Question about Leica Laser Alignment Lb-4 Dual Grade Slope Laser
CALIBRATE LASER ALIGNMENT LB4 - Leica Laser Alignment Lb-4 Dual Grade Slope Laser
  • 3 Answers
Depends on which microprocessor it has inside
Posted on May 30, 2015
Can you inform how i can calibrate laser level alignment lb 4
Posted on Jan 15, 2014
  • jose
    jose Jan 15, 2014
    can you inform how i can calibrate laser level alignment lb 4
Colour out of alignment on aficio c811dn ricoh.when i print a demo page,the colours are out of alignment.
The transfer belt is not calibrated or the ID sensors are dirty. Read the user manual on how to calibrate it. No manual? Go to ricoh-usa.com
Sep 29, 2014 | Ricoh Aficio SP C811DN Laser Printer
I need manual for lb4
It will show Battery Protect when;
1-There are no batteries in unit.
2-The batteries are fully charged.
3-Alkaline batteries have been installed and charging is attempted.
4-The batteries are bad.
Sanyo 4400 Ni-Cads assembled in brick pack form, the Ni-Cads normally last 3-4 years and need replacement. This is an older unit that is obsolete with few parts available but there are after-market battery assemblers that can make them up just Google it.
Aug 27, 2012 | Leica Laser Alignment Lb-4 Dual Grade...
I have laser printer hp 3525 and printer don't mix colours properly so letters are to be printed green the yelow color print seperate and the blue seperate ,so the the print come with two letters as if...
> go to menu, apply set of default setting, then check..> go to menu, device setting,quality,calibrate color,calibrate now.. printer performs color calibrate, after completion, check the print quality. I hope it will resolve the issue.> if above said advises are not resolved the issue mechanical adjustments has to done which is not suggestible to the users.. only professionals can perform the activity.
Oct 05, 2011 | HP COLOR LASERJET CP 3505 N PRINTER
Printer colour alignment out. How do it align this?
CALIBRATE THE PRINTER
Use the menus
1. Press OK to open the menus.
2. Press the Left arrow ( ) or Right arrow ( ) button to navigate through the listings.
3. Press OK to select the appropriate option. An asterisk (*) appears next to the active selection.
4. Press the Back arrow ( ) button to scroll back through the submenus.
5. Press X to exit the menu without saving any changes.
Color Calibration
? Power On Calibration. Specify whether the product should calibrate when you turn it on.
? Calibration Timing. Specify how frequently the product should calibrate.
? Calibration Mode. Specify the type of calibration the product should use.
? Normal
? Full (slower)
Full calibration improves the color accuracy of photos printed on 100 x 150 mm (4 x 6 in)
HP Color Laser Photo Paper.
? Calibrate Now. Set the product to calibrate immediately.
NOTE: You must click Apply before your changes take effect.
Jul 18, 2011 | HP LaserJet CP1515n Printer
I need to calibrate my hp deskjet 3845 but when I click the button to calibrate it says it's lost communication with the device
Hello
Calibration is one of the functions performed from the Printer Assistant icon on the desktop. If the Printer Assistant icon on the desktop has been deleted from the system, the same tasks can also be accomplished from the Printer Toolbox . The Printer Toolbox can be accessed through the Printer Folder or by right-clicking the Printer Icon on the Taskbar
Please follow these steps to calibrate your printer
Double-click the Printer Assistant icon on the desktop. The Printer Assistant menu will appear with a list of options
Select the Tools and Updates option or the Utilities option (depending on your driver version).
Printer Maintenance menu will appear.
Select the Calibrate Printer tab from the Printer Maintenance options
Click the Calibrate tab. The printer will print the first calibration page.
In the Cartridge alignment page, please inspect the straight colored lines in Sections A, B, C and D . Choose the straightest lines in each section to indicate the best cartridge alignment.
In the Page alignment area, please verify Section E . Then, select the bar and the arrow closest to the edge of the page without being cut off, to indicate the best page alignment.
In the Calibrate Device window, enter the selected alignment values in the Pen Alignment and in the Page Alignment fields and click the Continue tab
The second calibration page will be printed now. The page will contain two patterns: a square and a cross . The lines on the patterns should be horizontally and vertically aligned . Click the Done tab if the lines are correct or the Calibrate tab to repeat the calibration process
The first calibration page contains five sets of alignment patterns. The calibration will cover two areas of alignment. The Cartridge alignment is designed to obtain the best print quality and the Page alignment is designed to ensure that the print is aligned correctly on the page.
If the Printer Assistant and its files have been deleted from the system, the maintenance features in the Tools and Updates section of the Printer Assistant are also available in the Printer Toolbox .
Open the Printer Toolbox and perform the services by following the instructions below:
Right-click the Printer Icon on the Taskbar .
Click Open the Deskjet Toolbox option.
Select the Printing Service tab in the Printer Toolbox .
Choose the Calibrate the printer option.
