Question about Honeywell HZ-709 Oil Filled Radiator Heater
How to get control cover off hz-790
How does the panel come off to expose anti tilt?
  • Steve Tardugno Jan 25, 2013
    Small star driver or drill out and replace. They are located on the bottom front of unit.
Removing the top of my Kenmore model 790
You could have asked in the original post. :>)
Look at the upper rail of the oven at the front. Look for clips that unscrew and will allow you to tilt the top backwards.
Oct 29, 2015 | Kenmore ELITE 790 30 FREESTANDING DUAL...
How do I remove front panel on my mede200xw
Remove the top screws from rear, slide top back and up to remove,
You just exposed the screws in front top that fasten the control panel - remove thos and lift off control panel, now exposed are the top front panel screws, remove those and tilt panel out and pull up. Some have a few screws at bottom of front panel that have to be removed as well - also remember to disconnect the door switch wire harness.
RDU Appliance Repair Washing Machine and Dryer Repair
Jan 01, 2015 | Dryers
Where Is the anti theft module
Passive Anti-Theft System (PATS) Transceiver module is around the key lock cylinder behind or under the plastic cover on the upper steering column'
Passive Anti-Theft System (PATS) Transceiver Removal
  1. s4h~tr~en~file=ani_caut.gif~gen~ref.gif CAUTION: Electronic modules are sensitive to electrical charges. If exposed to these charges, damage may result.
    Disconnect the battery ground cable, Refer to Section 414-01
  1. Remove the ignition switch lock cylinder.
    1. Insert the ignition key into the ignition switch lock cylinder and turn to the RUN position.
    1. Push the ignition switch lock cylinder release tab with a punch while pulling out the ignition switch lock cylinder.
    2. If equipped, remove the tilt wheel handle.
    3. Remove the upper and lower steering column shrouds.
      1. Remove the screws.
      1. Remove the upper and lower steering column shroud.
      2. Remove the lower instrument panel steering column cover.
        1. Remove the lower instrument panel steering column cover.
        2. Remove the instrument panel steering column opening cover reinforcement.
          1. Remove the bolts.
          1. Remove the instrument panel steering column opening cover reinforcement.
          2. Remove the anti-theft transceiver module.
            1. Remove the screw from the bottom of the transceiver module.
            1. NOTE: Only apply pressure or leverage below the key cylinder lower rib.
              Disconnect the electrical connector and remove the module.
Dec 24, 2014 | 2006 Ford Taurus
Samsung dv4006 control panel removal
remove the top with 2 screws on the back then slide back a little then it will lift off. there are 3 or 4 tabs at the top of the console that lift and the plastic will tilt toward the front and lift off to expose the control.
Mar 14, 2014 | Samsung 7.3 Cu. Ft. Electric Dryer
Leaking water from the bottom
Lots of plastic parts there.... and a few clip on hose clamps. You will need to remove the cover of the machine (typically 2 screws near the left and right ends of the control panel, then lift the panel up and back. That exposes 2 clips that hold the cover in place. Pop them up with a screwdriver. Tilt the machine cover forward and off the guts. Now you can freely inspect the bottom stuff with a flash light and a mirror.
Apr 24, 2010 | Washing Machines
Need to know how to change heating coil in white westinghouse dryer model number wer211eso
The link below discusses disassembly of models similar to yours. The main difference is that the manual covers models with front controls whereas yours has top controls.
Unplug dryer. Place putty knife in the seam between the top and front panel about 2” in from either side. Push in on clip while pulling control panel forward and tilting putty knife handle up, all at the same time. Same on opposite side. Raise top all the way.
Looking down inside dryer on left and right see a screw about 6 inches down. Remove each side while holding front panel in place. Pull top of front panel about 3 inches forward from sides and then pull up. This will disengage the front panel from lower pressure clips and allow you to turn it sideways and expose the dryer interior.
Continue with "Removing the drum" on page 69. Having removed the drum exposes the heater behind it and safety thermostats above the heater shroud. The heater is generally purchased and replaced as a coil only not as a complete assembly as described in step 4 of page 72. Look for a break in the coil by touching all sections until found. If the break is not found check thermostats, motor switch at back of motor and heat contacts in timer for open circuits. Repair as necessary.
Reverse above process to reassemble.
