Question about Dell TrueMobile 2300 Wireless Router (tm23003)
I lost my wep key
Can I get my wep key without changing or doing a reset? Thanks, I have a Dell truemobile router.
  • 68 Answers
What you can do i log into you router with the admin user go to wireless access settings and you would be able to see your WEP key, or if you want you can change it...!!
Posted on Jan 28, 2009
WAP/WEP password not working
These are the two options for your Router. Don't forget to save your settings
WPA is an upgrade to the WEP (Wired Equivalent Privacy) standard for securing your wireless network. If you would like to secure your wireless network using WPA, you will need the following:
  • WPA enabled on your Dell TrueMobile 2300 Wireless Broadband Router
  • WPA support for your wireless clients. If you are using a Dell TrueMobile wireless client, you can check for the availability of WPA enabled software update for your wireless client at http://support.dell.com.
  1. Log into the Web configuration of your router at http://my.router (or the default address http://192.168.2.1)
  2. Click on Basic Settings.
  3. Click on Wireless Security.
  4. Click on the Enable Wireless Security checkbox.
  5. Select either WEP or WPA in the Network Authentication list.
To setup WPA
  1. Enter your pre-shared key. This key must match the key that is used by each wireless client computer associated to your router.
  2. Choose a key format. This can be hexadecimal digits (0-9, A-F) or ASCII characters (any key on the keyboard).
  3. WPA Group Rekey Interval specifies how often the key rotates or changes.
  4. WPA Encryption allows you to select 1 of 2 possible encryption methods (TKIP and AES) - choose one that your wireless clients supports.
  5. Click NEXT, then Save and Restart to apply the changes.
  6. Setup the WPA on your wireless clients. Refer to the documentation that accompanied your wireless clients, or your wireless clients on-line help system for information on how to setup WPA.
May 14, 2012 | Dell TrueMobile 2300 Wireless Broadband...
I cannot remeber my security key. How do I find my security key
Have you ever SET a security key?
because if not it will probably have a factory default set, which it SHOULD tell you in your User Manual.
I'm not familiar with the Truemobile 2300 Router, but most routers either have a reset button of the back or bottom of the case, or their may be a hole marled "reset" that you can poke a cocktail stick or simular (non-conductive) object into the hole to reset it, this MAY set it back to Factory default and wipe any security key, There again it may not.
If no good, Have a look at:-
http://search.euro.dell.com/results.aspx?s=gen&c=uk&l=en&cs=&k=Truemobile+2300&cat=all
Jan 30, 2011 | Dell TrueMobile 2300 Wireless Router...
I am trying to enable my WEP encryption. My Dell TrueMobile 1184 help guide asks me to open my web browser to http://my.router. When I click on that the Connecto to my.router dialogue box appears and...
The default username and password are both admin short for (administrator) now if you configured the router previously and added a password and forgot it you could always reset it from the reset button located in the back of the router hold it in for 30 seconds and wait 1 minute for the router to boot up only if the password admin does not work (I hope this helps have a good day)
Oct 02, 2010 | Dell TrueMobile 1184 Wireless Broadband...
I entered a WEP encryption key onto my Dell TrueMobile 2300 router, but when I try to connect to it wirelessly (and put in the correct key), I don't get any connection to the internet. It works fine when...
Dear Friend,
You must be trying the WEP -OPEN.
try WPA-PSK and put in your customized password.
Before making any changes in the system remove all the cables from the router and reset the router once and try to configure the network with WPA- PSK.
It should work.
If negative plz contact your ISP
Thank You
Prasanth83
May 11, 2010 | Dell TrueMobile 2300 Wireless Broadband...
I have a dell 1180 truemobile USB wireless adapter and does not sem to coneect to my AT&T U verse. has WEP key enter and U verse has a WPA key. are these incompatible? How can I make it work
if the adapter wont do WPA then yes it is incompatible. You will have to logon to your modem/router and change its wireless settings to WEP
please give details of your router/modem etc if you need help with this
Jan 15, 2010 | Dell TrueMobile 1180 802.11b Wireless...
I HAVE AN OLDER TRUEMOBIL 2300 WIRELESS ROUTER WERE ARE THE KEY CODES TO MAKE IT SECURE OR DO I ENTER MY OWN AT RANDOM?
You can secure your wireless network wit WEP or WAP code.
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
For belkin router http://192.168.15.1
or
http://192.168.2.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings then enable WEP Security then add WEP code .It is your password to connect wi fi.Then save settings and restart router.
Then you can connect your wi fi network with that code.
Thanks for using FixYa.
Dec 22, 2009 | Dell TrueMobile 2300 Wireless Broadband...
Wireless security
the WEP password is located on the label on the botom of your router. The WEP password prevents unotherize conecting to the network. If some one for example like your naber see your network and conects to but put in the wrong WEP they will not be able to use your internet.
Jan 04, 2009 | Dell TrueMobile 2300 Wireless Broadband...
How do I set up a password to secure my wireless network??
Enabling the WEP for the Dell TrueMobile 2300 Wireless Router
Click the Start button.
Click All Programs.
Click Internet Explorer.
The Internet Explorer browser window appears.
Type the following in the Address line:
192.168.2.1
Click the Go button.
You are prompted for a Username and Password.
Type the following as your username:
admin
Type the following as your password:
admin
NOTE: If you previously changed your administrator password in the advanced settings of the router you will need type the password that you set.
Click the OK button.
The Dell TrueMobile Setup Page appears.
Click the Basic Settings tab.
Click the Wireless Security button on the left side of the page.
The Wireless Security window will appear.
For the highest level of security choose the 128 Bit encryption option.
You will have to type a name for your encryption key in the field to the left of the 128 Bit option.
Click the Save and Restart button on the left hand side of the page.
The Save and Restart window appears.
Click the Save and Restart button.
Your settings will be saved to the router.
More Secure
Configure the 2300 Wireless Router for WPA-PSK with TKIP Encryption.
Double-click on Internet Explorer.
The Internet Explorer window appears.
In the Address Bar type my.router or the default IP address 192.168.2.1.
Press the <Enter> key or click Go.
The TrueMobile 2300 password window appears.
Type the User Name and Password.
NOTE: The default user name is admin and the default password is admin.
Click OK.
The TrueMobile 2300 Wireless Router configuration window appears.
Click Basic Settings.
Click Wireless Security in the left-hand pane.
Click to select Enable Wireless Security.
Under Network Authentication, select WPA (Wireless Protected Access) from the drop-down menu.
Input a network key or password in the field to the right of WPA Pre-Shared Key.
NOTE: Your network key or password can use 8 to 64 characters using Hexadecimal digits or 8 to 63 characters using ASCII characters.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 02, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Setting passwords on dell truemobile wireless router
Hello, The default address for the dell truemobile 1184 is 192.168.2.1 If you have changed it and forgot, unplug the router (elec) for 5 seconds. This will reset it to default. The default SSID is "wireless". If a user ID and/or password is asked for enter "admin". Here you can change settings, enable broadcast, change SSID, enable WEP or WPA. Hope this helps.
Mar 16, 2008 | Dell TrueMobile 2300 Wireless Broadband...
Dell TrueMobile 2300 Wireless Router (tm23003) Logo
499 people viewed this question
Alun Cox
