Question about Sewing Machines
Singer furtura 920 needle and bobbin timing
How do I fix the needle and bobbin sync?
SOURCE: Bobbin won't p/u thread Singer 478
i have no idea how to thread this machine ?
Posted on Aug 16, 2008
Rahul Sudhan
  • 30 Answers
SOURCE: How do I fix a
Here's how you set the timing od the Machine alright:
1. Take the side plate off, take the needle plate off.
2. Take the presser foot off, and put a new needle in the machine. 3. Make sure that the needle is in the lowest position and look at the needle bar for the two timing lines. Locate the top line.
4. Then, turn the handwheel toward you until the top line is where the bottom line was.
At this point, the tip of the hook should be directly in the scarf of the needle.
This should set the timing of the machine perfect....
Posted on Jan 05, 2009
Mongo32
  • 111 Answers
SOURCE: Singer 8280 bobbin thread not taken up by needle
needle in backwards?
Posted on Jul 08, 2009
  • 20 Answers
SOURCE: needle hitting bobbin case model 750
This is a timing problem the hook timing needs adjustment, and possible the needle timing also
Posted on Oct 13, 2009
SOURCE: Just bought machine, new needle, thread, Needle
try sewusa loads of manuals and sewing diagrams. Since its a older machine.I would clean and oil it also.Lint can cause all kinds of issues.
Posted on Dec 29, 2009
On my Singer 6235 sewing machine, needle will not pick up bobbin thread. Any suggestions to fix the problem?
Doesn't pick up bobbin thread
1. The bobbin may be in backwards.
2. The bobbin thread & top thread need to be pulled to the back before starting the stitching
3. You need a ballpoint rather than universal needle to sew on t-shirt knits.
4. the needle is in the machine backwards
5. Make sure the needle is the correct one for the fabric being sewed
6. Needle inserted wrong in the needle holder
7. Warped needle
8. Warped bobbin
9. Also could be a timing problem
Mar 01, 2016 | Singer Sewing Machines
Just received a singer futura II model 920 which seems to sew just right. When I tried to wind a bobbin, I just can't get it done.
If it is a new machine, take it for warranty service. Sounds like perhaps something is misaligned with the release lever. In the meantime, a standalone bobbin winder can be purchased at JoAnn's, Hancocks, or Amazon.com for about $35 (helps reduce wear & tear on your machine).
It's very difficult to say whether it is worth the price of repair. On the other hand, what would you do with a machine that doesn't work? It could be something very simple that can be repaired for a small price, or it could be something expensive. (However, since you indicate it is only the bobbin winder that is faulty, otherwise the machine works with that one exception, you can save up to get the bobbin winder fixed.) FWIW, a standard check, clean & oil could cost around $100 (based on what I currently pay for my machines). However, you could ask what it would cost to fix the bobbin winder only.
From a search on eBay:
http://www.ebay.com/sch/i.html?_nkw=singer+futura+920
You can track similar machines and their sales prices to determine if it would be worth fixing your machine. Even if you don't, you can still purchase the standalone bobbin winder and continue to use the machine anyway. A working machine is better than none at all.
Feb 02, 2016 | Singer Sewing Machines
I need a manual for singer 7105
If when you put the bobbin in, you can't get the top thread to bring it up, your timing is off. That means that the hook that catches the top thread as it goes around is out of sync. If you have had no experience working with this type of machinery, I do not recommend that you try to fix it yourself; however, any sewing machine technician can fix it for you--it should not be expensive and doesn't take long, and it doesn't have to be a Singer dealer--hooks and how they work are standard for every machine. I believe that Sears will work on any machine. It doesn't require a replacement part.
Jul 01, 2014 | Singer 3116 Simple
Have a c-150 furtura ...i'm getting a bad stitch on the bobbin thread with both reg and embroidery stitching how do i fix this been in repair shop 3 times comes back with still bad stitch they use...
ANOTHER THING IS TO CHECK THE TENSION OF THE BOBBIN THREAD. MAKE SURE THE THREAD YOU ARE USING IS GOOD THREAD THAT DOESN'T PULL THE COTTON UP AND CAUSE A PUFF BALL ON THE NEEDLE. CHECK THE WAY YOU ARE LOADING THE TOP THREAD. ALWAYS DO THIS WHILE THE FOOT IS UP SO THAT YOU CAN CONTINUOUSLY GIVE TUGS THROUGH EACH OF THE GUIDES. THIS HAS TO BE LITTLE TENSION WITH NO SNAGS.
Apr 23, 2014 | Singer CE-100 Futura Computerized Sewing...
Singer model 640 needle hits metal in bobbin area on downstroke
Yep, it's out of time. Take it in for service. Ask for cleaning, lubing and re-timing. Otherwise they will just time it and if it is dirty and dry... it may just fall out of time again.
Also remember you can never turn the hand wheel backwards to the way it is intended to go... that causes this issue in some machines.
Aug 25, 2012 | Singer Sewing Machines
I think the timing is off on my singer 7430 -- it keeps breaking needles and I can see where the needle hits the bottom of the bobbin casing when it is in the fully down position -- any quick fix?
Drop-in bobbin?
Refer to the maintenance section of the manual for cleaning.
Raise the needle to it's highest position and remove the bobbin and bobbin case.
Clean the shuttle and replace the bobbin case, noting the graphic in the instruction manual for aligning the case into the shuttle.
Turn the handwheel to see if the needle now clears the outer edge of the bobbin case.
Mar 29, 2010 | Singer 7430.CL Computerized Sewing Machine
Singer Touch & Sew 7462 - Needle hits bottom of bobbin case
With the needle hitting the bobbin case , it sounds like it might be out of time. Which I am sorry to say is not an easy at-home fix.
Jan 17, 2009 | Singer 7462 Mechanical Sewing Machine
Needle & Bobbin out of sync
This description sounds like the machine is out of time. The needle should match up with a cut out section in the bottom of the bobbin area. If it is hitting, the timing has slipped, probably from sewing on a fabric that was too heavy for the machine.
Apr 22, 2007 | Singer 7466 Mechanical Sewing Machine
Sewing Machines Logo
35 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
