Question about Dryers
Don't have money to buy new dryer timer ($85-$95). Can I just put a 220v timer between panel and 220 outlet?..
  • 3,103 Answers
There is an issue with the amperage load on the timer..most dryers require a 40 to 50 amp connection to work properly.. using a timer thats not as heavy rated will catch fire from overheating!!!!!dont want to burn the house down...
Posted on Jan 23, 2013
  • al Martin Jan 23, 2013
    Def need no fires!.. The tag on the dryer says 120/240v 60hz 28amps. Could I 'step down' to 110? Would that change amperage?
  • 4 Answers
SOURCE: Kenmore Dryer 697267
Most dryers are 220 so they can produce the amount of heat required to properly dry clothes. I would Not recommend trying to convert the dryer to 110 voltage. This may cause you alot of unwanted problems. I would find a Qualified electrician to install a 220 outlet at the location of the dryer .
Posted on Apr 26, 2008
AlmostBob
  • 550 Answers
SOURCE: Using dryer in 220V country
There are two systems in use in the states
110v dryers are available that fit a standard 11v 15a socket
110/220v fit the oversize 'dryer' sockets, and they are two 110v phases 90 degreees apart
the motor runs of a single phase 110v.
there is 220v between the 'outside', the active lines of the two phases, at any time, but it is not useable to provide mechanical power as a single service, due to the complicated shape of the wave form when you add out of phase voltages together, but is ok to drive the heaters, they have no mechanical efficiency requirement
A 2 phase 110v heater it means 3kw can be supplied without a 30 amp circuit
but it becomes difficult to use a single phase 220-240v transformer to provide 2x110v 90degree 2 phase current unless you specially buy one in. .
High power applications in 220-240v are generally supplied by 415v 3 phase 60deg supplies,
Any transformer would be onsellable at the end of your posting, to your replacement, who would doubtless be in the same boat as you, with a heap of 'stuff' that needs to run.
UK Aus NZ may be sources of transformers, or dryers to suit.
check with Australian UK NZ suppliers as well as local Indian ones, as those countries are also nominal 240v single phase home suplies and they may have (1) the dryer, or (2)the transformer to suit the 110 2 phase dryer
Posted on Sep 13, 2008
appldoctom
  • 311 Answers
SOURCE: 110 volt/amp dryer
yes ,i see some on line at living direct.its an Haier,they call it a portable.it was about 300$ and that included shipping.if you can't find .i googled 110 volt dryer and their was the link too [living direct] have fun,God bless,tom
Posted on Jan 23, 2009
Macmarkus
  • 2605 Answers
SOURCE: Asko W/D. Power to 220 wall outlet and washer
Hello paulehni, welcome to Fixya.
First things first, have you checked the 15amp fuses which are located at the back of your Asko dryer ?
**Turn off your breaker at the home service panel, it should be a 30amp switch**
That is where I`d start and focus your attention. They are at the back as I said located next to where the power cord exit`s the unit. Look for 2 small round slotted caps ( these are the fuse holders/hubs ) either black or gray in color.
With a flat screwdriver fitted in the slot of the fuse hub, turn it a half turn counter clockwise an it should drop out...though it may need to be pulled out if it`s stuck in the holder part.
Replace with a 15amp "slow blow" ( the only difference is the slow blow are filled with sand and aren`t transparent glass tubes but rather gray or white in color ) if the fuse is blown. You can find these fuses at most brick & mortar appliance part stores or on-line parts vendors such as repairclinic.com, amresupply.com, reliableparts.ca etc. Part number is #8058140 and you should replace both. The number may substitue to an in-store number, it really depends on the vendor, just provide your model number and you should have no trouble.
Hope that is helpful. If so please rate the solution accordingly, if not let me know what you find or if you require further assitance.
Thank`s for visiting Fixya today and good luck.
macmarkus :)
Posted on May 16, 2010
TheMobilian
  • 8220 Answers
SOURCE: Roper dryer model REX6634PQ0 doesn't
Start by unplugging the machine and take it outside if possible.
get the screws out and remove the rear cover
Go ahead and get the front off next so you can remove the blower housing
Take the filter out and a couple screws then grab the back of the control with
your left hand and use a putty knife to release the top on each side
That smaller fuse at the top blows with a blocked vent
8_17_2011_4_03_01_pm.jpg8_17_2011_4_03_15_pm.jpg8_17_2011_4_03_40_pm.jpg8_17_2011_4_04_15_pm.jpg8_17_2011_4_04_45_pm.jpg8_17_2011_4_05_01_pm.jpg
Service manual and videos are HERE
Posted on Aug 17, 2011
What is required to use it as far as electrical outlet.
