Question about Indesit W 123 Front Load Washer
Indesit WA105 - drum is loose and fails to spin
The drum will not spin, the motor and belt are fine, it seems as though the drum has deattached itself from the spindle, if I turn the drum by hand its very loose and the drivewheel at the rear of the machine does not turn. Is this fixable?
  • 1 more comment
  • Jerome .... Jul 23, 2007
    The spider assembly attached to the inner drum is broken into many pieces, doesnt look like it can be fixed? its riveted to the inner drum.
  • Jerome .... Jul 24, 2007
    Many thanks Crytech for your reply, the parts are around £55 including the spider bolt kit(which is required as the original is riveted), but I reckon if I take out the drive spindle then I'll probably need to replace the bearings/seals as well, which will be around another £15 at least, so total cost is at least £70 + postage, not to mention a few hours to do it all, so guess I'll just buy a new machine (equivalent machine is £200 or less).
    Thanks Again Crytech
  • garrygoodiso Oct 20, 2008
    ~~Indesit WAX 120
    The drum is loose The bearing and drive wheel is ok. The drum can be moved up and down from the front door. is there a nut holding the drum to the shaft can it be tighte.nd from the frount
  • 51 Answers
Hi Jezzer69 It is repairable but will take about 3 -4 hours (if you know what your doing) and the parts will cost about 65% of what a new machine will cost. You need to weigh up how old the machine is and or if its "beyond economical repair" Regards
Posted on Jul 24, 2007
SOURCE:
LG DLE5977W dryer displays Clean Filter and hums without turning drum when Start button is pushed
I would guess a broken drive belt. Just take top off and check. Two screws on back, pull top back about 2 inches, left off. Belt should be around drum. If belt is loose or gone, it's broken.
Aug 21, 2018 | LG Dryers
My 1wd7145k (uk) has stopped working mid cycle, I have restarted and it fills with water ok but does not start to spin but continues to count down on the program timer. the motor does not spin and I
May be the rubber belt is gone open the screws behind the washing machine and check if the belt is worn out or cut replace by buying the belt of the same code number printed on the belt
Nov 15, 2014 | Indesit Washing Machines
Replaced belt on dryer but drum wont turn even though motor is running
are you sure youve got the right belt for that model dont know if all belts are standard or not its a posibilty you have the wrong belt as im asuming your your turning the drum when empty when you get it over the drum and motor should be really tight hope this helps you
Jan 19, 2013 | Indesit IS70C Electric Dryer
Drum of machine does not want to spin with elec motor
Some slippery material has deposited on the motor pulley. Clean it with a abrasive paper lightly. Also the inner side of the belt which comes in contact with pulley with light abrasive paper. Also make sure the belt is tight so that it can grip the pulley. If all this fails, it means the belt has become loose over prolonged use and requires replacement.
May 02, 2010 | Washing Machines
My indesit WG1230 washing machine does not spin or move drum but water go in and out.
With the door open, try spinning the drum, there should be some resistance along with a slight wherring sound. If it spins freely without much sound at all - you probably need a new belt.
If you can feel it driving the motor, you may need new contact brushes for the motor.
If the machine buzzes when it should rotate on program, you need a new motor Run capacitor also.
If no sound - nothing, the motor may need replacing or at least checking.
Nov 05, 2008 | Indesit Washing Machines
Dryer motor
if the motor buzzes when you push start then it is a bad motor.as long as the drum turns freely by hand.
Oct 29, 2008 | Whirlpool LER4634J Electric Dryer
Drum will not turn
check the belt if its not that the the brushes need replaced in the motor that will fix the spin problem
Mar 03, 2008 | Indesit W 123 Front Load Washer
Irregular banging during cycle
these washers are a swine to dis-assemble and i would not recommend it unless you are experienced. on most indesit, the bearings are in a spider bolted to the outside of the tub. take the back off and see if you can localise the noise to the bearings worthwhile also taking the heater out (one nut in the middle), peer in and check no foreign object causing the noise
May 21, 2007 | Indesit W 123 Front Load Washer
Machine does Agitate
Open machine's rear panel and remove belt. Check if motor spins (when it should, as per cycle stage). If motor is spining - Move tub manually and check for smooth spin In case it doesn't spin smoothly - maybe that a sock or other piece of clothing get between the clothes tub and the outer tub and prevent tub's spining. If this is the situation, you should remove it. In case motor doesn't spin- Check with multi-meter if it get power. If it get power - The problem is with the motor. Good luck !!
Jun 07, 2006 | Indesit W 123 Front Load Washer
Indesit W 123 Front Load Washer Logo
271 people viewed this question
Top Indesit Washing Machines Experts
Gerry Harvey
Gerry Harvey
jimorris77
Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
