Question about HP LaserJet 3050 All-In-One Laser Printer Copier 4-in-1
Hp laserjet 3050 scaner solution for windows 8
    Sergeant:
  • 241 Answers
You can get 32-bit and 64-bit drivers and software from here.
Hope this helps.
Posted on Jan 23, 2013
Nikhil Gedam
  • 87 Answers
SOURCE: low memory display on HP Laser Jet 3050
Hello All,
Please perform the following:
Super NVRAM init
When a super NVRAM init is performed, the all-in-one language and telecom country/region settings
are undefined. The user is prompted to set the language and telecom country/region. Until these settings
are defined, the all-in-one will not return to the Ready state.
CAUTION A Super NVRAM init erases all data that is stored in both the unprotected and
protected NVRAM memory.
To perform a super NVRAM init
1.
Turn off the all-in-one.
2. Press and hold down the * and 5 buttons.
3. Continue to hold down the buttons while you turn on the all-in-one. Hold the buttons throughout
the entire power-on sequence.
4. When Permanent Storage Init. appears on the control-panel display, release the buttons.
5. When prompted, set the language and telecom country/region.
6. Allow the all-in-one to return to Ready before using it.
Posted on Nov 03, 2008
SOURCE: HP LASERJET 3050 SCANNER: ERROR (not set up on pc).
Shirley,
If your still looking for a solution, or to those of you who have a similar problem, the following fixed my problem after trying to resolve the issue over the last year!!!!
I also received the "not set up on pc" message and tried re-installing the software numerous times.
Finally resorted to re-installing windows XP (because of this and other software glitches) and re-installed the Laserjet 3050 software again...but could not get the printer to install.
The problem was occuring while the software was asking to "plug in the usb cable", but would not complete the installation. It was not recognizing the device....the solution was to reset the laserjet 3050!!!!
to reset, push the "menu" button, < (left arrow), go to "service", "enter" button, > (right arrow), "Restore Defaults", "enter" button.
This should reset the factory defaults.
After this, I re-installed software, working!!!!!
Puas
Posted on Mar 11, 2008
SOURCE: hp laserjet 3050 - black line down the center of
If the lines only appear on copies from the auto feeder and printing is clean, then lift the auto feeder section and clean the scanner glass underneath.
If printing and copying have similar 'streaky' results you probably have a bad toner cartridge - try a replacement. If that doesn't work you have a fuser problem - which is quite a costly repair based on the replacement cost of your unit
Posted on Mar 04, 2009
Dadofmykids
  • 25 Answers
SOURCE: how 2 configure fax on HP laserjet 3050
If this doesn't answer your question, then let me know more specifically what you need.
Setting the time and date
To set the time and date
To set or change the time and date, use the following steps. If you need help entering any
information, see Enter text from the control panel.
1. On the control panel, press Menu.
2. Use the < or the > button to select System setup, and then press .
3. Press Menu to select Time/Date.
4. Use the < or the > button to specify either the 12-hour or the 24-hour clock, and then press .
5. Use the alphanumeric buttons to enter the current time.
6. If you specified the 12-hour clock, use the < or the > button to move the cursor past the fourth
character. Select 1 for A.M. or 2 for P.M., and then press .
-or-
If you specified the 24-hour clock, press .
7.
NOTE Make sure that you use two digits to specify the month and day, in that order (for
example, use “05” for May and “01” for the first day of the month of May).
8. Press Menu.
Setting the fax header
To set the fax header
To set or change the fax header information, complete the following steps. If you need help entering
any information, see Enter text from the control panel.
2. Use the < or the > button to select Fax setup, and then press .
3. Use the < or the > button to select Fax Header, and then press .
4. Use the alphanumeric buttons to enter your fax number, and then press .
5. Use the alphanumeric buttons to enter your company name, and then press .
NOTE The maximum number of characters allowed in the fax number is 20. The maximum
number of characters allowed in the company name is 40.
