Question about Linksys WRT54G3G Wireless Router (WRT54G3G-ST)
Default gateway problem with Linksys WRT54G3G-ST
My default gateway is 192.168.0.1 and Linksys help says it must be 192.168.1.1. Is this true and if yes, how can I change it? The linksys help said it is an aircard problem (Verizon PC5750). Also the reset button does not seem to work (when trying to reset to get to default user/pw) - is there a solution to this problem?
There chat is really awesome get on with them and they will walk you thru. I just did mine... the IP for the router access was 192.168.1.1 but mine was a GS. the user name you leave blank and the password is admin. If the password does not work then hard reset by holding a pen in the the back of the router for a full minute to allow all the power to drain and memory to erase.
Once you have access to the router you can set it to anything want... I suggest you set the number of DHCP leases to be one more than you have computers for so that a guest with a wireless can access without have to set up another access and MAC Filter.
As far as the AIR card goes use a ethernet cable to connect directly to the router to make the changes. then once you are in the router you will set the exact IP and default gateway required by your device and games... you can set them and open ports too... just do not open anymore than you have to..
Good luck,
Jason
Posted on Jan 28, 2009
Coda qoy
Sir
Checking or verifying the wireless settings of your Linksys Cable Gateway is important when connecting wireless devices to your network. This is the best route to take if you are unsure of your gateway's wireless settings.
The wireless settings that you need to take note of are:
  • SSID
  • SSID Broadcast
  • Wireless Security
To check the wireless settings on the Linksys gateway follow the steps below:
Step 1:
Access the gateway's web-based setup page. For instructions, click here. If you are using a Maccomputer to access the cable gateway's web-based setup page, click here.
Step 2:
Click the Wireless tab.
Step 3:
Look for Wireless Network Name (SSID). It is recommended to change the SSID to something unique.
Step 4:
Click the Wireless Security sub-tab and take note of the current Wireless Encryption Level and the Wireless SSID Broadcast if it is set to Enable or Disable.
If Wireless Encryption Level is set to No Encryption, this means that the wireless security on the gateway is disabled.
If Wireless Encryption Level is set to 64 Bit Encryption or 128 Bit Encryption, check the value under Default Key and take note of the Wireless WEP Key that corresponds to it.
I hope Your problem is Linksys router Problem is solved by now, In case You still need Linksys Router Help Then I Suggest you follow official Linksys Router Support URL Website mention below :
Linksys Support
Or
In case You still need online Linksys Router Support Then follow us On for Linksys Router Support
Mar 27, 2014 | Linksys WCG200 Router
My linksys WRT120N routers default ip is 192.168.0.1 when most peoples routers are 192.168.1.1 when they have the same router, what does this mean?
If you are able to access router settings then whats your problem..IP can vary ..that not an issue..are you getting any problem??
Jan 21, 2013 | Cisco Linksys Wireless N Home Router...
Forgot my password for wrt120n
Looking for the Linksys WRT120N default password? You probably have little reason to access your router on a regular basis so don't feel too bad if you've forgotten the WRT120N default password.
However, when you're troubleshooting a network problem and need to get in to the device, the WRT120N default password suddenly becomes very important.
For most versions of the Linksys WRT120N, the default password is admin. As with most passwords, the WRT120N default password is case sensitive.
In addition to the WRT120N default password, you can also see the WRT120N default username and WRT120N default IP address in the table below.
Note: The Linksys WRT120N default password may be different for certain hardware orfirmware versions.
If I have that information, I'll include the exact WRT120N version number along with the correct default password. You can usually find your Linksys WRT120N version number on the bottom of the router.
Be sure to change the default router password on your WRT120N to something more secure as soon as you're in. Then use a free password manager so you'll never forget your new WRT120N password.
Help! The WRT120N Default Password Doesn't Work!
At some point during the life of your particular Cisco Linksys WRT120N, the default password, username, and/or IP address might have been changed.
In most cases, if the Linksys WRT120N default IP address has been changed, the new IP address for the WRT120N will be the same as the default gateway IP address configured for your network connection.
See How To Find the Default Gateway IP Address for help.
In situations where the WRT120N default password or WRT120N default username has changed, you'll need to reset the Linksys WRT120N to factory defaults. You can usually do that via a special button or sequence of actions.
The WRT120N manual will have specific directions for performing a factory default reset. You can download the manual for the WRT120N from Linksys Support.
Please let me know if any of the WRT120N default login data below needs updated. For other questions about the WRT120N default information on this page, see my Default Password FAQ.
WRT120N Default Password & Other Default Login DataVersionDefault UsernameDefault PasswordDefault IPPrivilegesAll[none]admin192.168.1.1Administrator
Jan 13, 2012 | D-Link 802.11g Wireless Router WBR-1310...
