Question about Euro-Pro 416 Mechanical Sewing Machine
Removing front cover
We have a euro pro model 416 that had a screw fall out and now the tension unit is loose. How does the front cover around the sewing head come off? We can't get inside to replace the screw. Have the whole front loose but this area will not loosen.
If you very carefully lift the decorative plate at the bottom left corner you'll find hidden screw took me a while to find it cause mine
Posted on Feb 21, 2009
How do you remove the faceplate on a euro pro 376
Some machines (computerized models) are made so that the outer covers cannot be removed. Are you able to remove the side cover over the needle bar? You may be able to find the problem there. Otherwise, you may need to have service performed. The thread could be hanging up in the tension guides--most likely pieces of thread.
You might try cleaning the tension guides. RAISE the presser foot, loosen the upper tension as much as possible. Then gently pull a length of unwaxed dental floss through the tension mechanism a few times. If that doesn't work, there may be something really stuck that needs a technician to resolve.
Just FYI--ALWAYS raise the presser foot before threading the upper thread. This releases the tension disks so the thread will seat properly.
Jan 24, 2016 | Euro-Pro Sewing Machines
Check this site
Euro Pro Sewing Serger Machine Parts www drdanessmh com
It is impossible to list all parts on a webpage so if you don't see the part you need click their Contact Policy Tab at Dr. Dane's Sewing Machine Hospital for more Parts
Jul 27, 2015 | Euro-Pro 416 Mechanical Sewing Machine
Need manual for the euro pro 416 sewing machine
contact euro pro website about a manual
some of these sites you'll have to email & ask them
Apr 22, 2012 | Euro-Pro 416 Mechanical Sewing Machine
I have a EURO -PRO model 9110. The bobbin tension is not correct.The top thread can be easily pulled out after sewing.How do I adjust the bobbin tension?
Hi janna
have you tried adjusting the top tension first?
if you have a drop in bobbin then it has to be adjusted at a sewing shop
the bobbin case you take out of the machine you can, using a small screw driver,,here's how
lower bobbin tension--
to test the bobbin tension,
remove the bobbin case & bobbin,,
hold it by suspending it by the thread,,
**** it once or twice,,
if the tension is correct, the thread will unwind by about an inch or two
if the tension is too tight, it does not unwind at all
if the tension is too loose, it will drop too much
to adjust turn small screw on the side of the bobbin
to the left is tighten
to the right is loosen
Sep 21, 2011 | Euro-Pro 9120 Computerized Sewing Machine
I need power cord for my euro pro 416 where can i buy one in ohio
why you should buy? andakan can make it. inexpensive and creative, taking advantage of existing things.
Aug 14, 2011 | Euro-Pro 416 Mechanical Sewing Machine
I need a power cord and foot pedal for a Euro-pro 416. I guess I have moved too many times... Where can i get them?
is this it?
Feb 05, 2011 | Brother CS-100-T Computerized Sewing...
Lost Electric cord and pedal
I thought mine was also lost until I looked in the hidden compartment at the top on the back side. Just a suggestion
Feb 23, 2008 | Euro-Pro 416 Mechanical Sewing Machine
Euro-Pro 416 Mechanical Sewing Machine Logo
113 people viewed this question
Top Euro-Pro Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Greg Cann
Greg Cann
Are you an Euro-Pro Sewing Machine Expert? Answer questions, earn points and help others