Posted on Apr 07, 2009
FixinFax
  • 3085 Answers
SOURCE: HP Laserjet 3050 All in one printer - Unable to receive faxes?
Vonage is dgital. fax machines are analog
Posted on Jun 26, 2009
HP Laserjet M2727nf Mfp Printer Scanner Error 8
The HP M2727 has a known issue with the scanner error 8 and bad formatters. HP has extended the warranties on this product. I suggest you contact them directly and they will most likely exchange the unit.
Nov 08, 2011 | HP Laserjet M2727nf Multifunction Printer
HP LASETJET 3050 ALL IN ONE IS COPY THE PAGE IS LINES HOW TO RECTIFY
Try to print something out ( like report or similar ) and if the print is fine that means that you have some dirt on scaner, clean scaner verry well with moisturized cloth and dry it after.
If the lines are also on print that means that you have to replace drum ( toner crg. ). To be sure that is the drum problem, remove it from the macine and on green long roller ( drum ) look for lines. If there are lines, change it.
Use genuine crg. - allways
Jul 17, 2010 | HP LaserJet 3050 All-In-One Printer
Error 52 scaner
unfortunately, you have a bad SCANNER BLOCK, it would cost more to replace it than a new fax machine. Sorry
Oct 30, 2009 | HP LaserJet 3050 All-In-One Printer
Multifuction hp laserjet 3050 conflict with hp laserjet M1522N
After installing the printer software you need to program scanning software.
Below are the steps to program scanning software:
To program the Scan To button:
Select Start/Programs or All Programs (Windows XP)/HP/HP Laserjet 3050, 3052, 3055, 3390, 3392/Scan
Click the Setup to open the Scan To Setup Wizard.
Select the Change the destinations that show up on the all-in-one control panel when I press the <Scan To> button and then click Next .
Check the Allow me to scan by pressing the Scan To button on the all-in-one check box.
Choose the destination by moving them from the PC window (the left window) to the All-in-one window (the right window).
NOTE: The All-in-one window might contain items set up by other computers that are connected to the all-in-one. You cannot make changes to these items.
Click Update .
To Create a destinations:
Follow steps 1-2 from the above steps.
Select Create a new destination with settings that I will specify and then select Next .
Select the Save it to my computer and then press Next .
Select the scan preferences and then select Next .
Select the scan destination folder and file format type and then select Next .
NOTE: If you wish to use a custom folder for your scan destination, you will need to create the folder prior to this setup wizard in order to browse to it.
Select the quality level you would like the file to be saved as.
Name the new destination on the computer, check the Send this new destination to the all-in-one check box, and enter a name for the display on the all-in-one. Then select Next .
Confirmation allows you to verify your settings. Select Save .
Once the new destination has been saved, the new destination will be configured as one of the Scan To destinations on the printer.
May 15, 2009 | HP LaserJet 3050 All-In-One Printer
how do I change the language? everything is in German.
Nov 11, 2008 | HP LaserJet 3050 All-In-One Printer
52 scanner error turn off and on is displayed in the contoll panel,the same thing is again displayed if i turned off and on also nothing can be printed due to this displey. please help
The printer has burned a scanner assembly. The part number is RM1-2033-030CN. The part is extremely expensive in relation to the printer cost. ($182.00 @ HP)
I would recommend surfing ebay for an HP Laserjet 1022 printer as it is the cheapest printer that has the same scanner. Even a dead 1022 will work as they tend to either have formatter or fuser issues when dead. A scanner error on your printer or the 1022 is extremely rare.
I have included a link to the HP 3050 service manual for you that will walk you through it step by step. The teardown is significant however very do-able by the novice with the service manual.
http://h20181.www2.hp.com/plmcontent/NACSC/Printers/LaserJet/30328_020806/course/library/service/service.html
Good luck, You can do it.
Jul 09, 2008 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Laser Printer Copier 4-in-1 Logo
470 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
