Question about Bryant Heating & Cooling
What ton is 561cj024-E
Need to know how many tons
  • 5 Answers
Looks like two tons to me
Posted on Jan 05, 2014
honey2509
  • 146 Answers
SOURCE: why the word ton used for airconditioner.
hi there..
this what i found for you...
The unit ton is used in refrigeration and air conditioning to measure heat absorption. Prior to the introduction of mechanical refrigeration, cooling was accomplished by delivering ice. Installing one ton of refrigeration replaced the daily delivery of one ton of ice.
  • In the United States, a standard ton of refrigeration = 12,000 BTU/h = 200 BTU/min ≈ 3,517 W. It is approximately the power required to cool 1 short ton of water by 1 °F every 10 minutes; or the power required to melt one short ton (2,000 lb) of ice at 0 °C in 24 hours.
  • A ton is also a unit of energy equal to that power for a period of a day, or 24 h × 12,000 BTU/h = 288,000 BTU ≈ 303.9 megajoules.
  • A less common usage is the power required to cool 1 long ton of water by 1 °F every 10 minutes = 13,440 BTU/h ≈ 3,939 W.
All the Best.
Was this solution helpful? Show your Appreciation by rating it:
Posted on Feb 24, 2008
burzerko
  • 254 Answers
SOURCE: HOW DO I KNOW WHAT TON MY AIR CONDITIONER 13AJA36A01 IS
This is a 3 ton unit
Hope this helps Ya.
Posted on Jul 02, 2008
  • 252 Answers
SOURCE: Need Tons on a btb736a100a2
3 ton
Posted on May 07, 2009
rockitman187
  • 2559 Answers
SOURCE: WHAT TON IS MY AC UNIT
It's a 2 1/2 ton unit
Posted on May 19, 2009
james3751
  • 614 Answers
SOURCE: Can Air Handler !1/2 ton run with 2 ton
Its done all the time. It is sometimes better to do this because you run a colder coil and rmoves more humidity. The newer unit have variable speed fan and run slower to do the same thing. Remember the lower the humidity the higher you can raise your tsta. Example In arizona at 95 degrees you dont feel the heat as much because of the lower humidity. Its ok to do so. You get more btus out of your unit that way. Rus. I have dozens of units with air handlers 1/2 ton smaller...
Posted on Jul 18, 2009
I want to know tonage of ac
12,000 but/ton. If the 101 in your model is their tonnage (101√∑12=8.4. its a 8 1/2 ton (5 ton and a 3 1/2 ton combined). That's probably it or very close. I could not look it up cause I don't know the maker of the unit.
Jun 25, 2015 | Mitsubishi Heating & Cooling
How to measure air conditioning tonnage to square feet of hom
Read size of air conditioner you need , each ton of air conditioning will keep cool 400 square.so higher ton yo pick you feel cool.please read below square feet to ton chart.
1 ton on 400 sq. ft.
2 ton on 800 sq. ft.
3 ton on 2000 sq. ft.
5 ton on 2570 sq. ft.
May 28, 2014 | Computers & Internet
Need to know how many tons this AC unit is
To find out the tonnage, I would need to see the model number. If you can go to the out door unit and write down the number or look for this in the numbers and letters. There are 12,000 btu's per ton of cooling. I don't know if you have a central unit or a window unit, but look for numbers like this. 018, is a 11/2 ton, 024 a 2 ton, 030 a 21/2 ton, 036 a 3 ton, 042 a 31/2 ton, 048, a 4 ton, they don't make a 41/2 ton, and it go's to 060 a 5 ton. This is the largest for a residential that is made. From there they make units for commercial buildings that start at 71/2 tons up to 350 ton's on 10,000' warehouses for wine storage and so on. This is larger then a train box car. You may want to write this down and keep it as most people have no idea how to tell, and now you do. Please don't forget to rate me as I know you will be kind. Let me know if you need my help for any thing.
Sincerely,
Shastalaker7
A/C, Heating Contractor
Sep 08, 2010 | Heating & Cooling
DO NOT HAVE BTU LISTED ON AIRCONDITIONER FOR SERIES LP 109755 319Y SERVICE# M6X08F2A-B
Hi, I am not sure what you are wanting to know? If you want to know the size of the a/c tonnage wise, its 5,000 b t u's short of being a 1 ton unit. There is 12,000 b t u's of cooling per each ton. 2 tons would be 24,000 b t u's, 30, a 2 1/2 ton unit and so on. If this is not what you needed to know, please get back to me and let me know. Sincerely,
Shastalaker7
Jul 03, 2010 | Maytag Chassis Built-In Air Conditioner...
Need help on tonnage question
I would have an air conditioning contractor do a heat load calculation and give you and estimate. 3 ton may work if your insulation is good and your windows seal well. 4 ton may be too much and you won't get the humidity removal needed in Florida.
Mar 04, 2010 | Heating & Cooling
Need to know unit size
ckl60 5 ton about a 2003 model on most ac heat pumps the model number reflects the ton sized by 12000 btus per ton also as for the indoor unit cfm rating 400 cfm per ton
May 14, 2009 | Goodman CKL60AR60 Air Conditioner
Heating & Cooling Logo
379 people viewed this question
Top Bryant Heating & Cooling Experts
christian nielsen
Dan Webster
Dan Webster
Bill Long
Are you a Bryant Heating and Cooling Expert? Answer questions, earn points and help others
