Question about Uniden Lands Phones
Connect my Uniden DHS100 headset with Uniden 1785 phone
I can't get my new Uniden DHS headset to connect with my new Uniden 1785 phone. Can you help?
4 Suggested Answers
  • 84 Answers
SOURCE: The headset for my Uniden EXS 9650 Cordless
Hi, a simple way to determine if the problem is in your headset or in your phone itself is to try the headset on another telephone. If you do not have another headset compatable telephone, you can try taking the headset to a local radio shack (or other electronics store) and see if they will test it on another phone for you.
Posted on Apr 28, 2009
SOURCE: can you buy headsets seperately for th uniden
yes just purchase a Plantronics M175 headset, a lot better than the one that Uniden offer.
Posted on Dec 16, 2009
  • 50 Answers
SOURCE: Recently purchased a new Uniden
What is the product code?
Finding the product name/model number. transpix.gif
Finding the product name/model number:
  1. Look on the bottom of your phone for the serial number sticker.
    (If you have a multi-handset unit, it will be on the main base.)
  2. The product name is in the top left corner of the sticker, above the bar code:
Honestly, i know your hate this response but read through the instructions and re-wire it by what the instructions say. Step by step. if you dont have the manual...respond back and i can send that to you.
Posted on May 09, 2011
What is right size plug for corded headset for Uniden 6.0 cordless phone?
The cordless phone headsets use a 2.5mm plug.
The larger 3.5mm plug is used for the PC or
laptop computer headphone connections.
The model number for your cordless phone is
on a small sticker under the battery inside the
handset. Entering this number at
www.manualslib.com will allow you to
get a free copy of the original owners' manual.
Feb 01, 2016 | Uniden Cordless Phone
How to connect an HS 950 headset to Uniden DECT 9135
(I presume you have checked the headset is fully charged and powered on.)
Together with pressing "Find Headset" on the phone, you also have to press and hold "VOLUME +/-" for 5 seconds on the headset.
When the connection is made the headset LED will flash blue every 10 seconds.
I hope this helps.
May 11, 2014 | Uniden DECT 6.0 Cordless Phone ID
How do I fix the speakerphone on a Uniden dect 6.0
check headphone socket, clean & some heating. or" find switch connection & that have short pin & open it.
May 29, 2012 | Uniden DECT 6.0 Cordless Phone ID
Uniden cordless phone model TRU 9466 3.5mm to 2.5mm adapter
Hi Ted,
I'm looking for a solution to a similar problem. I found this adapter that might help you: <http://www.theheadsetbuddy.com/pc-computer-headset-to-uniden-phone-adapter/>I can't vouch for it first-hand since I haven't used it but am about to purchase it. It looks like you should be able to use a headset or separate headphones and microphone with it.
--Tom
Nov 25, 2011 | Uniden TRU9466 Cordless Phone
Having issues syncing my Uniden BT112 Bluetooth to my BlackBerry Bold. I used this Bluetooth with another telephone and don't have any of the old packaging. I don't have a pin number. Help!
Please follow the correct instructions below to successfully pair your headset with the phone.Make sure that the headset is sufficiently charged before pairing.
Charge the battery
Before using your headset, charge the battery for at least 8 hours. Charging the battery completely (and keeping it charged) will help you get the longest possible talk and standby time out of the battery.
Pair the headset to your Bluetooth phone
Pairing is like "introducing" two Bluetooth devices and giving them permission to connect to each other. If you want to use the headset with more than one phone, you need to pair it with each phone separately. Once a phone and the headset are paired, they can connect automatically whenever they detect each other.
1. Make sure the headset is powered off and the power adapter is not connected (you can't use the headset while it's charging).
2. Press and hold Power until the LED flashes alternating red and blue. The headset is in pairing mode and should be visible to other Bluetooth devices.
3. On your phone, start a search for Bluetooth headsets or handsfree devices. (This process may take several seconds, and it will be different for each phone; see your phone's manual for detailed instructions.)
4. Your phone should discover a device called a BT108, BT108 headset, BT109, or BT109 headset, When your phone asks if you want to pair with this device, answer yes.
5. When your phone prompts you for a PIN code or password to pair with the BT108 or BT109 enter 0000.
6. When the headset is paired, the LED turns blue and flashes every 3 seconds. Your phone might display a confirmation message, also.
7. Your phone might ask if you want to change the headset's name; generally, you should only change the name if you have more than one BT108 or BT109 headset that you use with this phone.
Connecting to your phone
Most phones connect to the headset as soon as you pair it; if yours won't, turn the headset off and back on. If headset still won't connect, check your phone's owner's manual for additional Bluetooth information.
Once the headset is paired:
Whenever you turn the headset on, it will automatically try to connect to whatever device it was connected to last.
