Question about Fujitsu ScanSnap Manager
Scansnap hardware error 0x00048004
When I attempt to scan with my scansnap s1500 I get an error in scansnaps hardware (0x000480004)
I had this exact same problem. Turned out that I was using the wrong power adapter. Enough power to turn on the scanner lights and connect to the computer, but not enough to actually perform a scan. As soon as I realized I was using the wrong power cord, I switched it up and voila!
Posted on Aug 05, 2014
  • 1 more comment
  • Ryan Stewart
    Ryan Stewart Jan 13, 2015
    That was the exact problem that I had.
  • Anonymous Aug 03, 2016
    Thanks so much! Was spinning my wheels on this, and would never have thought that someone supplied my user with the wrong power adapter. Managed to find the right one in a box of parts.
  • Anonymous Nov 15, 2016
    Same with me. I came to an office which had relocated down the hall and they switched power supplies and put the wrong one in the ScanSnap. Thank you do much for posting your solution!!!
Very frustrating and I almost threw my scanner in the trash because of this... here's the fix.
go to C:\Windows\System32\spool\drivers\color from another computer that has the same operating system and copy "sRGB Color Space Profile.icm".
Place the copied file unto the trouble computer - copy the file in the same location.
Good luck
Posted on Oct 24, 2013
4 Suggested Answers
SOURCE: error while attempting to install ScanSnap Manager on Win XP Pro
Bypass installation wizard and just run the setup.exe file for ScanSnap Manager. Installation wizard is bugged.
Posted on Jan 12, 2009
JulesPCaut
  • 702 Answers
SOURCE: problem installing Scansnap S510
This is probably due to the program using the same folder for the new version of the program. Best solution would be to uninstall the new version, uninstall the old version and then reinstall the newset version only.
Running a registry cleaner in between does not harm.
One other thing to try is an uninstall program, but I am not sure that will help.
Posted on Apr 23, 2009
SOURCE: driver scansnap
What needs to be deleted in the registry?
Posted on Sep 12, 2008
NEED SCANSNAP 1500 DISK NEW SCANNER DISK IS LOST
don't know if you ever got this resolved but....
http://www.fujitsu.com/global/support/computing/peripheral/scanners/software/s1500.html
check under the operating system tab to select the right installer for you.
Mar 23, 2013 | Fujitsu ScanSnap Manager
Lost cd to scansnap s1500
If you are unable to find the exact drivers then connect your device to PC and run driverscanner tool to find the recommended drivers. You can get the tool here:
DriverScanner2013.net
Nov 06, 2012 | Fujitsu ScanSnap S510
My scanner keeps flashing and not pulling the paper through, I cannot seem to figure out why it will not scan. It does this quite often, what is the problem that is causing this? Scansnap S1500
Go to msconfig or if you have a registry cleaner, go to the startup menu. Disable and ssmgr (scansnap manager in pfu). Reboot. Open the ScanSnap 1500 and then start the ScanSnap manager. The scanner is now ready to scan.
Jan 26, 2011 | Fujitsu ScanSnap Manager
I installed ScanSnap on Windows 7 under the administrator account and it works successfully. The problem is with the other non-administrator account. The ScanSnap icon was not installed on the...
OK; after giving up on lousy tech support I got it working after doing the following (not sure if all required, but this is what I did)
1. Gave admin rights to C:\Program Files (x86)\PFU
2. Updated to latest ScanSnap Manager V5.0 L21
3, Copied C:\Users\<admin acct>\AppData\Roaming\PFU directory to C:\Users\All Users
Good luck...
Mar 21, 2010 | Fujitsu ScanSnap Manager
Have just installed S1500 software and finished the installation but get an error message "Failed to initialize drinver module (0 X 80210019)". What does this mean and how do I proceed? ****
Try the following step :
Pre-Installation Steps
  • Log onto PC with an account that has Administrative Privileges.
  • Disconnect ScanSnap scanner, if connected.
  • Close any open applications.
  • Install ScanSnap Manager, ScanSnap & CardMinder software from the ScanSnap Setup CD-ROM.
    • Upon reboot of the installation you may receive an error message stating, “Failed to initialize driver module.” Please disregard and continue.
ScanSnap fi-5110EOX Vista Update Pack Installation Steps
  1. Download the fi-5110EOX Update Packs (Vista 32-bit Support)
    1. ScanSnap Manager V3.0 – ssv3020up.exe
    2. CardMinder V2.0L10-V2.0L11 – cm2012.exe
  2. Install all two update packs that were downloaded in Step #1.
    1. Reboot is NOT required after each update pack.
  3. Reboot the PC after all three update packs installed completely.
  4. Connect ScanSnap Scanner via USB, open lid, let Windows Vista install the new hardware.
Mar 07, 2010 | Fujitsu ScanSnap Manager
PFUSSMON HAS STOPPED WORKING ON MY SCANSNAP S1500
Find your specific scansnap product and update it:
http://www.fujitsu.com/us/services/computing/peripherals/scanners/support/downloads.html
A user had a similar issue and I found this update for the scansnap S1500 manager:
http://www.fujitsu.com/global/support/computing/peripheral/scanners/drivers/s1500.html
This occurs with certain Intel dual core processors, so you might be effected accordingly.
--Rob
Jul 08, 2009 | Fujitsu ScanSnap Manager
Error while attempting to install ScanSnap Manager on Win XP Pro
Jan 09, 2009 | Fujitsu ScanSnap Manager
Fujitsu ScanSnap S300 PfussMon has stopped working
--Rob
Apr 09, 2008 | Office Equipment & Supplies
Computers & Internet Logo
6,112 people viewed this question
Top Fujitsu Computers & Internet Experts
Computer Links
Tony
Are you a Fujitsu Computer and Internet Expert? Answer questions, earn points and help others