NOTE:HP recommends to use HP plain paper when performing the cartridges calibration process.
NOTE:These printers could work with one or two print cartridges. HP recommends to perform the cartridge calibration process with the two cartridges installed in order to get the best print quality. Anyway, the printer can also be calibrated with one cartridge installed if the customer decides to work in that way.
Jan 16, 2011 | HP Deskjet 3845 InkJet Printer
Print cartridge alignment failed.
Check the following steps :
Double-click the HP printer icon in the system tray at the lower right end of your desktop. Navigate to the "Toolbox" tab.
Click on the "Status" link on the left side of the window. Scroll through the "Status" menu and click on the "Print Info Pages" link.
Click the blue "Print" button located to the right of the "Configuration Page" heading. Check the print page to see if the "L" shaped bars are overlapping or bleed into each other.
Contact HP directly for a repair or replacement if the "L" bars do not have any overlap, as that will indicate an extensive mechanical problem that can't be fixed through troubleshooting.
Return to the "Toolbax" tab if the color bars are overlapping. Click on the model number of your HP color laser printer at the upper left end of the window. Click on the "Device Settings" link.
Choose the "Print Quality" option and then click on the "Calibrate" button on the right side of the window. Click "OK" in the new window that appears and wait for the alignment calibration process to finish.
Attempt to print a document again and see if the alignment is still off. If the alignment is not correct, repeat the calibrating, since the HP color laser printer may need to be calibrated more than once to fix the alignment.
Nov 08, 2010 | HP Photosmart C5180 All-In-One InkJet...
The Black prints faint on the left side of the page for our HP2605dn printer.
Faded prints are possible due to following reasons.
1. Fogged red mirrors inside the Laser box
2. Alignment of the Laser Box
3. Calibration Problem
4. Cleaning Problem
I will guide you with simple steps first, if this dosen't work working with laser box is little tough & time consuming, hence will describe later.
To Calibrate the colors, Press the 'Green Button' in the front panel, use the arrow keys to navigate through menu.
Select 'System Setting' by pressing the green button again, navigate using the arrow keys and select the 'Calibrate Color', select green button to select and confirm to 'Calibrate Now'. This will take few minutes.
In addition to that, to clean the paper path, select the green button and use the arrow keys and navigate thru' menu and select 'Service'. select using the green button and navigate through menu and select cleaning option. This will take few minutes.
Try printing some documents and check whether you have fixed. If you have not got the original print quality, Let know to guide you more technically.
Jun 08, 2010 | HP LaserJet 2605DTN Color Printer
LaserJet 2605dn Printer: HP Color Laser Jet 2605 printer far left side blac...
4. Cleaning Problem
May 17, 2010 | HP LaserJet 2605dn Printer
I need to calibrate rotary laser DW073
Sounds like you figured this out on your own. I calibrate my own DW073 regularly without any fancy gadgets. I use the calibration check procedure in which the unit is placed about midway between fixed objects 100' apart.
These have a front and back and sides, so first you mark where the laser hits facing front to back at your targets. Then turn it 180 deg. relevel and resite. If the difference between the new and old marks is not the same then I turn the adjuster to halve the inconsistency and once that is accomplished, tweek the adjusting screw at the end of the level vial. (Because if you have adjusted more than the tiniest bit, the bubble will no longer display as level. So having established level, or closer to it, the adjustment here is actually to bring the relevant bubble vial back to level rather than assume they are level and adjust the physical beam mechanism (unlike the old physical sight levels where you adjusted the actual optics -- a little more like adjusting a rifle scope). Then you repeat for the side to side vial.
Anyway sounds like you are set so I posted this for anyone who happens to find this thread and is looking to field calibrate their DW073, e.g. don't have time or money to get it done in some shop.
I also wanted to post an add on question. Did you figure out how to adjust the "cone error", i.e. the accuracy of alignment of the twin lasers. They appear to have allen set screws that lock their adjustment, and maybe they are then reaimed by using a slotted screwdriver on the brass ring surrounding the laser. Maybe these are made eccentrically or slightly beveled so turning the laser reaims.
So far, my cone has stayed within the specs of 3/32" at 25' in the manual. But I'm seeing two lines at maybe 150' out. Probably that is close enough for gvmt. work, and I may find the adjusment so sensitive that I can't really get it any closer. But I'd at least be interested to know the method for adjusting the cone error.
Thanks,
Brian
Feb 15, 2009 | Dewalt DW077KD T Self Leveling Rotary...
CDJ Laser Alignment/Calibration
They dont normally go out of focus, any trouble reading discs / freezing is usually caused by a worn out laser which will require replacement.
Jul 22, 2008 | Pioneer CDJ-1000 CD Player
Leica Laser Alignment Lb-4 Dual Grade Slope Laser Logo
936 people viewed this question
Top Leica Measuring Tools & Sensors Experts
Vuk B
Tom Chichester
Are you a Leica Measuring Tool and Sensor Expert? Answer questions, earn points and help others
