Refrigerators Logo
Anonymous Posted on Jan 23, 2013
Issue with Kenmore Refrigerator/Freezer
I have a Kenmore 795.75952401 refrigerator/freezer. I noticed the freezer was running constantly and there was ice buildup on the back freezer wall. I also noticed the refrigerator temperature setting led lights were all off, but the freezer LED's 5-7 were all lit simultaneously. I turned the unit OFF and back ON and the refrigerator and freezer temp settings returned to the default (#4) indicated by the LED's. However, the next day I had the same issue -- the refrigerator temp indicator lights were all OFF and the fridge was not cold, but the freezer was running constantly (ice cold) and the freezer temp lights 5-7 were all lit. I have turned the unit OFF/ON several times and it will run fine for a while, but usually by the next day the same issue occurs. Any idea what is wrong?
  • Anonymous Jan 25, 2013
    UPDATE: It seems that the error condition occurs about 24-hours after the unit is powered on.
  • Marilyn May
    Marilyn May Jul 30, 2021
    defost coil
Jt Stefon
Level 1:
New Friend:
Greenhorn:
A rookie expert who has answered 20 questions on their first day.
  • Contributor 22 Answers
  • Posted on Dec 31, 2014
Jt Stefon
Contributor
Level 1:
New Friend:
Greenhorn:
Answers
22
Questions
Helped
4746
Points
46
Ok,1st check on fridge side toward upper back of the top and feel for air coming thru, and there is another one down possibly behind crisper .I had this same deal. Had to do total defrost,, put food in cooler,, theres two blower fans in these types of fridges,,one in the bottom back,, and one in the back of the frezzer,, I used an old hair dryer and let it blow warm to top interior of frezzer,, careful not to let any cords hang/drop in any water!!,ok once done dry out as much water as possible, turn fridge on set both controls to 4,when fridge kicks on do the feel test,, you may need to close the frezzer door, air should be felt near top inside of fridge,if so than shut fridge side and feel inside frezzer near bottom and air should be felt,, side-by-side need to circulate air from frezzer to fridge, then back to frezzer
  • Marilyn May
    how can you feel any air with door shut?
5 Related Answers
Anonymous
  • 93 Answers
  • Posted on Jul 10, 2008
SOURCE: right side of refrigerator not cooling; frezzer working great
Ice build up on back wall could be defrost thermostat or faulty defrost heater
Rob C
  • 547 Answers
  • Posted on Sep 13, 2007
SOURCE: Refrigerator seems to run all the time
Hey Wisper, I had a very similar problem with my Haier. Read all about it here: http://www.fixya.com/support/t180574-freezer_10_deg_fridge_50 I replaced the thermostat ($35 or so, mail ordered) but that didn't do very much. Then I replaced the Evaporator fan ($40 for an OEM part, read the details on my other page) and that did the trick. Feel free to email me if you want more details of what the job involved. I'm @gmail.com and the address is RobCuthbertson
Amigaman
Gerald Griffin
  • 248 Answers
  • Posted on Oct 25, 2007
SOURCE: Frost buildup
  It is not defrosting.  You have to remove back wall of freezer where frost is and take hairdryer to melt away frost.  You need to check defrost heater.  This is on bottom of evaporator coils.  It has wires going to it on both sides.  This has to be checked for continuity.  If ok on top of coils is a round unit called a defrost terminator.  This needs to be checked for continuity also.  This must be done before you defrost coils.  It should have continuity when its cold.
  If these are ok you probably have a bad timer or defrost board.
