Question about Endurance TF3i Folding Treadmill
Treadmill stuck in folded position
My treadmill is stuck in the folded position. It is 3 weeks old and has only been used a few times. It is stuck in the upright or storage position. It will unlatch - but will not lower to the floor. HELP!
  • Anonymous Feb 28, 2009
    My Treadmill is stuck on a half fold... and i forgot to put the incline to its lowest level
Nordic track treadmill is stuck up in space saver position
see the video and proceed , use the common sense. God bless you
Oct 07, 2012 | Nordic Track NordicTrack Treadmill, A2550
Treadmill deck will not fold in the storage position
HOW TO FOLD THE TREADMILL FOR STORAGEBefore folding the treadmill, adjust the incline to the lowest position. If this is not done, the treadmill may become permanently damaged. Remove the key and unplugthe power cord. CAUTION: You must be able to safely lift45 pounds (20 kg) to raise, lower, or move the treadmill. 1. Hold the metal frame firmly in the location shown bythe arrow at the right. CAUTION: To decrease the possibility of injury, do not lift the frame by the plastic footrails. To raise the frame, bend your legs, keep yourback straight, and lift with your legs. Raise the frameabout halfway to the vertical position. 2. Raise the frame until the latch knob locks into the storageposition. Make sure that the latch knob is locked in thestorage position.To protect the floor or carpet from damage, place amat under the treadmill. Keep the treadmill out of direct sunlight. Do not leave the treadmill in the storage
position in temperatures above 85 Fahrenheit.
http://www.treadmilldoctor.com/?utm_source=fixya&utm_medium=CPC&utm_campaign=Mendi
Jul 15, 2012 | Epic View 550 Treadmill
How to fold my afg 5.0 treadmill for storagae
Dear Sir: Hello , i hope everythign is o.k
Please do the following:
FOLDING Firmly grasp the back end of the treadmill. Carefully lift the end of the treadmill deck to the upright position until the foot lock latch engages and securely locks the deck into position. Make sure the deck is securely latched before letting go. To unfold, firmly grasp the back end of the treadmill. Gently press down on the foot lock latch with your foot until the lock latch disengages. Carefully lower the deck to the ground. NOTE: on some models the foot lock latch might be on the right hand side. NOTE: when folding the Horizon Fitness Treadmill the console assembly will tilt away from you, but will return when fully folded in the upright position. Please allow two additional feet from wall when folding.
Thank you in advance, sincerely. Blessing.
If you need additional help, please contact me.
e.cuadra Managua, Nicaragua C.A.
Sep 25, 2011 | Horizon AFG 5.0 AT Treadmill
I can't fold my treadmill back up. Instead of folding upright at the 12 o'clock position it is tilted to the 11 o'clock position. Any ideas why it won't go all the way upright?
1) SEE IF SOMETHING IS PENDING between the folding section
2) Your Pin is little bend.
3) the receiver where the pin is coming is not adjusted.
sincerely.
Sep 14, 2011 | HEALTHRIDER S300i Treadmill Motor Control...
How do you get the running deck down?
If you are saying that the deck is in the folded position and will not fold down then pull the pin on the left side of the deck. If the pin is stuck then try and plug in the treadmill insert the safety key and push the down incline button on the console. This should make it so that the pin will un-jam.
Aug 21, 2010 | Proform iLog 750 Treadmill
DOES THE UNDERNEATH SURFACE OF THE TREADMILL RUNNING BELT NEED TO BE TREATED WITH ANYTHING BECAUSE IT SEEMS TO BE STICKING
Yes! these units need to be maintained depending on usage. for example: 2 people using a treadmill 3 times weekly for a period of 30 min @ a pace of 3 mph would need to apply lubricant on deck every 3 months. Any exercise specialty store or sporting goods that are selling treadmills should have these lubricant kits with instruction on how to apply it.
Now their is a chance that your treadmill may either need the running belt or drive belt (under motor shroud) to have the tension adjusted.
Mar 11, 2010 | Proform 730 Folding Treadmill Model...
3 yr old Smooth Fitness 7.1HR Pro won't Unfold
Did you unlock the lift control? You have to rotate the knob that is just above the pwer switch to let the unit lift or lower.
Feb 23, 2010 | Smoothfitness Smooth Fitness 7.6 HR Power...
Can't find on button
Is there a magnetic key on the panel for safety that you have to wear when using unit? Try putting it in and out several times.
Jul 06, 2009 | Proform Sport 1000 Folding Treadmill...
Endurance TF3i Folding Treadmill Logo
192 people viewed this question
Top Endurance Exercise & Fitness Experts
Howard
Howard
Tom Chichester
Techmotionusa.com
Techmotionusa.com
Are you an Endurance Exercise and Fitnes Expert? Answer questions, earn points and help others