The red light keeps coming on and i lose my connection, my neighbour has the same model could this b the problem?mant thanks Mell
Yes you may have them set to the same gateway address. Go into the router's setup and change the gateway.
example:
Linksys ' default gateway is 192.168.1.1 and if your neighbor has a linksys router, his gateway would be the same as yours.
I would change it to 192.168.3.1. This will isolate your router from his signal and vice versa.
If you need further help, respond with the model of your router.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response
Thanks, Joe
Feb 01, 2011 | Computers & Internet
How to get the ip adress from a linksys rtp300 phone adapter
I'm not sure if your asking for the IP ADDRESS of your Linksys or the DEFAULT GATEWAY of that device because your router's ip address will be provided by your server or Internet Service Provider (ISP) depending on your service. There are two ways of obtaining an ip address first will be DYNAMIC, where your ip address changes all the time and STATIC where you are given specific ip addresses for example 192.168.0.1 -to 192.168.0.25. The easiest way to obtain those ip addresses, by the way, is to contact your Internet Service Provider (ISP)
example: AT&T, Roadrunner, Time Warner, etc....
But, if your looking for the DEFAULT GATEWAY for you to access your router's configuration, most of the time it is found underneath the router itself. For Linksys the Default Gateway is 192.168.1.1
>I hope i helped you out with this... Enjoy!
Sep 15, 2010 | Linksys VOIP PHONE ADAPTER 2-PORT (PAP2NA)...
I can't access my linksys router set-up page. I keep getting this message: "401 unauthorized" authorization required
" 401 unauthorized" authorization required " .This message means the user name and password for the router is not correct. the default password of the Linksys router is admin with no user name ( leave it blank )
If the default password is not working then the router password must be changed.
If you don't know the password of the router then you will need to reset and reconfigure the router.
Once you reset the router , it will come back to the factory default settings.
Click here for more info about router and network
Jan 08, 2010 | Gateway Wireless-B Router (wbr-100)
Reseting without the button
192.168.1.1 default IP address unless you change it before....to verify the IP on your router ...right click on network icon or adapter icon ...select status...then DETAILS...the Default gateway is your routers IP
Apr 02, 2009 | Linksys BEFSR41 Cable/DSL Router W/4 Port...
Vista keeps losing internet connection
open device manager and  look at network adapters and right click on your device and go to properties and uncheck the power management box that allows pc to put device to sleep. this should resovle your problems since windows id defaulted to put device asleep when idle to save power. hope this helps.
Mar 14, 2009 | Linksys WCG200 Wireless Cable Modem 54G...
Get no connection useing 6100 modem connected to wireless B router
Hi starman re westell 6100.
Hi i hope you have find solution with your issue ifnot let me walk you through on how to get it up and working.
First , you need to connect your modem directly to your computer. We need to access its Graphic Unit Interface by opening your browser and type onyour address bar its default gateway.
The def. gateway can be 192.168.1.1 or depending what ISP youre connected to . For ATT broadband its 192.168.1.254 / verizon broadband is 192.168.1.1..  { onyour address bar : type in 192.168.1.1 and hit Enter.
to check def gateway : you can go to start > run > cmd then enter > on DOS command type in ipconfig /all  then HIT enter > itl provide you your network list > your default gateway is your westell modem or if your linksys is connected than it should be you linksys.
Itl route you to your westell page. Try to go to  Broadband and choose connection or configure connection.button. Look for configure and by default you will see its in PPPoE> change it to bridged ethernet and save.
By enabling bridge to your modem w/c is westell youl have a chance to configure you linksys to PPPoE.
Connect you westell to your linksys and on your computer try to check your default gateway as seen above. By default linksys can be access by typing in 192.168.2.1 or 192.168.1.1. Itl prompt you for UN and PW: by default your Username is : Blank and Password should be admin. { blank = dont type anything}
On your linksys SETUP page > by default it is set to DHCP or obtain IP address automatically. Pls change it to PPPoE and type in your UN and PW : username@isp { your ISP name}. and hit save settings or save.
Restart your linksys and try to browse to check fore connection.
For all types of modem such as westell : you need to set it to bridge mode first foryou wireless router to work ie linksys. Set linksys to PPPoE .. that should work .
For more detailed steps or questions re: this issue pls dont hestiate contact me. Best wishes.
Pls enable you Wireless Encryption for your home network security.
Ciao .
Prince
May 21, 2008 | Westell Wirespeed LiteLine 6100...
Open Questions:
Linksys WRT54G3G Wireless Router (WRT54G3G-ST) Logo
1,003 people viewed this question
Top Linksys Computers & Internet Experts
Prashant M
Prashant M
Michael Galve
Michael Galve
Are you a Linksys Computer and Internet Expert? Answer questions, earn points and help others
