between cleaning and printing is that the paper is drawn into the printer by the feed motor. This exerts a bigger drain on the power supply than the cleaning does. So see if the motor just starts to jerk as the power fails. If so then you will need to place the power supply unit. It could also be the control board but the psu is more likely.
Aug 11, 2017 | Epson Stylus Photo PX720WD A4 All-in-One...
Error Epson Stylus Photo PX660 - Close the Scanner Unit
maybe the scanner rail of scanner has been stuck that's why when you turn on your printer there's an error!!! or if you can try to open the scanner and clean the motor and the belt.
it might dirt or something that causing your printer to turn it on or causes-sing error.
for my opinion plss.. check the scanner we have desame cases in my printer too. I open the scanner and clean it then it works..
Apr 27, 2014 | Epson RX595 Photo All-In-One Printer
My Epson RX650 scan software will not start up. The printer works and the copy feature works. When I double click on the Epson Scan icon on my desktop it appears that it wants to start up but then...
Install another scanning software, if you have photoshop or any imaging software, you can use the scanner by going to the menu, then choose File, Import, TWAIN, Acquire and the scanner control will appear.
Or just go to My Computer and double click the scanner icon (in XP) to start the scanning assistant.
Nov 09, 2010 | Epson Stylus RX650 All-In-One Printer
Paper jam has been cleared, but paper jam message remains.
Try these steps and see if it resolves your problem. Hope it helps:
Follow these steps to clear a paper jam:
  1. Press the cp_button_45_er.gif Start button to eject the jammed paper. If that doesn't work, go to step 2.
  2. Turn off the Epson Stylus.
  3. Lift open the scanner and remove any paper inside, including any torn pieces.
  4. Close the scanner, then turn the Epson Stylus back on.
Aug 02, 2009 | Epson RX595 Photo All-In-One Printer
Remove empty print cartridge
Turn the printer on, when time is displayed press the setup button. Press the up/down arrow buttons to get to "5. replace Cartridge" and then press OK. Open the scanner unit and lift the lid off the ink carriage unit. Remove the empty cartridge and fit the new one. Make sure the cartridge and carriage cover click down into place, close scanner unit and press OK. The user guide with pictures can be downloaded fro Epson here:
http://www.epson.com/cgi-bin/Store/support/supDetail.jsp?BV_UseBVCookie=yes&infoType=Doc&oid=58607&prodoid=58654753
Please take a moment to rate this solution, thanks.
Apr 01, 2009 | Epson Stylus CX3200 All-In-One InkJet...
62 people viewed this question
k24674
jasbo
jasbo
