Question about Keurig B60 Coffee Maker
Can't drain the water out.
My coffee maker isn't brewing a whole cup,i cleaned it with vinegar,still didn't work,it seems like there is water in the coffee maker,how do i drain it?
  • 1,511 Answers
Drain by turning the unit upside-down and clean the ports, Needles that puncture the Kcups.
Posted on Jan 31, 2014
SOURCE: keurig coffee maker won't draw water from the resevoir
I just got mine to work by forcing water into the pump to force it to prime. I took a syringe for a meat injector and built a gasket so it would seal over the water intake. Then I forced several syringes of water into the pump till it finally picked up and caught its prime.
Posted on Mar 02, 2009
SOURCE: Slow coffee stream and smaller brew size with B70
I had the same problem. In my case the needle that pierces the cup was clogged. All you need to do is unfold a paperclip (small and not plastic coated) and push it down through that needle to clear the blockage.
My unit works better then ever!
Posted on Mar 14, 2009
  • 25 Answers
SOURCE: Keurig starts & stops without brewing coffee, just descaled
The pic is clogged with coffee or the air bladder is bad. Use the tool on the underside of the tray to clean out pic. If that doesn't work, the bladder will be bad.
Posted on May 14, 2009
  • 5 Answers
I had the same problem, contacted Keurig and they suggested the descale procedure, which did nothing. The brew size was very small, the display would not let me select the size, and water was being pushed back into the reservoir. I was able to resolve the problem however.
First I went through a gallon of white vinegar, without results. Then I did the following:
Went to Walmart and bought "Brew Rite". Tried 8 cup mixture (8 cups of water, two tablespoons of mix), did not work. Being persistant, put in another 8 cups, and when the reservoir was empty of the solution let sit 2 hours while unplugged and then put in clear water. By the time I got half way through with the clear water, the device started working properly, no problems since. This may work for you...
Posted on Aug 12, 2009
SOURCE: Keurig only brews about 2-3 oz. of coffee.
Doesn't sound like a descaler issue. I am having problems with mine and noticed that water is flowing back into the reservoir when it is pouring into the coffee cup. I think there is a valve that is not closing properly.
Posted on Mar 23, 2010
How do i clean the water chamber
Well I use vinegar. Fill the water chamber with 1 cup vinegar and water. Run through a brew cycle. Than run through again with plain water.
Jul 18, 2015 | Coffee Makers & Espresso Machines
How can I fix my coffee maker when the water resovior will not drain?
Try cleaning it by brewing a 50/50 mixture of white vinegar and water. You may have to run it through a couple of cycles with a fresh mixture each time. Then rinse by brewing water only a couple of times. Over time calcium and lime builds up inside the tubes of the machine and restricts the flow so this should be done once every few months or as needed. The vinegar will loosen the mineral deposits and flush them out.
Jun 01, 2014 | Cuisinart Grind and Brew 10 Cup Coffee...
How do you descale
Since you don't specify what type of machine you have, these directions are a bit general: Run a solution of white vinegar and water through the machine, turning it off 1/2 way through the cycle and let it sit for 20 min to 1 hr. Then turn it back on and let the rest of the solution brew through. Dump that, rinse off the carafe, brew basket or whatever parts are removeable, are run a brew cycle with just water Different makers will tell you different amounts of each to use, but I usually mix about 1/2 water and 1/2 vinegar, sometimes more vinegar. Don't use all vinegar, there's no reason to waste it, and less than 1/2 vinegar won't work very well. It depends on what kind of machine you''re descaling for the total amount of water/vinegar mix you would use... if it's a 4 c. Mr. Coffee, I do the whole pot. If it's a 12 cup coffee maker I use about 4or 5 cups of the mixture. Something like a Keurig is a bit more tedious - same general directions, but after rinsing the water holder, run clean water through the brewer several times before making coffee again.
Mar 31, 2012 | Coffee Makers & Espresso Machines
WATER LEAKS BOTTOM OF UNIT WHEN IS MAKING COFFEE ALSO, HOW DO YOU DECALCIFY UNIT? iS THERE AN ON LINE MANUAL?
Below are solutions for a leaking coffee maker and how to decalcify the machine?
Tools and Materials needed to fix this problem are as:
* White Vinegar * Fresh Water * Volt-ohm Meter * Screwdriver
Step 1 - Clean
If your coffee maker seems to be clogged, try cleaning it with a mixture of white vinegar and water. Assuming that your coffee maker has a 12 cup capacity you will want to use 11 cups of vinegar and 1 cup of water. Fill the coffee pot to the 11 cup mark with vinegar and then fill it to the 12 cup mark with water.
