Question about Whirlpool Cabrio Washing Machines
My moms water pipes froze in to her washer and then thawed out. The washer filled with water but it won't wash the clothes. Just fills and sits there. You can hear a buzzing noise like the motor should be running but it's not. My mom said she thinks maybe the pump is broken? What could be the problem and how does she fix it?
SOURCE: washer won't spin but motor runs and belt is not broken
The motor bracket is broke, which allows the motor to "jump" causing the belt to come off.
Posted on Oct 29, 2007
Washer_tech
  • 164 Answers
SOURCE: Not enough water
run the machine empty. if the water comes to the bottom of the glass window, you're fine. No you don't need to see the soap suds either, too musch soap will cause the machine not to function properly and won't spin out all the water
Posted on Nov 17, 2007
  • 132 Answers
SOURCE: Washing Machine does not fill up with water
THERE IS AN ELECTRONIC VALVE OR PUMP WHICH DECIDES WHEN AND HOW MUCH WATER IS ALLOWED TO ENTER THE MACHINE UNFORTUNATELY SOMETIMES IT HAS TO BE REPLACED I AM NOT 100% SURE BUT THIS MIGHT BE YOUR PROBLEM GLENN.....
Posted on Nov 15, 2008
  • 60 Answers
SOURCE: Lid Switch Trigger Broken: How To Fix this?
There is no fix for the lever. Go to www.repairclinic.com and order you a new one. They are cheap and relatively easy to replace.
Posted on Mar 14, 2009
  • 77 Answers
SOURCE: washer wont agitate or spin
Sounds like your transmission is going bad. usually they will pop the belt when going out. Probably with a service call and the cost of the transmission, you'd do better heading to sears. Sorry to bear the bad news. Good luck.
Posted on Apr 21, 2009
Washer won't fill
check to make sure your clothes are not covering the middle of the drum it has a sensor there for the water to come in
Feb 02, 2013 | Whirlpool WTW57ESVW 4.0 Cu. Ft. Top Load...
My moms pipes froze to her washing machine. They thawed and the machine filled with water but they won't wash. She can hear a buzzing sound like the machine is trying to wash the clothes but nothi
Yes , I think the valves also must have jammed in the process and when the hot water filled up in due course it must have released.
It is best to switch off water supply to the machine in such times.
Jan 23, 2013 | Washing Machines
WASHER FILLS WITH SEDIMENT AND DESTROYS CLOTHES
do a wash with no clothes in a hot wash only
Jan 17, 2013 | Washing Machines
Whirlpool top loading washer won't fill completely
did you shorten the stand pipe for the outlet drain ?if not try putting a short extension on the top .
Nov 18, 2017 | Whirlpool Washing Machines
Water won't stop filling the washer
water fill valve is probably stuck open. see if you can find a blockage or just replace it
Feb 03, 2012 | Kenmore HE2 Washing Machines
It is very cold in my garage where my Fisher and Paykel washing machine is. First it would not fill it just ran and ran without filling, then it started filling fine, but then after a while started...
water freezes. sounds like first your fill pipes were froze then the pump froze. if you can find a place inside the house for washer or you may have to build a room around washer and dryer and heat it
Dec 13, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
23 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
