Question about Technics Audio Players & Recorders
Need covers for technics rp-f295 - Technics Audio Players & Recorders
What is the universal remote code for an RCA RP-9316 Audio system?
Please let me know what brand your universal remote is and the model so I can further help you. Usually, there is a sticker under the battery cover that tells you what model it is. I would be glad to help.
Sep 16, 2014 | RCA RP-9316 Boombox
I have a rp-dj1200 headset, right side ear not working, pulled apart & 5 wires 2 copper colour, 2 red colour 1 green - 1 copper wire (not far outside)has come off. I need to know where to solder this...
there must be a disconnected wire ....
first of all you need to go to a qualified hardware repairer...then you need to pay him and get the work done because i don't know where you live!
Jan 14, 2010 | Technics RP-HP1200 Headphones
Rca model # RP 50128 need manual
I need a manual for RCA Digital voice recorder Model 3 Rp 50128
Aug 19, 2009 | RCA Audio Players & Recorders
Technics headphones RP-DJ1200
You can buy replacement plugs and solder them on. Make sure you take the old one to the store when you purchase the replacement. The next thing you need to do is figure out which wire goes to which part on the plug. You can us a volt ohm meter to test the old plug and see which color of wire or which color of wire insulation matches to which part of the plug. You can also try taking the foam pad off the left earpiece and look to see if you can get the speaker plate off the earpiece. Once off you can look to see which color goes wher. There will be another wire there that connects the right earpiece to the left one. Make sure you unscrew the shield from the plug and put it over the cord facing the correct direction before you solder the plug to the wiring. Screw it to the plug after. Hope this helps.
Jul 10, 2009 | Technics RP-DJ1200 Professional Headphones
Technics RP-DJ1200A's left speaker disconnection
If you try carefully removing the foam ear pad you might be lucky enough to find that the speaker plate is screwed to the backing cup. I hope this is true in your case. Some of them are just glued together. Hope this helps.
May 27, 2009 | Technics DJ Headphones
I recently bought a pair of Headphones in the UK, DJed one gig, went to use them on the plane home and and with the use of an adaptor wouldnt work I checked the jack and it snapped off, Do I need to get...
You can use any jack as a replacement. You won't affect the quality, unless you wire it incorrectly, or you buy a very cheap jack. Gold plated won't do much difference in regards to quality. It will not be noticeable, but will look pretty!
- TERMiNAL OPTiC
www.DJPROLAB.com
Apr 15, 2008 | Technics RP-HP1200 Headphones
199 people viewed this question
Top Technics Audio Players & Recorders Experts
 Grubhead
Grubhead
T-Comtech Repairs
T-Comtech Repairs
Electro Med Services...
Are you a Technics Audio Player and Recorder Expert? Answer questions, earn points and help others
