Question about AEG Lavamat 12710 Front Load Washer / Dryer
AEG Lavamat Turbo 12710 update. Machine is AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts t
I tried clean everything but nothing happens what can i do need help asap please
    Top Expert:
  • AEG Master
  • 12,223 Answers
Test the following steps and fix it. God bless you
If the washer won't start, the user control and display board may be defective. Check for power to the washer first.
If the washer won't start the timer might be defective. This part is often misdiagnosed, check other components before replacing this timer.
If the washer won't start the line fuse might have blown.
If the washer won't start the thermal fuse may have blown. It can be tested for continuity. Watch our fuse testing video for more information.
If the washer won't start the line fuse might have blown, or the line fuse holder might be damaged and need to be replaced.
If the washer won't start the main control board might be defective. This is not common. Check other parts and causes first.
If the washer won't start the lid switch assembly might be defective. This is a very common problem. The lid switch assembly can fail either mechanically or electrically. Test any electrical switches with an Ohm meter for continuity. The switches should have continuity according to their design
If the washer won't start the door lock assembly should be checked. The door lock can fail either mechanically or electrically. Test any switches on the door lock with an Ohm meter. The switches should have continuity according to their design.
If the washer won't start check to see if there is power at the electrical outlet which the washer is plugged into. Plug a lamp or radio into the outlet to check it. If the outlet is dead, check the circuit breakers or fuses for the home.
If the washer won't start, check to be sure there is power to the electrical outlet for the home. If that is OK, the power cord itself might be defective. This is rare. You can check the power cord with an Ohm meter for continuity.
Posted on Jan 23, 2013
2 Suggested Answers
adrianaloret
SOURCE: AEG Lavamat Turbo 12710 update. Machine is
hello i have the same problem has the person above said but cant find the brushes on the motor, what can i do ? NEED HELP PLEASE
On an aeg lavamat washer dryer l12710 where is the filter for the dryer I have cleaned the front one for the washer ?/
If you go to www.aeg.co.uk and look under "service and support" you will see a box to insert your model number. I've put your model in and there's service manuals in several languages. Happy hunting.
Nov 03, 2014 | AEG Lavamat 12710 Front Load Washer /...
Lavamat 12843 no power
Maybe a bit late by now noting your question date.. If you have L & N from supply through suppressor to pcb it could be board u/s but well worth checking for low insulation on elements as oddly this can cause the display not to light!. If you don't have a suitable meter disconnect all wires to elements and see if it works.
May 08, 2014 | AEG Lavamat 12710 Front Load Washer /...
Aeg lavamat turbo 16830
start at the beginning,, check your fuse
Jul 16, 2013 | Washing Machines
I have an AEG Lavamat 16850, only bought it 2 months ago. I have an EFO message and 3 beeps every minute. I have emptied the filter and it is a clean as a whistle and emptied the hose as well. I am not...
You have a leak in the machine and water is accumulating in the base pan. Most likely this leak is a manufacturing issue or a transportation issue. Check to see where the leak is coming from under the machine. If in warranty call the dealer.
Nov 15, 2017 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat Turbo 12710 update. Machine is refusing to start on any program. I set program. Instrument panel lights up as expected. Time indicator starts to flash. Door indicator light then goes from...
You will need to change the carbon brushes in the motor. Tip machine 45 deg backwards you might need someone to hold for you and look at motor underneath you will see 2 black carbon brushes remove these and replace if worn then retry machine also make sure the wires to the motor are ok.
Jan 07, 2011 | AEG Lavamat 12710 Front Load Washer /...
I have a aeg lavamat turbo washing machine .when start it the water does not got to the drum ane water never stops simply running
You have a syphon - the waste pipe is probably too low and the end sits in water in the drain, meaning the water runs through the machine and out the waste.
Jun 30, 2010 | AEG Lavamat 12710 Front Load Washer /...
AEG Lavamat 16820 turbo Washer/dryer won't start - makes noise
Here is a tip that I wrote about dryers and noises...
It will help you determine what is happening there...
Dryer Repair Squeaks, Grinding, Clicking and Knocking Noise
heatman101
dgmj
Apr 18, 2010 | AEG Lavamat 16810 Front Load Washer/Dryer
AEG Lavamat 12710 Front Load Washer / Dryer Logo
768 people viewed this question
Top AEG Washing Machines Experts
Gerry Harvey
Gerry Harvey
Einar Axel...
Einar Axel...
Level 1 Expert
Are you an AEG Washing Machine Expert? Answer questions, earn points and help others
