WWA5600SBLWW loud noise like a belt broke
Loud clanging noise, maybe a belt broke?
  •  Margaret Shields
    Margaret Shields Jan 26, 2013
    Thank you for your help, appreicate! Found my belt began to shred like a piece of a rubber band, bought a new one for $10- am going to try this first. Could there be a reason for this? I do realize this is an old machine, but it works pretty good. thanks Margaret
  • Washing Mach... Master
  • 17,130 Answers
It is so common that the washing machine can make terrible noise in many ways and is a common fault. In all occasions it is important that your observation is most important and so is vital to the identification /rectification and solution. If you have noticed that machine is vibrating when it is running then the motor /drum suspension has to be inspected. Since these fittings are located on the underside of the machine it is important that you look for the noise with a good inspection lamp. Manually turn the motor and drum and listen for the noise, if so the motor bearings, the drum agitator shaft and fittings must be checked. Also the suspensions which include the shock absorbers and springs, the body clamps must be checked to be in correct alignment and not changed in position. Tightening of the mounting is also very important. Finally in most cases a drop of OIL or smear of grease on the moving parts cane solve most issues.
Check this link :
http://www.espares.co.uk/advice/washing-machines/a/7/1210/wobbly-washing-machine-or-tumble-dryer.html
For replacement of bearings check for tips on this visual link: http://www.espares.co.uk/advice/washing-machines/a/7/1401/how-to-replace-the-bearings-on-a-washing-mach.html
Posted on Jan 24, 2013
SOURCE: maytag spinning loud noise
bearings are bad need to replace
Posted on Mar 14, 2007
watugot
  • 290 Answers
SOURCE: Kenmore Washing Machine 70 series
You most likely have a broken coupler between the motor and gearcase.
You can buy the part for about $10 or have someone come out and replace it for about $150-200.
If you will post the complete model number from the the washer so I can see which style cabinet you have, I will try to walk you through the repair. It isn't very complicated if you are handy with home repairs.
With the age of the machine it probably just needs a coupler, but it could also have a problem in the transmission or basket drive that has caused the failure.
Posted on Nov 13, 2007
  • 1028 Answers
SOURCE: Very loud on spin cycle
yes ..bearing on upper side of gearcase has gone bad probably from a water leak from tub seal
Posted on Jul 20, 2008
onthejob5130
  • 640 Answers
SOURCE: spin cycle very loud,
spin surpport defective,,,this part is under warranty,,lifetime warranty..contact whirlpool for replacement of spin basket,,onthejopb
Posted on Feb 07, 2009
garing
  • 998 Answers
SOURCE: LOUD CLANGING EXCEESIVE NOISE DURING SPIN CYCLE.
i would think the bearing
Posted on Aug 10, 2009
Loud noise coming from my engine on my van 98 ford windstar 3.8L
Maybe it,s Cracked or Broke in ther picture say,s Lot,s or the Harmonic Balancer is Loose too or Broke Get back too Me On This Please
Apr 07, 2013 | 1998 Ford Windstar
02 4x4 olds bravada makes loud clanging noise when turning wheel
Have your CV boots and half shafts checked. If these are cracked, they will dry out and cause a lot of noise when turning. Also check your swaybar links, these cause a lot of noise also, but not only while turning.
Feb 10, 2012 | 2004 Oldsmobile Bravada
Very loud clanging noises started while driving
Try to remove the belt for the ac and see if you still hear the noise, as it sounds like you may have blown the seal or bearing out of the ac compressor , not sure just a guess.
Mar 13, 2017 | 1984 Chevrolet Corvette
How do i change an oil filter for a chrysler voyager 2000 and everytime the engine is running their is a loud clanging sound which gets louder evertime i push down on accelerator what could this problem...
remove the serpentine belt, then start the engine and listen for the noise. if the noise is gone. then you have a accessory going bad. ( i.e. ac compressor, water pump, belt tensioner, idler pulley...etc..)
Oct 24, 2009 | 2000 Chrysler Grand Voyager
My Maytag gas dryer makes a loud rattle and clanging noise.
Prob. some failure of a bracket or loose inside...
Have a local tecnician check it out.
i think that ll be best cause i can't imagine that will be an easy fix.
I hope this is useful, and greets,
Olivier.
Oct 21, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Loud clang, no power, no go.
Sounds like you may have lost your drive gear key
Jul 07, 2009 | 2004 Harley Davidson XL 1200 R Sporster...
Loud squeaking noise
dont spray that on the belt lol that stuff is flamable i think lol you most likely have bad phelt glides  they are pads that sit between the drum and the drum support and when that wears out it squicks or maybe you have a bad idler pulley which is what holds the belt maybe its rusty or something but most likelt its the pads
Jun 09, 2009 | Maytag MDE6000 Dryer
Water dispenser and ice maker
you got it replace the water inlet valve but make sure it is bad first ...................The loud noise you hear maybe caused from too much pressure on the valve turn the pressure down a little and try again
Jan 10, 2008 | Kenmore 53642 / 53644 Side by Side...
Washing Machines Logo
48 people viewed this question
Top Washing Machines Experts
