Question about Whirlpool Duet GHW9150P Front Load Washer
Display flashing F5
Stop filling in mid cylce
    Problem Solver:
  • 6 Answers
F5 is the ntc for heater , this needs to be replaced or check for broken wire that supplies it .
Posted on Jan 23, 2013
Display flashes F5 it stops filling
Possible that the INLET filter or valve is faulty. check the voltage at the time of the cycle to confirm
click on : Inlet valve
Jan 23, 2013 | Whirlpool Duet 3.8 cu. ft. Front Load...
I have an LG front load washer (model# wm1814cw). The machine stops mid cycle but gives no error code. I have to almost unload the washer entirely and then restart the cylce. If I try to begin the
Replaced the sensor and it rocks again. I was about to buy a new washer.
1. Remove the back panel
2. Remove the center bolt that hold the cap which covers the motor coil.
3. Pull the cover out.
4. Remove all the bolts that hold the motor coil. Be carefull not to drop the coil when you take the last bolt out.
5. Remove the old sensor and replace the new one.
6. Put back every thing and it will rock again.
Jul 22, 2012 | LG WM1814CW Front Load Washer
Washer stops with "nf" displayed on screen
nf is no fill
with samsungs most of the time its a bad resistopr on the cold water vale itself,
check your screens though
Oct 03, 2009 | Samsung WF337AA Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Machine stops at Mid Cycle and the Timer Flashes
Check your exit hose spigot, it may be clogged. This is if your filter is all clean. There should be air for passage in the standpipe behind. Your hose should not fit airtight into the standpipe and neither too deep into it. Snaking out your standpipe would be good too.
And pl rate me if helped.................
Jan 25, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Elite he3T front load, bought 2004
I'm going from memory on the "H F" code: If it stops during a filling cycle, it's probably the small rubber hose running between the pressure switch and the bottom of the tub. Mine had a small hole rubbed in it as a result of it rubbing on the counterweight on the back of the tub assembly. I replaced the hose with some vacuum hose I purchase at a car parts store that had the same inner diameter. I also made sure the hose wasn't rubbing the counter weight when I reinstalled it.
Jan 02, 2008 | Kenmore 46462 Front Load Washer
Whirlpool Duet GHW9150P Front Load Washer Logo
74 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
