Question about MSI CR700-047US Laptop Screen
My MSI CR700 has a loose spot by the bottom left hinge of the screen. What do I do?
It is causing my screen to flicker up and down the screen and then go completely black. . . If you hold in real tight at the bottom it will eventually come back on. What do I do to fix that? It has a small crack running from the hinge to the left screw.
5 Suggested Answers
gcsltd
  • 239 Answers
SOURCE: my lcd screen on my new msi cx700 keeps flickering
This may be due to the inverter board found behind your lcd panel.
Take it apart & solder the two sides of the coil found on the inverter board. This loose solder is caused by heat.
Please send me your feedback & vote to motivate us & to help us help you.
Posted on Feb 11, 2010
  • 114 Answers
SOURCE: I have a msi cr700 and the web cam used to work,
  • Reinstall the driver/software for the web cam.
Posted on Mar 17, 2011
  • 13 Answers
SOURCE: I have a msi CR700.
try charging it if dat doesn't work take it 2 d repairer
Posted on May 11, 2011
jonsnell4
  • 22688 Answers
SOURCE: Msi cr700 no power battery n chager fine
Power socket damaged or motherboard has a fault if you have the correct power to the DC socket on the laptop.
Posted on Oct 02, 2016
Replace lcd on gateway NV57h77u
I disagree. The procedure is so easy no Service Manual is needed
1) Remove ALL power. Remove the AC adapter, and Battery.
2) Open the laptop.
The plastic frame in front of the LCD screen is the Display Bezel.
(Gateway? Believe they call it the LCD Panel Bezel)
Down in the BOTTOM corners, next to the Hinges, are screws to be removed. One in each bottom corner.
There are Screw Covers over these screws. The Screw Covers need to be removed.
Little round covers I believe to be made of plastic.
(Some models they are made of synthetic rubber)
I use a computer pick to Gently remove them.
Some use the tip of an X-Acto knife. I do not recommend this as there is a possibility of injury.
Perhaps a large darning needle. (Needle you sew with, but is Large in size)
Pick up at one edge of Screw Cover. Screw Covers are held on by a type of rubber cement.
I LIGHTLY stick them to the Display Bezel for safekeeping.
(Yes. They like to stick to the tool, your fingers, and it seems passing jets in the sky.
If you are careful with them, you should be able to reuse them.
If they do not stick anymore, use a toothpick, and apply a TINY dab of rubber cement to them/it )
Once the Screw Covers are removed use a No.1 Philips screwdriver, or equivalent Jewelers screwdriver; to remove the 2 screws.
The Display Bezel has TABS going around the exterior perimeter, of it's inside edges.
These Tabs snap into matching LATCHES on the Display Cover.
You can come from the Outside edge, where the Display Bezel meets the Display Cover, and use a thick guitar pick.
The guitar pick is wedged into the parting line, of where the Display Bezel meets the Display Cover.
Once a 'crack' is formed in-between the two, then the fingertips are used to gently start popping the bezel from the cover.
You slowly go along with your fingertips, and work along the top, then sides. By the time you have both sides almost loose, the Display Bezel usually pops off.
I like the flex method.
Come to the inside edge of the Display Bezel.
Where it meets the LCD screen. I suggest start on the Right side/Middle.
Use a fingertip, and lift up the inside edge of the Display Bezel up a little. Can't lift up at that spot? Move over. You are at a Tab/Latch.
With this spot lifted up a little, use the fingertip of the other hand, and slide under next to it.
Now use your fingertips as wedges, and pop the Display Bezel loose a little at a time.
I start at the Right side/Middle as stated. Left hand fingertips go DOWN the right side, Right hand fingertips go UP the right side.
Then I go across the Top, and down the Left side.
MOST of the time, as stated; the Display Bezel usually pops off when right side, and left side are most of the way popped loose.
NOT always though!
Sometimes you have to pop EACH and EVERY Tab/Latch loose.
Also; watch around the Hinge area/s.
Display Bezel can get hung up around them.
Go slow, and gently work the Display Bezel off, around the Hinge areas.
Display Bezel popped off, sit back; relax. You just did the hard part.
Wasn't so tough, huh?
This is what the Display Bezel looks like removed,
http://www.ebay.com/itm/Gateway-NV57H15U-LCD-Front-Bezel-15-6-AP0HJ00021-/171020787909?pt=LH_DefaultDomain_0&hash=item27d1a220c5
The MAIN view shown is a BACK view.
In the smaller views underneath, the 4th view from the Left, shows the FRONT view.
If you SET your mouse cursor in the middle of the Main view photo, the Zoom In feature is enabled.
You can CLICK on any of the smaller views, to make them appear as a Main view.
You can also see that the Hinge Covers, are an integral part of the Display Bezel. Shows you that when removing the Display Bezel, these Hinge Covers may need to be worked off of the Hinges.
Of course, may not; as I have previously stated.
The LCD screen is an Assembly. It is composed of layers.
These layers are kept in the factory set alignment, by a metal Screen Frame.
The Screen Frame resembles a picture frame.
There are THREE screws on each side of the Screen Frame.
These screws (Philips) go through metal Brackets, and hold the LCD screen/Screen Frame; to the Display Cover.