Dryer Service Manual
Sep 30, 2009 | Electrolux Dryers
I have no idea how to put music on my iRiver IFP-790 mp3 player
First, you should have MP3 music files on your computer. If not, download what you like or "rip" from a CD using Media player or similar application.
Then simply connect your MP3 player to a USB port on your computer. It is very likely that if you remove a cover on the player it will expose a USB connection. Plug it into your USB port on your computer. It will automatically be recognized by Windows and you can see the contents. Navigate to the music on your computer, click to copy it and then paste it onto your MP3 player. Voila, it will be there to play!
Sep 05, 2009 | iRiver iFP-790 MP3 Player
Dont have a owners manuel so i dont know what the fuse numbers are 93 ford taurus
1996 is all I have. Look on back of cover for fuse chart.
Location
The fuse junction panel is located to the left of the steering column. To expose the fuse junction panel, remove the fuse panel cover (14A003) as outlined.
Fuse Loc. Number Fuse Amp Rating Fuse Color Circuit Protected 1 — — Not Used 2 5A Tan Instrument Illumination 3 10A Red Left Low Beam Headlamp 4 10A Red Right Low Beam Headlamp 5 5A Tan Brake/Shift Interlock Rear Window Defrost 6 15A Lt Blue Back-Up Lamps/Air Conditioning, Speed Control, TR Sensor 7 10A Red Starter Relay Power, TR Sensor 8 5A Tan Radio Mute, Power Antenna, GEM Module 9 10A Red Anti-Lock Brake System, Central Temperature Monitor 10 20A Yellow Electronic Engine Control (EEC) Relay, Ignition Coil, PATS, Radio 11 5A Tan Air Bags, Alternator Indicator Lamp 12 5A Tan Gauges, Warning Lamps, Transmission Control Switch, GEM Module, Integrated Control Panel Autolamps 13 5A Tan Air Bags, Blower Motor, Electronic Automatic Temperature Control 14 5A Tan Light-Out Module 15 10A Red Multi-Function Switch (Turn Signals) 16 — — Not Used 17 30A Lt Green Front Windshield Wipers/Washers 18 5A Tan Headlamp Switch Illumination 19 15A Lt Blue Rear Window Wiper/Washer 20 5A Tan Radio Memory, Phone, Remote Anti-Theft Personality (RAP) Module, Integrated Control Panel (ICP) 21 20A Yellow Cigar Lighter 22 5A Tan Power Rearview Mirrors, Antenna, Decklid Lamps, Autolamp 23 5A Tan Generic Electronic Module (GEM) Power, Remote Anti-Theft Personality (RAP) Module, Passive Anti-Theft System (PATS) Module 24 5A Tan Integrated Control Panel, Radio, Speedometer 25 10A Red Diagnostics (Data Link Connector) (DLC) 26 15A Lt Blue Decklid Release 27 10A Red Battery Saver System 28 15A Lt Blue Stoplamps, Speed Control 29 15A Lt Blue Multi-Function Switch (Hazard Lamps) 30 15A Lt Blue Highbeam Headlamps, Daytime Running Lamps (DRL), Instrument Cluster 31 5A Tan Tail Lamps 32 5A Tan Heated O/S Rear View Mirrors, Integrated Control Panel (ICP) 33 5A Tan Power Window and Lock Switch Illumination 34 — — Battery Saver Relay 35 — — Driver Unlock Relay 36 — — Rear Defrost Relay 37 — — Interior Lamp Relay 38 — — Driver Power Window Relay (One Touch Down) 39 — — Accessory Delay Relay
Apr 09, 2009 | 1993 Ford Taurus
My honeywell oil heater fell over on its side and now it wont go on the manuel said to put it up right and it should respond, but it isn't, its a HZ-709, please help
Four small titted tamper proof Torx screws hold the vented side cover to the unit. Two of the screws are under the narrow plastic trim that easily unsnaps at the top of that cover. Gently removing the cover with all of the wires still attached exposes the weighted mechanical saftey (anti-tilt) switch that allows for the possibly bent electrical contacts to be readjusted. Check and tighten any loose or overheated spade connectors and the rest of the operations may not need any further attention.
Mar 05, 2009 | Honeywell HZ-709 Oil Filled Radiator...
Honeywell HZ-709 Oil Filled Radiator Heater Logo
Top Honeywell Heating & Cooling Experts
Bill Long
Paul Carew
Are you a Honeywell Heating and Cooling Expert? Answer questions, earn points and help others
