Question about Samsung MW1030WA Microwave Oven
I have a samsung model MW3090W and need a turntable roller
    Top Expert:
  • Samsung Master
  • 12,223 Answers
Go please to www. repairclinic.com and get it.
God bless you
Posted on Jan 23, 2013
Turntable in new Samsung Microwave is wobbly-- turns OK but goes down if you put something on it away from the teflon rollers.
If the turntable is unstable in the oven, it's most likely an issue with the oven cavity. The tray is probably borosilicate glass, the roller guide is simple, this is something a service tech should see in person. If the oven in still under warranty you should pursue a warranty service call to make sure the oven cavity was not stamped incorrectly. Pleazer Appliance...
Jan 13, 2015 | Samsung CHEF Collection 2.1 cu. ft. Over...
I have a built in convection/microwave oven model AWM540IX, the turntable is not turning, is there anything I can do or will I need to get professional assistance?
Check the turntable guide to make sure it is lined up properly and that there is no debris caught in it. You may need to re-align or clean your turntable guide.
Cleaning and realigning a turntable guide;
Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable.
With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing.
Test your microwave after this thorough cleaning and realigning in order to determine whether this has solved your problem. DO NOT run your microwave with nothing in it.
CAUTION: Your microwave oven is capable of giving you a serious electrical shock, even when it is unplugged. We strongly suggest you seek the assistance of an appliance repair technician when conducting any microwave oven repair.
Also, Examine the plastic drive bushing the turntable tray sits on. It may have become worn, or even may have split in two;
Drive bushing replacement
Inspect the plastic drive bushing located below your microwave oven's turntable tray. There may be some debris blocking the tray's range of motion. Clean away any blockage you find, and then test your microwave to see if this has cleared up the problem. DO NOT run your microwave with nothing in it.
However, if upon your inspection, you notice that the plastic drive bushing below the turntable tray is worn and/or broken, you will need to have the bushing replaced. Consult with a certified and experienced appliance repair technician. Replacing a drive bushing is a lengthy and involved process that the average layman should not perform.
Good luck....
Mar 21, 2011 | Whirlpool Microwave Ovens
GE model je 1860, the turn table doesn't work, the 21 v ac crossed the turn table, and the motor is 128 ohm as the spec. Would you think what caused,please Thanks
In GE / Samsungs that have 21VAC turntable motors and stirrer motors, the 21VAC is supplied from a tap off the internal cooling fan motor that cools the magnetron.
It sounds like you have a bad turntable motor.
The turntable system otherwise consists of the motor, the coupler, the turntable support with rollers, and the tray.
You can see and hear a video of how a turntable motor should sound when you rotate it by hand.
If yours won't rotate or it sounds like it's grinding, etc., you may have a bad motor or possibly a bad plastic coupler.
To replace either, you need to unplug power, then remove the bottom cover of the oven.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
You can find helpful exploded view diagrams and order parts by entering your full model number here.
Oct 01, 2010 | GE JE1860 Microwave Oven
.model mw3090w microwave
Here is a tip that will help you to figure out what is wrong with yourMicrowave Oven....
Microwave Oven Basic Troubleshooting Tips
heatman101
ca
Sep 25, 2010 | Samsung Microwave Ovens
Microwave quit
Well first of all you can try to clean the turntable- Remove your glass turntable cooking tray from your microwave. Gently wash with warm soapy water to remove any debris. Next remove the turntable guide and clean it in the same manner, with warm soapy water. Pay particular attention to the turntable rollers. There could be spilled food particles caught in the rollers, hindering the rollers' movement. Also, gently cleanse the internal cavity of your microwave, paying special attention to the area below the turntable. With the internal cavity, turntable, and turntable guide completely clean and dry, return the parts to your microwave. First place the turntable guide on the bottom of the microwave. There should be a circular groove in the bottom of the microwave cavity keeping the turntable guide in place. Follow the guide with the turntable cooking tray. Carefully place the glass tray over the turntable guide and onto the drive bushing. The drive bushing should fit neatly into the grooves on the bottom of your glass cooking tray. It may take some adjusting before the tray will sit properly onto the drive bushing. If further you have the same problem then this could be a failing turntable motor...... Please post comments for further help or information.......
Good Luck!!
Thanks
Jun 25, 2010 | Sharp R-1610 Microwave Oven
Turntable wheel under glass tray broken
If the microwave comes with a roller ring to rotate the glass turntable then I would recommend that it needs to be used when the microwave is operating, as the turntable rotates the food so it can be heated evenly.
I would recommend checking with your local Panasonic repairer he may have access to a new roller or even a second hand one to tide you over.
Mar 20, 2009 | Panasonic Microwave Ovens
Mocrowave clod
heatman101
9t
Jan 23, 2009 | Samsung MW1030WA Microwave Oven
My Samsung microwave no longer spins. Any ideas? Please help
The turntable system consists of the motor, the coupler, the turntable support with rollers, and the tray.
If yours is not set to be off via the control panel, and it won't rotate or it sounds like it's grinding, etc., you may have a bad motor or plastic coupler.
You can order Samsung parts here.
Aug 19, 2008 | Microwave Ovens
I need to purchase a replacement turntable support
The turntable support ("roller guide asm") is actually ref # 28 and runs only $22.11. See http://tinyurl.com/gv383
Oct 16, 2007 | Microwave Ovens
Turntable roller rest
It's called either the turntable coupler or the turntable support, depending on your model number. You can visit the Sears parts Web site at http://www3.sears.com/ and enter your full model number and see exploded view diagrams, parts lists, and order the part. Or you can call Sears parts at 1-800-252-1698.
Mar 24, 2007 | Kenmore 62463 Microwave Oven
Samsung MW1030WA Microwave Oven Logo
42 people viewed this question
Top Samsung Microwave Ovens Experts
William Miller
William Miller
Oscar Netto
Oscar Netto
Are you a Samsung Microwave Oven Expert? Answer questions, earn points and help others
