Question about Pride Jazzy 1113 ATS Indoor Power Wheelchair
My husband wheel chair is lockedup . He backed out of the bathroom and it locked up, won't movie at all
Power wheelchair won't turn right, back tire squeals
Have you completely disengaged the wheel locks? Check for worn wheel bearings.
Apr 19, 2013 | Invacare Health & Beauty
Shoprider power chair won't move and 8 Battery LED Lights are flashing
Code 8: Controller problem. Also, check to see if your gearbox levers are engaged - if you can roll the chair by hand the gearbox is not engaging the motors.
Mar 20, 2013 | Pride Mobility Products New Pride Mobility...
Won't drive in a straight line
Make sure that the caster wheels are turning freely. Clean and lube if necessary
Mar 10, 2013 | Golden Technologies Alante 2 Heavy Duty...
Batteries for Renegade power wheel chair won't charge
if the batteries are OLD they are quite possibly totally dead and need replaced
Apr 10, 2017 | Health & Beauty
HOW DO I FIX MY OFFICE BOSS CHAIR IT LEANS BACKWARDS AND WON'T STAY STRAIGHT
without sounding like a smart ***, have you checked the adjustors under the seat. Some handles are 3way handles and can do multiple adjustments. If you have adjusted all the knobs and handles, maybe it is leaking gas or in some case oil. Some of these chairs have an extra knob at the back of the seat along the column of the back rest, as to lock it in the desired position. Good luck.
Jun 01, 2012 | Furniture
Jet 3 ultra power chair won't move
Move the freewheel levers back and forth so the chair does not move drive position
May 25, 2012 | Jet 3 Ultra Power Chair
One wheel on my Pride Jet 3 won't go.
Have you ever solved the problem? My Jet 3 does the same thing and i would like to know whats causing it.
Thanks
Rangr90
Jan 08, 2012 | Pride Used Mobility Jet 3 Power Wheel...
The Battery does not seem to charge so I want to remove it and see if it will charge if connected to an external charger. How do I remove the said batteries?
Remove the batteries .. Every Chair is different .. but if the batteries aren't charging it's probably that they were left uncharged for a time and they dropped down enough that the charger dosn't recognize them .. If they drop down below around 6 volts the charger won't charge them ... I have taken batteries out and charged them individualy with a car charger .. but they never come back .. at best half life.
Aug 31, 2011 | Pride Mobility Products New Pride Mobility...
I have a Pride 1143 Jazzy Electric wheel chair and the controller is constantly flashing. This happened after I drove into my van and locked into the e-zloc. My husband sid I drove in too fast and caused...
Hi
Rapid flash of lights indicates a fault in the VSI or the electrical system. You need to refer to " VSI Error Codes" on page#32 of this User Manual:
Pride 1143 Jazzy Electric wheel chair User Manual
Please do accept the solution if the issue is resolved or else revert for further assistance.
Thanks
Rylee
Jul 25, 2009 | Select Jazzy Used Electric Wheelchair
Pride Jazzy 1113 ATS Indoor Power Wheelchair Logo
37 people viewed this question
Top Pride Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Colin Taylor
Are you a Pride Health and Beauty Expert? Answer questions, earn points and help others