Dryers come in both 110V and 220V.
If you plug a 220V dryer into a 110V socket, it will run very slow.
If you plug a 110V dryer into a 220V socket, it will burn up.
If you can find a 220V extension cord, then you should be able to use it.
Mar 08, 2015 | Dryers
110 volts philipps tv plugged into 220v outlet, a spark was emitted by the wall outlet to which the extension was plugged what happens now?
Now you go buy a new TV. The 220 volts will have burned out the power board that supports the TV and maybe some other components. Unless it is a very expensive TV, you are better off buying a new one rather than trying to repair the old one.
Feb 02, 2014 | Televison & Video
I am trying to hook up my stackable washer and dryer. I havee a 220 plug 30a what do I need to do so I don't have to go back to home depot and get whole new plug in and plug?
If the unit has a 30 amp/220volt plug, then you will need a dedicated 30 amp outlet from a 220 volt line from the panel. You can not switch the plug to work with a regular (15-20 amp) outlet. Have an electrician install a 10 gauge 220 line from the panel to the unit. good luck!
Aug 30, 2011 | Whirlpool LTE6234D Top Load Stacked...
ASKO 7000 series washer drum stopped rotating. Smelled of burning. Could not turn the drum by hand. Guessing a burned out bearing as electronics and pump still work and are trying to turn steel drum. ...
check inside your washer for nails or other objects . I already seen a nail fall down in one of the basket holes and the nail stuck into the outer tub not allowing the basket to spin. If you dont see anything in the basket holes, then it is your bearings. The burning smell is coming from your belt. The motor is spinning but your basket is not. It is cheaper to buy a new washer. In ordered to fix your washer you have to rebuild it. The bearing are built into the outer tub of the washer.
Jul 13, 2011 | Asko 8005 Front Load Washing Machine
I have a lg dryer with a 220 electric hook up plug and in my house there is only a 110 electrical outlet. is there any way I can just change out the cord to a 110 electric cord and use it?
No. the new dryers have to have a 220V power. You first have to replace or add a 220 outlet on the wall that matches the connector on the dryer.
Jun 26, 2011 | LG Dryers
What do you do if your out let for your house is only putting out 110 instead of 220 at the outlet.
Depends ... what is 'normal house voltage' where you live?
If you are installing a new electric dryer in the USA, typically, they operate at 220 Volts. If there is no special outlet at the place where you want to use the dryer, you will have to have an electrician install the proper gage wire and outlet for you. Expect to pay up to $200.00 or more for this installation from the house main panel to the dryer location.
If there is a gas line at the location, you may want to consider exchanging your electric for a gas model.
May 27, 2011 | Kenmore 700 6973 Dryer
Dryer will not start door is closed
Carefully check your 220 outlet. You can check a 220 buy a volt meter. Make sure your volt meter is set over 220 range and put the red lead into the slot and black lead into the L shape. It could be you are not getting 220 power out of your outlet. We all know on a 220 outlet both legs have 110 on each side. A dryer takes 110 for the motor, and takes 110 for elements.
Dec 03, 2009 | Estate TEDX640JQ Electric Dryer
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Does the Maytag LSE7806ACE require a 220 plug?
If you hook it up to 120 volts (by connecting L2[red] to common [white] the dryer will operate, but your heating element will only produce 25% of the heat it would on a 220v circuit. The drying time would be about 3 hours, and the auto dry setting may not work. Heat difference is about 5000 watts of heat on 220v, vs 1250 watts on 120v circuit.
Dec 19, 2007 | Maytag LSE7806A Top Load Stacked...
Re: no heat and timer not moving
  If the timer is set for a auto dry cycle,  the timer won't advance if not heating.  You need to check for 220 volts at outlet.  It's possible to have only 1 110 volt circuit.  May be a bad breaker. or outlet.  If you have 220 volts at outlet,  you need to have an ohm meter to check continuity of the thermal fuses and the heater.   Access by removing rear panel.  UNPLUG FIRST!!!!!
Oct 22, 2007 | Roper RES7646KQ Electric Dryer
Dryers Logo
67 people viewed this question
Top Dryers Experts
