Question about Vtech Digital Cordless Telephone VT-2568
How to retrieve messages on my vtec 6.0 model vs6114
Phone was previously programed but i can't remember my code for playing back messages
Whats the name of the wiring harness thats needed in a swap from non vtec to vtec
92-00 Honda Engine Swap Wiring Guide VTEC AND NON ...
honda-tech.com/.../92-00-honda-engine-swap-wiring-guide-vtec-non-vt...
Oct 8, 2011 - 92-00 Swap Wiring Guide for VTEC and Non-VTEC ... try to compile one thread that would try to answer pretty much 95% of all questions ... I wanted to do this because often times I end up posting the same thing to ... to ECU harness so using an EX/SI 92-95 engine harness will make VTEC plug and play.
97 accord non VTEC to VTEC ' HondaSwap
hondaswap.com > Model Specific > Accord
Jan 16, 2010 - 15 posts - ‎6 authors The distributors may be different on the vtec/non vtec. .... As was previously stated, allyou need to do is add wiring for VTEC. ... that connect to the ecu to the connectorsthat wire in your engine harness while the engine is out... f22b2 non vetec swap to f22b vtec need help asap
Sep 22, 2012
96 accord head swap non vtec to vtec
Jun 1, 2012
1990 USDM CRX Si D16A6 to ZC SOHC non-VTEC ...
Mar 7, 2012
99 Accord non-vtec to vtec engine swap, need help
Sep 27, 2011
More results from hondaswap.com
Nov 03, 2015 | Cars & Trucks
Tip
Remote access for machine
This come from a previous model than I have (mine is a ol5870), but seems to work for this one in retrieving messages from another phone.
Default access code is 0000 if you haven't changed it (but you should); when answering machine answer dial in the 4 digit code while the outgoing message is playing.
Once in dial 1,2, or 3 to play messages (mail box number I believe)
You can dial * for a help menu
4 Repeat a message
44 Ignores a message (message won't remote retrieve next call)
6 plays next message (skip to next)
7 Deletes message
8 Lets you record a memo
9 Let's you change the outgoing message (5 stops the recording)
0 Toggles answer on/off
I hope this helps some people at least in part.
on Feb 14, 2009 | Olympia OL5870 Digital Answering Machine
My mother can't remember the numbers to retrieve messages on her GE Big button, model 29369GE-1
The 29369 isn't an answering machine. Please consult the the documentation for whatever answering machine *********** has on her phone line.
If you require further assistance, please feel free to repost your question, but be sure to specify the make and model of the answering machine.
Oct 24, 2012 | Big Button GE 29369GE1 Speakerphone
Lost my pin to access messages. The phone model is a Panasonic cordless Model TGA542AL.
Which model of Uniden phone do you have? Do you remember the PIN that you have programmed into the phone? (If the PIN is not set, you can't access the answering system remotely. The Uniden phones that I know don't have a default PIN.)
For the DCT648, to access the messages remotely, dial your phone number and wait for the system to answer. Press 0 followed by your 2 digit PIN (within 2 seconds of pressing zero) while the greeting is playing. To play back all of the messages, press 0 2. If the unit is off, then you need to press 0 followed by your PIN (within 2 seconds) after 10 rings and the beep. Press 0 6 to turn on the unit.
Other Uniden phones use a 4 digit PIN. On the DECT1080, when the greeting plays, press * followed by the PIN. Then press 01 to play back the messages.
Uniden phone manuals are available at the product page (start at http://www.uniden.com and search for your phone) or from the Support page ( http://www.uniden.com/scat/cordlessphones_mnl ) . On the support page, you will need to use the drop down menu to change the type of phone (if you have a DECT phone) and then search through the pages. The manuals are listed in numerical and alphabetical order. One manual will cover several phones if the phone supports multiple handsets. So ignore the number after the dash if you can't find your exact manual.
If you add a comment with your phone's model number, I'll be glad to check the specifics for accessing the answering system for you.
I hope this helps.
Aug 30, 2011 | Panasonic Lands Phones
I have lost my manual and I don't know how to retrieve my messages from another phone when I'm away from home.
I hope this helps.
Aug 16, 2011 | Uniden Cordless Phone
I need to know how to retrieve my messages when not home. I have the Southwestern Bell Freedom Answering Machine Model No. FA 972. Thank you.