Anonymous
  • Posted on Sep 17, 2008
SOURCE: GE Profile Refrigerator PFS22SISBSS Bottom Freezer Temperature Indicators
I finally called GE about the non-working LED's and the temperature fluctuation. It's a known problem as many consumers have posted online. I called 800-386-1215 several times. What I found is I'd get different menu options nearly each time I called. The way I got to a 'helpful' human follows: Call above number; you will/may here a voice that states only 'for recalled appliances press 9' (may also have options for repair or parts) PRESS 0; next menu PRESS 5; you'll hear 'for less than 1 yr old press 1' and 'for more than 1 yr press 2'. In my case I pressed 2, then got a menu with 'for refrigerators PRESS 2'. Spoke to a woman who never denied that GE has a motherboard problem. She offered to provide a free motherboard but no labor. I asked (to be sure) if I would have to pay labor, she said yes or I could have $400 off a new crappy GE fridge. She said I would have to have a repairman come to diagnose the problem, then order the part and then come back to repair. I then said, 'You're telling me that I have to pay for TWO service calls to repair a known GE defect???? How much should I expect to pay for these TWO service calls???' She then asked me to hold, then came back on the line and told me that GE would pay the labor for the repair.
I also asked if GE was willing to do anything about the 25 cent door latch that cracked after 11 months (and is attached to the door gasket a $228.00 part) or the rusting wire freezer baskets and was told no. Hey, worth a try! The fact that they said no ensures that I will continue on my crusade to warn anyone who'll listen not to buy GE! Keep calling, after I got the right menu the wait was short the whole call was less than 15 minutes.
Anonymous
  • 1066 Answers
  • Posted on Mar 22, 2009
SOURCE: Freezer works fine, fridge don't
your inside fan has stopped working.  Could be stuck or frozen or simply bad.
Kenmore 10656926600 cycles on for 11-12 minutes then off 14-15 minutes constantly. Fridge and freezer temps are good.
Based on the information you provided, it sounds like your Kenmore refrigerator is operating normally.
Most modern refrigerators are designed to cycle on and off in order to maintain the temperature inside the fridge and freezer compartments. During the "on" cycle, the compressor runs and cools the refrigerant, which in turn cools the air inside the fridge and freezer. During the "off" cycle, the compressor stops running and the refrigerant flows back to the compressor to prepare for the next cycle.
The length of the on and off cycles can vary depending on factors such as the ambient temperature in the room, the amount of food inside the fridge, and how often the doors are opened. However, it's normal for a refrigerator to cycle on for around 10-15 minutes and then off for around 20-30 minutes.
If the temperature inside the fridge and freezer compartments is staying at the correct levels, then there is likely no cause for concern. However, if you notice any unusual sounds, odors, or fluctuations in temperature, it may be worth having a professional technician inspect the refrigerator to ensure it's functioning properly.
Freezer part are too cold
Why is my freezer too cold? ' ShopYourWay
www.shopyourway.com > Manage My Life > Questions
The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
[Appliances] Freezer is too cold? - Home Improvement ' DSLReports ...
www.dslreports.com > ... > Home Improvement
DSLReports
Jul 31, 2014 - 16 posts - ‎12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
Freezer to refrigerator vent frozen (1) - YouTube
? 1:30
https://www.youtube.com/watch?v=8g_39UHYeEA
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
Our Kemore refrigerator seem to be running constantly. It is only 4 years old. Out of 5 hours it has been running 2 hours and 43 minutes, at different time intervals. Temperature in freezer and...
Many times a freezer and/or refrigerator do not work right because of a dirty condenser coil...there are also many other things that can go wrong.
If you are hearing a clicking or buzzing then check out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to start trouble shooting your unit...and something that you can do rather then calling a repair person to do a simple thing for you...
Refrigerator
Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
When plugged, it shorts the surge protector and outlets.
I noticed that my refrigerator, kenmore freezer2_bing.gif, and stove were all not on. This has not ever been a problem before, so I unplugged the surge protector and reset the outlet. I then plugged the refrigerator2_bing.gif and the kenmore freezer to the surge protector and I noticed when I plugged the kenmore freezer it just shorted the surge protector. I then just plugged in the refrigerator and oven to the surge protector with no problems. I tried to plug kenmore freezer to other outlet and same result "a short
Freezer coils get covered in ice about once a month
If the fan is running, replace the defrost thermostat!! Make sure the heater is working... see blog on testing the timer and heater!!
Good Luck!!
Kenmore Trio Bottom Freezer Refrigerator
Loud hum could also be from the air circulating fan in the freezer compartment.
Top Refrigerators Experts
ZJ Limited
ZJ Limited
john h
