Question about Philips 36PT842H 36" TV
Blurry picture i have a Philips 36pt842h37d and the picture is blurry. dont no what to do or where to start. thank you!
  • Philips Master
  • 5,568 Answers
If this isn't due to a decaying capacitor, you may be able to correct the focus. PLEASE NOTE! Once the rear housing is removed, there are many points where dangerous voltages exist!  Please use caution and behave like there is a live rattlesnake hiding in the unit.
The rear housing on most is secured by only a few screws; four at the corners and perhaps two located around the cutout for the connectors. Don't remove any connectors by accident, they are normally mounted on a panel.
Once the housing is removed, you will need at least a very well insulated flat blade or #1 Phillips screwdriver - specially insulated tools for this kind of work can be had but if caution is used, normal ones will work.
You may have to remove the AC cord from the rear housing to use it to power up the set if it is attached.
Locate a largeish object that has a thick cable coming from its top and connected to the picture tube that will have a rubber cover over the connecting point on the tube. This device is the 'flyback' or horizontal output transformer. It will have two, sometimes three protruding adjustments. I recommend having a mirror positioned in front of the set so you can see instantly what is happening when you adjust it. Keep kids well away from the set, better yet, out of the room completely; they can distract and even get hurt if they move quickly.
One of the adjustments will affect the brightness - adjust any of these very slowly, you can damage the picture tube (CRT) if the brightness is turned too high and if misset, will create slanted white stripes across the screen if set too high. Another of these adjustments will affect the focus; this is the one you want to adjust. If there is a third one, it may affect focus on a part of the screen but not all of it.
If you get the brightness first (this adjusts the actual *very high* voltage that is connected via the thick cable), put it back where it was and try another.
You should be able to improve the sharpness of your video to its optimum again if the problem is not related (as previously stated) to a failing part. If you cannot improve the focus, then it is time to turn it over to a tech to troubleshoot.
Posted on Jan 28, 2009
Picture shows blurry
You will have to determine which of the picture tubes has contaminated fluid. To do this, you have to pull the screen off and see which tube is blurry. You will find a red, green and blue tubes when the set is on. To learn how to remove and replace the fluid, please check the following web site. www.TVRepairKits.com. Be sure you have the model number and know the symptoms you describe to repair this. Thanks for asking and show all hands of support!
Mar 29, 2011 | Philips Magnavox 9P6034C 60" Rear...
My screen is discolored and blurry. Please advise..
Sounds like contaminated fluid. Each of the 3 crt's in your set have coolant to keep them cool. This coolant over time gets contaminated and causes extreme blurry picture. ITs extremely common on the Magnavoxs. Its also a pretty big job. Replacing the fluid isnt too difficult but because the tubes have to be removed it means both physical alignment and electronic alignment will be necessary. Also dont remove the green tube until you have done both the blue and red and aligned them to the green. Then do the green.. I hated doing that job lol.. I dont recommend you trying it and probably wouldnt be cost effective to pay a shop to do it either.. I recommend buying a new set... Sorry
Oct 19, 2010 | Philips Magnavox 9P6034C 60" Rear...
Philips blurry 34pw8502/37 Blurry Screen
a part called picture tube base which connects picture tube to circuit board got some trouble,,, u can replace it with the help of a service pro..
Mar 23, 2010 | Philips 34PW8502 34" TV
Blurry picture
Make sure the lens is clean
Some webcams have a focus ring around the lens you can rotate to sharpen the image - like a telescope.
Others rely on software and you set the focal length for the best picture.
You can try the Philips website for support
http://www.support.philips.com/support/sms_page.jsp?userLanguage=en&userCountry=gb
Jan 19, 2010 | Philips SPC 600NC Webcam
Tv picture blurry, not clear
The LXI or Sears brand used philips TV's. These sets are known for bad coolant fluid. In between the picture tube and their lenses is a layer of clear coolant. Over time the coolant breaks down and causes the picture to become blurry. This can be a complicated repair involving removal of the picture tubes and lenses. Have a repair shop check it for you. Thanks for using fixya.
Dec 12, 2009 | Televison & Video
My picture is like a 3d look. I can't adjust the
Hi and welcome to fixya, it is the colour wheel problem,,,,,,,,,this is common problem please check it ... thank u.........
Jun 03, 2009 | Philips Televison & Video
Blurry screen
coolant fluid on picture tube may be contaminated replace it an setbe ok (this is a technician job)
Mar 19, 2008 | Philips Magnavox 9P6034C 60" Rear...
Blurry
Right off hand I'd check the focus . By turning the camera lens left or right may cure the problem. Sound likely to be the focus. Hope this is of some help. Bud
Feb 22, 2008 | Philips SPC700NC Webcam
Picture get blurry on right hand side
if the convergence is also off suspect convergence ic problem
Nov 27, 2007 | Philips 43PP9202 43" Rear Projection...
Tv out of Focus
Well you did start out good, thats cool, now we have to define focus, Is ir blurry around the edges as well as the whole Picture? If it is, it could be the picture tube, A bad solder connection on the tube socket, and yes it could also be the flyback transformer.
Oct 06, 2006 | Philips 27PT8420 27" TV
Philips 36PT842H 36" TV Logo
100 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
