Question about Xerox DocuMate 3125 - Document scanner - Duplex - 8.5 - XDM31255M-WU
DM3125 skips pages
Put in papers to scan and it does not scan
How do I scan multiple pages into one pdf attachment. Currently only to scan one page at a time.
i think you have ADF put the paper in it
or if you scan from falt bed after scanning some drivers or program give you option after scan (scan more pages)
Aug 27, 2015 | Dell All In One Printer -photo 966
Why is the scan skipping part of the page?
Either you are putting the page in a wrong manner. Or you have to fix in your settings, before you start scanning on your computer. I am regarding to the scanning setting which are available on your computer. If its set to DINA4 (provided you want to scan a DIN A4 page) and you have put the page in the correct manner, then it should scan perfectly. Otherwise, the device might be defective. In that case you should consider contacting Customer Support.
Oct 02, 2014 | Fujitsu fi-5120C
Can i skip blank pages while scanning duplex with a 5080c using capture perfect 3.0?
There is option to skip Blank pages. You have to specify in terms of percentage, above which the scanner will save and discard images below the specified percentage.
S. Mohan, India
Feb 28, 2013 | Canon DR 5080C Path-Through Scanner
5010C scanner won't skip blank pages
We had this problem and discovered it was caused by a small piece on the glass. Once the glass was cleaned, the blank pages were skipped.
Sep 11, 2012 | Canon DR-5010C Scanner
How do I set up my scanner to scan multiple pages at once, without having to keep hitting the scan button. ( fi-6140 )
Hi, are you using Scannedallpro software? If so, press the batch scan setting button (2nd right after the white drop down menu). This will give you access to your settings. Select add, name your new profile appropriately, then select SCAN, Click SHOW CONFIRMATION WHEN NO PAPER IN ADF, then click on Detail Scanner Settings. This will take you to your options screen. Select either Duplex, for double sided or ADF Front side for single sided. You can choose to drop out blanks by clicking on the OPTION button at the bottoms of the screen, then JOB/CACHE, click the selection button for Blank Page Skip and choose the sensitivity. (I usually use a low setting). Click OK.
when happy with your settings click OK again, then apply.
Use your new profile to batch scan. The system will scan until the hopper is empty and should ask if you want to continue with the same batch scan, allowing you to add paper until the job is complete.
NB Always ensure you have selected Multi Page Tagged Image File Format as the system will not save your scan as one document without it.
Hope this helps!
Nov 10, 2010 | Fujitsu fi-5120C
My mp830 prints and scans fine, but it won't scan dual side. it scans the first side, then starts to pull the paper back the other way, but it only goes a little ways (1-3") then the paper stops, like it...
Close the inner cover, and press the OK
button to clear the error. The paper being
printed at error occurrence will be ejected
without printing the remaining data for the
ejected paper, then printing will resume from
the next page.
Oct 11, 2009 | Canon PIXMA MP830 All-In-One InkJet...
HP OfficeJet 6400 sorts pages automatically when scanning.
When you go to print make sure you have the print settings to "collate".
May 27, 2009 | HP OfficeJet 6210 All-In-One InkJet...
Xerox DocuMate 3125 - Document scanner - Duplex - 8.5 - XDM31255M-WU Logo
44 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Xeroxrep
Level 1 Expert
Philip Hughes
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
