My thin twin washer smell like burn when is washing,what can it be?whirpool LTE6234DQ0
The timer was change,just that, now the engine smells like burn tires what can it be , what can i do?
  • violette_cem
    violette_cem Jan 25, 2013
    it doesn't has belts
  • Washing Mach... Master
  • 17,129 Answers
Could be that the belt is rubbing or that the heater is burning the cables It is best to use a good observation lamp , switch off the machine, remove the covers and go by the smell to the suspected area.
Click on: Element
Posted on Jan 24, 2013
  • violette_cem
    it doesn't has belts, i saw very close and the copper wires from the engine seems to become color black instead of it's color,the repairman said that i need to replace the whole engine is dead, but the washer continues to work, i don't seem to understand what it is wrong with it.T
  • 2920 Answers
SOURCE: whirpool washer burning smell
i would consider getting aanother washer.if it keeps doing this the machine will cost you more than its worth. time to call a repairman in again id guess..
Posted on Jan 11, 2009
IFIXALL
  • 868 Answers
SOURCE: Whirlpool Thin Twin washer won't start, just makes humming sound
The belt is broken and needs to be checked for any other part that has failed causing the belt to burn.
Posted on May 26, 2008
zr800o1le
  • 19 Answers
SOURCE: After about 18 months, washing machine smells like rotten egg/fart. Is there anyplace to clean it out?
If you have well water, Check your "Annode" Rods in the Hot Water Heater. Had mine do this. I had to Replace the Whole thing as it built up to much Contaminents from the "Hard" Water.
Posted on May 12, 2009
  • 17 Answers
SOURCE: Washer stopped during wash cycle, burning smell
http://www.appliancepartspros.com/Appliance-Parts/Dryer-Parts/index.aspx Take a look at what a new motor costs for your machine and go from there. Is may not be a motor is could be a belt or a bearing. I rebiult a washer for less then 50 dollars that one did not need a motor just bearings and a belt. I would take the washer apart so you can get an idea of what went wrong and then look at parts to repair it and decide what to do good luck
Posted on May 23, 2009
mrbobfixit
  • 259 Answers
SOURCE: Overloaded washer, smelled burning. Washer works
On this machine, you most likely just burned the drive belt. The old dependable care transmission design was pretty hard to kill, so just get yourself a new set of drive belts. Very easy to replace/install. You can just tip the machine back to access them. There is a lip on the bottom of the front panel that will hide the pump belt but enough room above it to unwind it off the pulleys. If you want, the front panel can be removed, early models used two phillips head screws to hold the front on or later versions used two clips on the bottom that you can release with a putty knife. Pull the bottom of the front panel forward to un-clip the top and away you go.
Posted on Jul 02, 2010
My wife put a load in last night and a couple of hours later the laundry room smelled like something was hot and the washer had stopped on the spin cylce. The control panel didn't feel hot but I unplugged...
Something caught in pump & belt burning. Motor start capacitor (If fitted) is US & needs replacing. Timer faulty, motor has burning smell, replace timer & or motor. Motor switchgear failed motor sitting there & humming, adjust switchgear or replace motor.
Dec 19, 2013 | Maytag Atlantis MAV6000 Top Load Washer
Dryer part, smells burnt and is extremely loud
If you notice a burningsmell in your washing machine, the cause could be any number of things. Regardless, this is one smell you shouldn't ignore. It's important to quickly diagnose the problem and find the solution.
The "Burning Belt" Smell
Older, top-loading washing machines use a belt drive to transport energy from the motor to the transmission and pump. The belt can prevent costly repairs to the motor or transmission by slipping, stretching, or breaking if there is a malfunction in the machine. If the belt slips, stretches, or breaks, it can cause friction and a burning smell, most likely a burning "rubber" smell.
The solution is actually quite simple: you need to replace the drive belt on your washing machine. You can call a repairperson or, if your washer is under warranty, the manufacturer. If you or someone you know is handy, you can replace the belt yourself. The belt is located either from the back access panel or from the underside of the washer.
Most new washing machine models are "direct drive." This means they do not use a belt. The motor is directly connected to the transmission. If you have a direct drive machine and your washer smells like it is burning, read on.
Electrical Problems
If your washer smells and you have a direct drive machine, it may be the motor, transmission, or both. If these are shot on your washing machine, the result may be an electrical burning smell. Both are necessary to run your washing machine and can be costly to repair. The first thing to do if you notice an "electrical" smell in your washing machine and not a "rubber" burning smell, is to unplug the machine and call the manufacturer or a repairperson.
An electrical burning smell may also be caused by a water leak coming into contact with electrical wiring. Both are major concerns and should be addressed immediately. A water leak can cause structural damage in your home and can short out the electrical wiring in your washer and cause additional damage to the machine.
Other Causes
Another more likely cause of a burning smell in your washer is overloading. Adding too many clothes to your washing machine can stress the motor or transmission, causing them to overheat or malfunction and emit a burning smell. For top load washers, overloading can cause the agitator to freeze or malfunction, stressing the drive belt and causing friction, which could emit a burning rubber smell.
To prevent overloading, know the size of your washer. They are measured in cubic feet. In addition, know how many towels, pants, shirts, and other items you can safely load. When it doubt, do smaller loads. Not only will this prevent overstressing the machine, it will also ensure clothes are thoroughly cleaned and rinsed.
Nov 07, 2010 | EuroTech Washing Machines
Burning smell wont work
If it is a burning rubber smell, the drive belt from the motor to the transmission may have failed. Remove the rear panel to access (you may have to remove the top first-- push in on the two front corners with a thin putty knife and release two spring clips ). Make sure the transmission pulley turns freely before repair. Hope this helps!
Jun 27, 2010 | GE WBSR3140DW Top Load Washer
My kenmore 70 series top loading machine will not drain and go into the rinse cycle what part needs to be replaced?
CHECK THE LID SWITCH, AND CHECK THE TIMER FOR A BURNED SMELL. IF SMELL PROBABLY TIMER. SOME WASHERS WOULD NOT GO INTO SPIN WITHOUT LID CLOSED, BUT WOULD AGITATE.
Mar 10, 2010 | Kenmore 22422 Top Load Washer
After washing with my whirpool duet my wash smells sour. Any idea?
Try using Affresh washer tablets. This kills the smell in front load washer. You can order this online or at a local parts store. Works great. I use it on all the front load washers that i sell in my store.
Jun 26, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Whirpool washer burning smell
Jan 11, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
May 26, 2008 | Whirlpool LTE6234D Top Load Stacked...
Washing Machines Logo
74 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
