Question about Miele Washing Machines
Miele 6065 programme stuck on main wash
  •  Roy Tilley
    Roy Tilley Jan 24, 2013
    all functions seem to work but the machine will only revert to main wash 1
  • Miele Master
  • 17,130 Answers
It is possible that the machine does not start off the cycle because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
Posted on Jan 24, 2013
  • 16 Answers
SOURCE: Miele Washer problem Novotronic Premier
Main wash light flashing is a heating fault. You either have a faulty temp sensor (NTC) or the pressure chamber has blocked and the heater element has popped.
Posted on Feb 08, 2008
  • 249 Answers
SOURCE: Miele W487WPS Washing Machine
unplug machine, drain water manually by leaving the out let hose down gravity will let the wate out unless its blocked.Close Ire.ps. door should open .reset,and try again
Posted on Feb 25, 2008
  • 70 Answers
SOURCE: miele premier novo, the main wash light flashing
Hi
Main wash is a fault indicator. The is a problem within the heater circuit, NTC, element, relay or loose wire. You will have to open front and check.
Remove 3 screw around dispenser and 3 10mm bolt around door. disconnect hose by drain pump and front of machine will open like a door.
Posted on Apr 01, 2010
Testimonial: "thanks, you confirmed what we sort of expected"
richroth
  • 9472 Answers
SOURCE: 'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Posted on Nov 04, 2012
richroth
  • 9472 Answers
SOURCE: miele stuck main wash
Unplug the unit for 30 mins.
Posted on Nov 05, 2012
My new Miele Washing Machine (Model no WDA 110) is not taking in water. The programme timer counts down but no water comes in thru powder/conditioner. We have checked the installation carefully and
Hi, Jane.
Is the tap on? (Sorry, I had to ask)
Make sure the filters on the inlet valve(s) aren't blocked.
If all is well with the inlet valves you should hear a faint humming. This is normal.
If it's a new machine it would still be under warranty, so you should get a Miele serviceman to check out the problem.
Good Luck
Cheers
Nomess
Jan 05, 2015 | Miele Washing Machines
Miele washing machine 6065 stuck on main wash programme , unable to clear or reset . any ideas ?
Switch off machine for some time maybe overnight. Press and hold on panel buttons to drain off voltage. when powered hold on start/stop/pause button. If the program does not reset it be fault in the memory or the processor.
Jan 23, 2013 | Washing Machines
Miele stuck main wash
Nov 05, 2012 | Miele Washing Machines
Only Upper basket and cutlery basket wash
got a bargain here ,a miele ?? the rolls royce of machines ,cant say i have repaired one of these myself but if no water from bottom spinner then i am sure it could be the programmer like you suspect and a solonoid operated valve ,most likely fault is the programmer so by pass the valve and just use the ,main wash and never mind about the top only cycle .If it is the programmer then no doubt it would cost more than a new cheap machine so the previous owner sold it ,like a second hand car if it plays up put it in auction
Mar 04, 2010 | Miele 24 in. G892SCU Plus Built-in...
The motor on my Miele washing machine is running constantly even when not set on a programme. The water seems to empty out as soon as it comes in. I Have to release the Stop /Start button to stop motor.
what motor do you mean the motor that spins the drum or the pump motor if its the pump motor i would check the programmer as it tells the pump when to run, on a rinse water evacuate cycle it would seem that you are stuck in that mode call a loacl engineer
Jan 16, 2010 | Miele Novotronic Premier 500 Front Load...
Miele Dishwasher door release problem
I switched the dishwasher off at the mains and then back on again. At this point the plastic arm started making a noise like it was trying to retract so I pulled the door to help it along. The door opened and the arm fully retracted - much to my relief.
Mar 15, 2008 | Miele Dishwashers
Feb 24, 2008 | Washing Machines
Oct 22, 2006 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
71 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