Pour this mixture into the reservoir and turn on the coffee maker, allowing it to run through a brewing cycle as if you were making a pot of coffee. By doing this you will dissolve any build up in your coffee maker. If the coffee maker is leaking because the pump is clogged, then this might clear the clog and stop the leaking. If it has been a while since you last cleaned your coffee maker, you may need to run the vinegar through more than one cleaning cycle to dissolve all of the buildup.
Step 2 - Pump Valve
Unplug the coffee maker and examine the pump valve. If the pump valve is broken or has a clog, then the water will not be able to rise up and flow through the fill tube. When the coffee maker is turned on, the water needs to go someplace. If it cannot flow through the fill tube, then it may leak onto the countertop. If the pump in your coffee maker is sealed, you will need to replace the whole pump. If the pump is not sealed you should check it to ensure it is not clogged with coffee grounds or mineral deposits.
Step 3 - Brew Switch
Examine the brewing switch to ensure that is working. To get to the brewing switch, remove the base plate. Next, you will need to test the switch with your volt-ohm meter. Touch the tester to the RX1 scale. If it reads 0 ohms then you will know that the switch works fine. If it gives you a number other than 0 then it is time to replace the switch.
Step 4 - Tube Connectors
If the coffee maker is leaking or sputtering then you should take a look at the tube connectors. Many times, a leaky coffee maker is caused by faulty tube connectors. If you find the leak is in an elbow, clean the surfaces before you replace it. If the tube connector leaks, replace both the tube and the elbow so that you can be sure the pieces will both fit together properly.
To decalcify, you will be needing a : decalcifying cleaner and A container large enough to hold the same quantity of liquid as your water reservoir
1) Remove the machine's water reservoir. 2) Empty all liquid from the reservoir. 3) Fill the reservoir with warm water. 4) Add one packet of the recommended cleaner to the full reservoir and stir until the cleaner is dissolved. 5) Return the water reservoir to the machine. 6) Turn the machine on. 7) Set the large container underneath the steam wand. 8) Set up your machine so that hot water -NOT steam-will be emitted from the steam wand when the steam valve is opened. 9) Open the steam valve according to the manufacturer's instructions. 10) After all of the decalcifying solution has drained into the large container (within a few minutes this will occur), remove it and discard the liquid that has been collected. 11) Rinse the water reservoir thoroughly and then fill it with the type of water you usually use for brewing. 12) Return the water reservoir to its normal position. 13) Using only water repeat steps 7 through 9 until the water reservoir is empty again.
I hope the above helps....
Good luck.
Jun 22, 2011 | Jura Capresso Impressa S8 Coffee Maker,...
UNIT STATED TO DE SCALE ,I USED VINEGAR AND THIS SEEMED TO FIX THE PROBLEM , NOW UNIT WILL NOT BREW A FULL CUP OF COFFEE .IT JUST STARTS TO WORK THE SHUTS DOWN AND SAYS ITS STILL BREWING.
Do you live in an area with hard water? It sounds like you have a blockage.
Unfortunately, doing a vinegar de-scale loosens up a lot of gunk, and some of that gunk might be blocking the holes through which the water from the reservoir goes into the filter basket. Think "kidney stones" (ugh).
One solution would be to do a couple more vinegar brews, to help break up this matter. Another might be to lay the coffee maker on its side on the counter & try running a toothpick or other suitable instrument (needles, etc.) into each drain hole, clearing any possible blockages. (Typically, the drain holes are in a "shower head" configuration. There may be a ring of anywhere from 8 to 20 drain holes).
This may or may not help. Do you use filtered water? I live in a hard-water part of the country, and - even using filtered water! - I still have to look at replacing my coffee maker every 3 years or so.
Best of luck :)
Mar 02, 2011 | Keurig Platinum B70 Coffee Maker
My keurig coffee maker is flashing the words DE SCALE. What does that mean and how do I fix it?
"Scale" is deposits of minerals, etc. normally found in water. Boiling a container of water (in a pot, or coffee maker in this case), leaves small amounts or "deposits" of these minerals on and near the actual heat source. If not removed, they can slow brewing time and more importantly, adversely affect the taste of coffee.
Descaling should be done at regular intervals to prevent this from happening. Your machine lets you know when to perform the descaling task. There are a number of products sold in your supermarket that will do this for you - but one of the least expensive; and just as effective - is to use white vinegar. Here's how to do it:
1) Drain your Keurig coffee machine over a sink.
2) Fill the machine with undiluted white vinegar.
3) Run the brew process at least four times, pouring the cups of vinegar back into the coffee maker.
4) Optionally, let your Keurig coffee maker sit for a few hours, then run the brew cycles again. Pour the vinegar into the sink and drain any remaining vinegar.
5) Fill your coffee maker with fresh water. Run multiple brew cycles with fresh water each time to thoroughly rinse the machine before returning to normal use.
That's it!
