Question about Kenmore Refrigerators
Model number 6172 Kenmore refrigerator
Just newly purchased and makes loud humming noise.
hotuna
  • 288 Answers
SOURCE: Kenmore Refrigerator making loud noise
Does the sound occur when the compressor is starting or shutting down? and only lasts for a couple of seconds? I had one do the exact same thing. Sometimes it would also wake me up at night. If so, I'm afraid he is right. On the bright side, it worked fine for years. I gave it to a girlfriend when I purchased a bigger one and it is still working today. The only thing you can do is change the compressor, which is probably not $$ practical.
Posted on Nov 05, 2007
SOURCE: Frigidaire side-by-side model # FRS26H5ASB4 making humming or buzzing noise
I had the same problem. I found the buzzing noise was caused by ice build up around the fan motor inside the freezer. I believe water must have leaked down around the fan during a defrost cycle. I removed the ice maker, the ice cube bin and ice dispenser auger motor. It sounds complicated, but it isn't too bad. The ice maker and auger are connected with quick connect plugs. So just unplug, remove the screws and remove them from the freezer. You will need to remove several other screws as well, I believe 11 in total as well as the top freezer rack. This will give you access to the white aluminum panel that runs from the top of the freezer to about halfway down the back of the freezer. After you remove the aluminum panel you will see the fan about half way down the freezer. I found a lot of ice around my fan. The fan blades were hitting the ice causing the buzz. Remove the ice and the buzzing is gone. It took me an hour to complete this repair. I hope this helps.
Posted on Feb 05, 2009
  • 172 Answers
SOURCE: Sears Bottom Freezer Refrigerator - Loud humming noise
That sound is usually your icemaker calling for water. you can turn off your icemaker by lifting the little arm on the icemaker. As the icemaker calls for water the valve will be activated and will hum. This sound is usually not very loud. If your valve is making that much noise you may consider replacing the valve. The part number for you water inlet valve is #2315533 The retail price is $60.18 . I do have these on hand and available to ship out today if you need one. Please just let me know. You may also consider replacing your filter if your refrigerator has one. Thanks and I hope this will fixYa
Michael Anderson
Anderson Appliance
(865)945-3808
Posted on Feb 17, 2009
  • 400 Answers
SOURCE: Maytag Performa Bottom Freezer refrigerator making weird noises
This can be due to low supply voltage, causing the compressor thermal overload to trip out. Therefore when this happens the compressor gets hot and it keeps trying to start but fails. It can also be a faulty starter relay, which is located in the conncetion box of the compressor and is very simple to replace.
Posted on Mar 20, 2009
SOURCE: Kenmore Elite Refrigerator 59676264700 loud clicking noises
check for bad relay
Posted on Jul 29, 2009
Kenmore bottom freezer fridge making loud noise not cooling
What is the complete model number of your unit?
Where is the sound coming from?
Dec 04, 2012 | Kenmore 73502 / 73504 / 73509 Bottom...
Kenmore/Elite Model 795.7756,7757 Trio: Bottom Freezer Door won't close. The latch or hook at the bottom corner of each side will not hook in.
We have a kenmore elite refrigerator modle number- 795 7756,7757 and it has been making a humming noise very constant now after two weeks, what could it be?
Sep 18, 2010 | Kenmore 77554 / 77543 Bottom Freezer...
Not heating and making a loud humming noise.
you have done well out of the oven . it sounds that certain components are well worn and probably no able to get parts best advice it time to buy a new one
Dec 21, 2017 | Kenmore Microwave Ovens
My Kenmore side-by-side refridgerator is making a loud humming noise.
Has anything changed in the cooling? Can you locate the model number on your refrigerator.The noise is coming from under or inside the refrigerator or freezer? Let me know those few things and we will find out whats going on, Thank, Sea Breeze
http://servicepartstec.blogspot.com/
May 17, 2009 | Kenmore 57029 Side by Side Refrigerator
Will not pump Kenmore model 970-c45072-00, purchased in 2005
Pump blocked probably something stopping it, sock, coin etc
Mar 13, 2009 | Kenmore 43142 Front Load Washer
Michael Anderson
Anderson Appliance
(865)945-3808
Feb 17, 2009 | KitchenAid Superba Architect KSCS25INSS...
Kenmore side byside refrigerator
Maybe you have some sort of a blockage in the pipes or the water cooler has an electronic fault and mabye needs replacing. Ask an expert such as a plumber. I'm glad i could help. Good luck!
Sep 11, 2007 | Kenmore 57029 Side by Side Refrigerator
Kenmore side by side refrigerator
Check the water valve in back of refrig.. u have a double valve... one side for water the other side for your ice maker.. make sure ice maker valve is working.
Refrigerators Logo
32 people viewed this question
Top Kenmore Refrigerators Experts
Sal De
Jim Goldsmith
Jim Goldsmith
oldblindman
Level 1 Expert
Are you a Kenmore Refrigerator Expert? Answer questions, earn points and help others