The Brackets are an integral part of the Hinges,
http://www.ebay.com/itm/Gateway-NV55-NV57-LCD-Left-Hinge-Rail-Bracket-AM0HJ000100-/400334888754?pt=LH_DefaultDomain_0&hash=item5d35d19f32
On EACH side, there is 1 screw towards the Top, 1 screw towards the Bottom/Middle, and 1 screw towards the Bottom.
Remove all 6 screws.
At the Top is the Webcam Cable. Unplug it from the Webcam Module.
(Cable pulls to LEFT side, facing laptop)
The TOP of the LCD screen is now tilted forward.
The Video Cable plugs into the Bottom side.
There should be a piece of clear Mylar tape, holding the Video Cable connector in place. Carefully peel it back, unplug the Video Cable from the LCD screen.
Remove the LCD screen.
Reverse steps to install new LCD screen.
For additional questions please post in a Comment.
Regards,
joecoolvette
A) http://www.insidemylaptop.com/replacing-lcd-screen-on-gateway-nv57h13u-laptop/
B) http://www.youtube.com/watch?v=ENmPg46IB9Q
Apr 12, 2013 | Gateway Nv57h77u Laptop/notebook
Msi cr700 media fail check cable
Hello, ihave same model MSI CR700 and have same problem, on booting up it says media failure check cable. Im try reinstal windows but freazed on instaling, Im try instal Ubuntu on USB stick and is working, I can see my disc but is like empty but yesterday there was all my files and no problem to opened files and pictures. what you thing problem in harddrive, cable, conector or motherboard. thanks
May 01, 2012 | MSI CR700-012US (816909061604) PC Notebook
LCD flickering at the bottom of screen
This appears to be a faulty CCFL lamp which supplies the back-light.
Because it is less than 6 months old, I suggest you get it fixed under warranty.
If you try to fix it yourself you will void your warranty.
Feb 12, 2010 | Toshiba Satellite M305-S4826 Laptop
My lcd screen on my new msi cx700 keeps flickering and going black. if i press the top corners of the screen bezel the screen returns to normal.Could this be a bad screen, backlight, inverter, something...
Feb 11, 2010 | MSI CX700-020US INTEL R4330 T4200 SYST2.0G...
Screen flickers on and off
It is a very common problem caused due to loose connction from the MCU to the Screen. MCU ( main control board ). Also check the hinges. They sometimes crack. Replace them in case of hinge problem. Thank you.
Sep 17, 2009 | Gateway 7322GZ Notebook
Screen flickering
That really depends on when it flickers, does it flicker when you move the display open or closed or when you press some part of the laptop?
If it happens when you press a part of the laptop, the display cable could be loose, thats unlikely.
I recently had a similiar problem with a toshiba laptop, the screen would flicker when pressed on the bottom left side of the laptop.
I checked the wires and they where fine, in the end I seem to have fixed the issue by pressing on the top cover where the issue happens and at the same time from the bottom from the same spot, what I did on that laptop, there was a cover that I could remove so I could press directly on the mainboard, pressing directly on the mainboard with my fingers and at the same time pressing down from the top seem to have fixed the problem on that laptop.
Sep 11, 2009 | Acer Extensa 5420-5687 Notebook
Screen flickers, Ok when you "tap" side of unit. Something loose or bad connection.
Most LCD inverters are located behind the screen bezel at the bottom of the screen near the hinges.
May 18, 2009 | Acer Aspire 3610 15.4 Glossy WXGA LCD...
Screen flickers
If light is good and picture flickers, then it is either a bad LCD ribbon cable, or cable not well placed into connector, or a bad LCD display, usually it is the cable.
If picture flickers like light is dimming out and coming back, then it is the LCD lamp, probably in need of replacement.
In some rare case a faulty Video card is causing the problem.
Usually to fix this you need to take apart LCD display and upper laptop plate, to reveal the display cable.
Aug 16, 2008 | HP Pavilion dv1000 Notebook
Both Screens Flicker after trying to replace touch screen
I finally solved the flickering problem on my DS (!), after I made my 1st engineering attempt overhaul shell, top screen and broken right hinge.   Was really frustrated about the flicker afterwards, and opened up unit back up too many times to debug (risked damage to cable ribbon everytime!).
Anyway turns out there's 2 hidden screws (location:  inside the battery compartment near where the front 'volume slider' is located) that adjusts the flickering (like how you need to calibrate an LCD monitor from doing same flickering effects) . You'll need a really (really!) small philips (+) screwdriver to do the adjustment.
Open up the battery cover with the VOL label upside down & facing you.  The adjustment screws are recessed deep inside the plastic...a right and left screw.  With the DS turned 'ON' to see the screen (whether you twist your neck to be able to see or have a mirror on the table in front of the DS)....slowly/carefully turn the screws to adjust until you like the clarity.  That's it.   The right screw = bottom screen.  The left screw = top screen.
Now.... on to figuring out how to replace or fix the broken Power toggle switch that I snapped off!  Currently using the toothpick method, but that's getting old!  Any suggestions, I'd appreciate it!
Dec 08, 2007 | Nintendo DS Lite Console
MSI CR700-047US Laptop Screen Logo
105 people viewed this question
Top MSI Computers & Internet Experts
vsri9
David
David
Matthew Spark
Matthew Spark
Are you a MSI Computer and Internet Expert? Answer questions, earn points and help others