Call your phone, let the outgoing message play when the machine answers, and wait for the beep. After the beep, enter the 3-digit security code you'll find on a sticker on the bottom of the machine. The machine will beep twice to let you know you entered the right code and it's ready for your commands.
Remote commands:
1# Plays messages in mailbox 1
2# Plays messages in mailbox 2
3# Deletes old messages (you need to play them all back first)
7# Starts recording a new outgoing message (press 7# again to stop recording)
9# Turn the system on or off
0# Monitor the room
While you're playing messages (you pressed either 1# or 2#) you have these commands:
3# Erase current message
6# Repeat previous message
7# Skip to next message
8# Repeat current message
## Stop playback
After your messages have played, you have 20 seconds to enter another command before the machine disconnects automatically.
You can download the manual here so you'll have a copy for future reference.
Jul 31, 2011 | Southwestern Bell FA972 Digital Answering...
Panasonic KX-TG933T 6.0 Lost directions. Need to program phone call in code from outside to retrieve any messages. Can't remember what my code is.... Thank you Ann Marie
If you haven't changed it, the remote access code is 111.
You can download a copy of the manual from the manufacturer's web site at
http://service.us.panasonic.com/OPERMANPDF/KXTG9331.PDF
The remote operation instructions begin on page 37.
Jul 12, 2011 | Lands Phones
How do i retrieve messages when out of town, from my v-tech 5.8 & can i use my cell phone to do this ?
If I remember correctly you can remotely connect to your answering machine.
When you call the phone and it greets you (assuming you haven't changed the code) press 19 to get it going.
You should then begin to hear your messages. After you get past the 19 part (options are as follows)
1 ) Plays all messages 2 ) Plays only new messages 3 ) (During playback) Deletes the current message 33 ) Deletes ALL OLD messages 4 ) Repeats current message 5 ) Stop 5 ) (While no message being played) Lists Available Commands 6 ) Skips to next message 7 ) (While no message being played) Record new greeting 8 ) Hang up 0 ) Turn Answering Machine on/off
Jun 29, 2011 | Vtech 5.8GHz Cordless Phone with Digital...
How do I access my messages when I am out of town. I have a Panasonic DECT 6.0 Thank you. ginny
Call your phone while you're away, and when your message starts to play enter your remote code. After that, you use the keypad on the phone to control message playback, record a new greeting, etc.
"DECT 6.0" is a generic term for the cordless phone technology, and not your phone model number. You'd find that on a label on the back or bottom of the base unit. Without a specific model I can't look for a manual and give details, but if you have the model listed you can download the manual from Panasonic here. It gives all the steps to set up your remote code and the commands to use. If you have a different model phone you can look for your manual at Panasonic's support page.
For the model listed above, the default remote code is 111. The list of remote commands is
Key Remote command
{1} Repeat message
(during playback)*1
{2} Skip message (during
playback)
{4} Play new messages
{5} Play all messages
{6} Play greeting message
{7} Record greeting
message
{9} Stop recording
Stop playback*2
Start voice guidance*3
{0} Turn answering system
off
{*}{4} Erase message
currently playing
{*}{5} Erase all messages
{*}{6} Erase greeting
message (during
greeting message
playback)
{*}{#} End remote operation
(or hang up)
Maybe this list works for your phone too.
May 31, 2011 | Panasonic KX-TG1033S Cordless Phone
How can I retriev messages from my home ohine/ansering machine???? PLEASE help. Model # 29893GE1B
Greetings:
To retrieve your messages from another phone call your telephone number and when you hear the beep enter your 3-digit security code (if you haven't set it the default code is 1 2 3). The answering machine will beep to confirm the code. You can skip the greeting by entering the security code anytime during the greeting.
To hear your messages locally press and release the PLAY/STOP button. To stop playback, press and release PLAY/STOP again. To restart the message that is playing, press and hold PREVIOUS until the message restarts. To replay the previous message, press and release PREVIOUS. To play the next message, press and release NEXT.
Hope it's all good news - Thank you for using FixYa.com.
Mikeywaf
Mar 11, 2011 | GE 29893GE1 Corded Phone
Vtech Digital Cordless Telephone VT-2568 Logo
49 people viewed this question
Top Vtech Lands Phones Experts
Are you a Vtech Lands Phone Expert? Answer questions, earn points and help others