I know this will help & good luck. Please rate my reply - thanks!
Feb 06, 2011 | Keurig Ultra B50 1-Cup Coffee Maker
The coffemaker won't brew and showed a descale message. What does that mean?
Scale---or mineral deposits---form from the water you run through your Keurig coffee machine. If not cleaned regularly, the buildup can clog the lines in your machine and ruin the heating element. The manufacturer recommends you descale Keurig coffee makers once every six months for normal water conditions and once every three months if you live in an area with hard water
1.Unplug the coffee machine and remove the cup.
2.Turn the coffee machine upside down over the sink in order to fully drain it of water. Be careful of the plug and avoid getting it wet.
3.Pour undiluted white vinegar into the reservoir up to the top edge of the viewing window.
4.Place a ceramic cup under the machine, plug it in and press "Brew" for a large cup. Pour the cups of vinegar into the sink and repeat the process until the reservoir is empty.
5.Remove the final cup of vinegar and empty it. Fill the coffee maker with clean water and allow it to sit for four hours, remaining on.
6.Unplug the machine and dump the water into the sink.
7.Fill up the reservoir with fresh, clean water and plug it in. Place the ceramic cup back on the drip tray and run multiple brews in order to rinse the machine of any remaining vinegar residue
Dec 10, 2010 | Keurig B70 Coffee Maker
Cleaned my mr coffee pstx properly and the light will not go off . Unplugged it and everything help !!!
!!!!FIXED!!!!
I know this an old question, but I finally fixed mine. Hopefully this will help someone. I have a PSTX Mr. Coffee (10 cup) maker.
Allow me to provide some background first ...
I started a clean cycle, following the instructions in the booklet exactly. I used 4 cups of white vinegar and pressed the clean button. Easy, right? The reservoir emptied about 2/3, the clean light began blinking and an audible (steady) alarm sounded. I waited for 2 hours for that audible alarm to stop, but it never did. Finally, I unplugged the coffee maker, plugged it back in and tried again. Same results. By this time, I figured I had run enough vinegar through it to properly de-calcify the unit, so I repeated the "clean" steps numerous times with just plain water. Same results. I realized that I could still brew coffee; only thing is, the darned clean light would keep coming on when I pressed brew. Surely, I did something wrong or there would be an answer on the web. I searched many answers, but none fixed my problem. So I decided to call Mr. Coffee (US: 800.672.6333 or Canada: 800.667.8623). I navigated through the menu and found the troubleshooting section for cleaning. The automated voice said, "Place 6 cups of cleaner solution or white vinegar in the reservoir...."
Stop the presses! Did she just say 6 cups? The manual clearly states 4 cups. Also, that's what everyone else on the web is reporting.
So I tried it, and I only used water (since the pot was still relatively clean) - 6 cups of water - pressed the clean button. This is what you SHOULD expect:
1. Place 6 cups of cleaner solution or white vinegar in the reservoir
2. Press the "clean" button.
3. When approximately 2/3 of the solution has brewed through, it will [apparently] stop brewing - the "clean" light will begin blinking (but there should NOT be any sort of audible alarm) - let the maker sit; it's still working on the clean cycle.
4. The final 1/3 of the solution will brew through and the cleaning light will shut off.
This CONCLUDES the cleaning cycle.
Of course, you should just perform a few "regular brew" cycles with just plain water to clear out the vinegar (or cleaner solution) odor.
Bottom line: The manual screwed all of us! 6 cups, not 4!
Try it - Hope it works for you as well as it did for me.
John
Nov 16, 2010 | Mr. Coffee 072179228578 12 Cup Coffee...
Cuisinart DCC2000 quits brewing after 1or 2 cups
Finally, I got my coffee pot to run through without stopping several times. To fix it I had to run vinegar through eight times! Never before has it taken so many cycles to clean out a pot. It is still spluttering a bit so today I am going to get more vinegar or maybe even CLR and run it through a few more times.
Nov 18, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Coffee pot turns stops brewing in the middle of the cycle
Yup thats the Ticket - EASY FIX -
you have to clean the insides too people... lol.. The best way to do it is to buy citric acid crystals available from your local pharmacy. who knew huh? a couple of tablespoons in distilled water. Brew half the pot and let it sit for 30 min the brew the rest of the pot. Notice the color of your water after your done brewing. probably green from copper.. I could go into much more detail but thats the short answer... brew another pot or two of just plane ole water and bang your good go.. You should do this every month with any coffee pot for better tasting coffee..
Jan 20, 2008 | Cuisinart Grind and Brew 10 Cup Coffee...
Keurig B60 Coffee Maker Logo
47 people viewed this question
Top Keurig Coffee Makers & Espresso Machines Experts
Lisa
Lisa
Jason
Are you a Keurig Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
