My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
  • Amanda Jan 23, 2013
    It has started working again. She thinks the pump froze also and just needed some more time to thaw :)
  • Washing Mach... Master
  • 17,130 Answers
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Posted on Jan 24, 2013
  • 38 Answers
SOURCE: Washing Machine Hoover H100M fills too much water in the drum.
this is 1 of 2 solutions  2 this problem the first thing to check is the vacuum system or it is a split in the pressure switch hose
Posted on Mar 05, 2008
  • 50 Answers
SOURCE: washer making buzzing sound during
If I understand correctly, the washer made a sound in the spin cycle but didn't actually spin the clothes dry?
If so you may have something in the pump that is not allowing it to pump out. Disassemble the pump and make sure it is clear of any debris.
Posted on Jul 21, 2008
  • 1462 Answers
SOURCE: banging pipes when washing machine fills
it is called water hammer and is difficult to cure. try turning tap off halfway. another cure but difficult and not 100% is to take the copper feed pipe round in a circle
Posted on Sep 17, 2008
  • 132 Answers
SOURCE: Washing Machine does not fill up with water
THERE IS AN ELECTRONIC VALVE OR PUMP WHICH DECIDES WHEN AND HOW MUCH WATER IS ALLOWED TO ENTER THE MACHINE UNFORTUNATELY SOMETIMES IT HAS TO BE REPLACED I AM NOT 100% SURE BUT THIS MIGHT BE YOUR PROBLEM GLENN.....
Posted on Nov 15, 2008
SOURCE: GE TOP LOAD WASHER DOES NOT AGITATE OR SPIN
I have a GE MODEL WWSe5240G0WW top loader washer that has seen very little use. My problem is that the unit will not agitate or spin,every thing else seems to work ok. I did remove the top lid switch and jumped the to wires (Yellow/Red and Orange) still did not make any difference. Any in for would be great.
Posted on Feb 21, 2009
Washer won t fill water
pipes maybe clear but is your area wher you live prone to limescaling? where the water pipe/pipes go into the machine there is a switch to shut on/off the flow of water during whatever cycle you want.this might be blocked or sticking. first try to select different cycles and see if any of those fills the machine with water. if no water comes its one of two things. that switch is faulty or communication between the switch and the front consule is at fault.
contact your supplier after trying to go thru a few different cycles.
Dec 04, 2013 | Frigidaire Washing Machines
Whirlpool lsb6000pq2 washing machine won't fill with water
Humming could be a blockage on the fill solonoid valve remove water fill hose and clean the filter at the valve it pulls out or use an old toothbrush
Jun 26, 2012 | Washing Machines
My washer buzzes when knob is pulled but it will spin just not fill or agitate
sounds to me like either the water faucet at the wall is shut off or their is some sort of restriction to the pipes not allowing the washer to fill
some on here may say that the buzzing will be the motor but since it spins i say bully to them the motor only knows to go to spin or agitate rotation based on on what the timer/control tells it to do if it will turn one direction it would turn the other direction as well. So definently check the water supply to the washer
Oh the buzzing is the solonoid on the valve opening the valve yet since no water coming in you hear the buzzing while you wouldnt hear it since it would be drowned out by the sound of the water coming in
Jul 19, 2011 | Washing Machines
My washing machine , a hotpoint wdd960 , wont stop filling with water , i had problem since the frosty weather when water froze. i have took top of machine and all electrics are soaked, it is 3 years old ....
you will find at the drum bottom there is a 5mm pipe leading to the water censor remove it and blow gently into it you should hear a click and one when you release the air this means that the censor is ok but the small pipe where you took the pipe from is blocked not allowing the air pressure to build up to tell the controller that water is full enough to continue to the next cycle clean out the small pipe with a pipe cleaner, dry the parts of the machine with a hair dryer eric
Dec 26, 2017 | Washing Machines
Squeals when hot water inputs
Is there a faint buzzing or humming noise coming from the water-inlet valve? (The water-inlet valve is the device on the washing machine that the fill hoses are attached to.) If you can't hear anything, the water-inlet valve may not be getting any power. If you can hear some noise and there's water present, you may need to completely replace the water-inlet valve.
Jan 10, 2010 | LG WM2101HW 4.0 cu.ft. Washer
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Agitator does not move but activates high pitch buzz
genaral electric washing machine fills won,t spin but throws out water as if it did, goes to next cycle same thing, but sounds as if it is spinning but isn,t, hose not clocgged i checked, what else can be the problem,sounds ok but not spinning
Jan 26, 2009 | Roper RAS8445KQ Top Load Washer
Whirlpool fridge model WF-NL300 ice maker not working. No water in icemaker. Black water supply tube that fills icemaker was frozed solid with ice. I thawed it in a cup of hot water. Unsure if line could...
Turn ice maker off for 24 hours to thaw out any additional frozen lines.
Make sure that you do have water from source to unit. Water valve grit screen may be clogged with debrie or water valve is bad.
Feb 29, 2008 | Refrigerators
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