If the headset loses the connection (e.g., if your phone is out of range), it reconnects automatically. To manually reconnect, press Power.
If the headset goes more than 1 hour with no connection, it automatically turns off.
If you need further assistance please leave me a reply.Hope you are satisfied with my solution.Your valuable feedback would be appreciated.Thanks for choosing Fixya.
TinuAlbinAlex
Jun 15, 2011 | Uniden BT-108 Bluetooth Headset
Does this device bluetooth aeon BTK-A20 work on all mobile phones or just nokia ones and if so how do i get it to work?
How to Pair (Connect) a Bluetooth Headset to Your Phone
So you've heard of this new thing called "bluetooth..." But what is it? ...And what does it do for me? It's wireless technology that can link your phone to a headset, computer, another phone, or in extreme cases, your car and home.
We'll just start with the basics and connect a headset to the phone
Instructions
Things You'll Need:
* A Bluetooth cellular phone
* A Bluetooth Headset
Blue tooth can simply be called "a generic wireless technology that can connect your phone, computer, headset, PDA, laptop, and any other enabled device to each other."
In essences, it was designed to be a universal wireless connector between devices.
Ok... Here we go.
Make sure that both your phone and new headset are charged up.
Since every brand of headset is different, please refer to the instructions for "Pairing", but I will tell you how the most common headsets pair.
By the way, "Pairing" just means "connecting". If you find it more simple, you can substitute the word.
On most headsets, from the Headset being off, hold down the answer/end button down until the indicator light(s) glow a solid color (usually blue). This may take up to 10 seconds. They might flash first, then after a couple more seconds, go solid on.
On your handset, find the bluetooth menu.
On most phones, go to the settings menu, then to "connections" and then "Bluetooth". You are looking for a link to "Add a new device".
On Motorola phones, it is in the "Handsfree" link. Select [look for new device] select this option, and hit "OK".
Nokia Phones: look for "search for new audio enhancements". Hit OK.
On Samsung phones: **Bluetooth menu might be under "tools"** Look for "Add new device". Hit OK.
The phone will search for a couple seconds. If your headset is in paring mode, it will show up on the phone either with the name of device or something like this [unknown headset] or [b2.c3.f4.56.a1] (called a MAC address).
Either way, select it, and hit OK.
The phone will now ask you for a "Pin" or "Passcode", which is a 4 digit number. Headsets will ALWAYS have 0000 (four zeros) as a pin or passcode. I have never encountered a headset with a different number as a passcode. I have been in wireless for 10 years, and still have not found a headset that has any different numbers.
Enter these four zeros and select "OK"
The headset and phone will connect to each other. The phone will display a message that will be something to the effect of:
"Connected to headset".
At this point, the phone MAY ask if you want to use the headset. This means all audio from phone calls would be routed to the headset rather than in to the phone's speaker or earpiece. Select yes, or ok.
Your headset is now set up for you to talk on like a REALLY important CIA agent or something of the like...
Keep in mind that when a call comes in, the phone will still ring like normal.
You can answer the call by either:
1. Pulling the phone out of your pocket and hitting the answer button.
2. Touching the answer/end button on your headset without reaching for you phone.
The range of your headset is up to 30 feet, in a direct line of sight.
If you go into another room, your range may be decreased.
If you do happen to go out of range, the call will be transferred back to the phone, and as soon as you are in range again, touch the answer button on the headset to let the phone know you're back in range. It will re-transfer the call back to the headset.
If you turn off the phone, or headset, you can repair them again simply by going to the bluetooth menu and selecting the headset again from the list. It will reconnect without a pass code and you are up and running again.
*** Please note that you do not have to hold down the answer/end button on the headset until it goes a solid on again.
Tips & Warnings
If you have difficulty, please feel free to contact me and I'll help you get things sorted out.
May 24, 2011 | Cell Phones
Can you buy headsets seperately for th uniden
Dec 13, 2009 | Uniden Cordless Phone
The headset for my Uniden EXS 9650 Cordless Telephone is tempermental & needs constant adjusting to maintain connections with the caller. Do I simply need to purchase another headset or is something wrong...
Apr 26, 2009 | Uniden Cordless Phone
My mic doesn't work; callers can't hear me
I don't have the answer but have the same problem. Uniden tech support had me disconnect power, etc. to no avail. Next solution was "replace the unit". I'm looking for a two-line phone with no answering device - use voice mail. Any ideas?
Mar 14, 2009 | Uniden TCX905 Cordless Accessory Handset...
Lands Phones Logo
Top Uniden Lands Phones Experts
k24674
Are you an Uniden Lands Phone Expert? Answer questions, earn points and help others
