Question about Toshiba Satellite A105 Notebook
Replace DVD/CD drive on Satellite A105 notebook.
I would like to know if I can replace the CD/DVD drive by accessing the removable panel underneath, the way I was able to replace the hard drive.
    Problem Solver:
  • 7 Answers
Ther is probably a single swcrew that releases the entire DVD/CD drive and it pulls out. Check your owner's manual or go to Toshiba's website and download the repair/trouble shoooting/owner's manuals and they will tell you exctly what to do.
DELLS usually have a screw insode of the memory access plate or under the battery after it is removed, but I odmn't know where they are on Toshibas.
Don Jones
Posted on Jan 28, 2009
How to factory reset my Toshiba Satellite A105-S4384
Put Recovery Disk 1 in the CD/DVD drive, then power off your computer, unplug everything from the unit including the AC, remove the battery, press and hold down the power button for 30 seconds, replace the battery and then AC, power on, at the Toshiba logo screen press 'F2' to enter the BIOS Setup, in setup press 'F9' to load setup defaults, press 'F10' to save and exit, now at the Toshiba logo screen press 'F12' to enter 'Boot Sequence', with the up and down arrow keys to select 'Optical Disk Drive' or 'DVD/CD Drive', you will then see 'Press any key to boot from CD/DVD drive...' with the dots counting down, press any key before the count down finishes. Assuming you get back to the Toshiba Recovery Utility menu, select the 'factory default' choice, and return your unit to its out-of-the-box state.
Jul 01, 2014 | Toshiba Satellite A105-S4384 Notebook
A105-4034 toshiba my dvd/cd drive is not working from a wrong driver update i need the right driver so i can update it
Hello.
Go to Control panel \ system \ hardware tab \ device manager \ select DVD CDROM drives
Here click + symbol to expand. Right-click \ select uninstall driver.
Now close all & restart laptop.
Windows will find & install the best driver for your DVD drive! It'll work fine.
Please send us your vote & feedback to motivate us. Thanks.
Feb 19, 2010 | Toshiba Satellite A105-S4034 Notebook
Need to replace dvd rom drive.toshiba satellite a105
u can pull out the DVD drive by clicking the button at the bottom of the laptop...then inset the new one...just it will click in it's place when u inset it...
Dec 17, 2009 | Toshiba Satellite A105 Notebook
Cd-rom
Do you mean how to eject the CD from the laptop?
You just have to press a button on the CD-drive itself to release the CD.
If you need assitance, please post back more info regarding the problem.
Aug 14, 2009 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 PC Notebook, DVD/CD Drive. The Drive is reading the DVD but not the CD. How do I change the settings for the drive to read both
You can't just change it from pio to udma. Go to Control Panel, System,Hardware,Device Manager, then expand IDE ATA/ATAPI, then right click on Primary IDE and select uninstall. Do the same for secondary IDE. Then just reboot your system, and it will autodetect all IDE devices. After that when you check, you should not have any devices in PIO, and your burner should work correctly. If not, stick it in a hyperbaric chamber for 2 days and see if that helps. smile.gif __________________
Jul 12, 2009 | Toshiba Satellite A105 Notebook
How to change hard drive in Toshiba Satellite Notebook
Underneath the notbook should be a compartment to access the drive. It should be held be a couple of screws. Make sure the power is out before removing the drive. Look for one that has the same interface as you are replacing. It could drain the battery life of your notebook a little fast but if you already have a 92 gb and your doubling the size of it, it will be a slight drain to it.
Aug 31, 2008 | Toshiba Satellite A105 Notebook
How to replace cd/dvd rom in Toshiba notebook Satellite A105-S1014
Steps for Removing and Replacing the Optical Drive
Steps 1 - Remove the battery
  • Slide and hold the battery release latch to the release position.
  • Lift the front edge of the battery and remove it from the battery bay.
Step 2 - Remove the optical drive
  • Remove the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
  • Use your finger to grasp the edge of the optical drive bezel and slide the optical drive out of the base enclosure.
Step 3 - Replace the optical drive
  • Insert the optical drive into the base enclosure until the connector is seated.
  • Replace the 7 mm P1 Phillips-head screw that secures the optical drive to the bottom of the notebook.
Step 4 - Replace the battery
  • Toe the rear edge of the battery into the base enclosure.
  • Lower the front edge of the battery and press the battery into the battery bay until the release latch clicks.
If you want to See the Video for replacing the DVD drive. You can go to this URL :- http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01271783&cc=us&dlc=en&lc=en&jumpid=reg_R1002_USEN
Jul 05, 2008 | Toshiba Computers & Internet
Toshiba Satellite A105-S2236 Laptop
The drive is faulty. You need to replace the drive. The reason the DVD still works is because a combo drive has 2 different lasers; one for the CD and one for the DVD. So the CD laser is faulty.
Jun 29, 2008 | Toshiba Satellite A105 Notebook
DVD broken - How to replace it
I found this on the toshiba website http://askiris.toshiba.com/ToshibaSupportSite/search.do?cmd=displayKC&docType=ex&bbid=bb35&url=&dialogID=45113241&stateId=0%200%2045111928
Basically it says 'If the internal CD or DVD drive is removable, it's usually secured in place by a locking switch and a separate eject switch / lever on the bottom or side of the computer.'
I couldn't find a decent manual with pictures, hopefully this helps
Lee
Jun 25, 2008 | Toshiba Satellite A105 Notebook
Toshiba Satellite A105 Notebook Logo
184 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
