Question about Whirlpool Duet 3.8 cu. ft. Front Load Washer
Display flashes F5 it stops filling
It stops filling in the first cycle
  • Whirlpool Master
  • 17,130 Answers
Possible that the INLET filter or valve is faulty. check the voltage at the time of the cycle to confirm
click on : Inlet valve
Posted on Jan 24, 2013
Whirlpool integrated dishwasher model ADG 7460 Have run the engineer test cycle and it stops and drains water after 2 mins; start light blinks 5 times.
F5 or 5 times flashing.
Variable speed motor failure.
Reason:
- Connection between Spray pump (Variable speed motor) and control board interrupted.
- Frequency converteron Spray pump broken or control board defective.
= Check the power voltage on the motor. BUS: 5V DC, Motor: 230V AC
Reaction: Cycle stops, drain pump drains out,failure indication.
OR
SPM blocked (MPH motor unit)
Failure condition:
- This failure is only indicated during the active test program
- The electronic detects an irregular deviation of the motor current consumption.
Reason:
Spray pump blocked = check pump housing
Short circuit in motor or wiring = check motor values
Reaction: After 5 attempts to reactivate the spray pump motor the cycle stops, drain pump drains out, failure indication.
Dado
Sep 03, 2015 | Whirlpool Dishwashers
Display flashing F5
f5 is the ntc for heater , this needs to be replaced or check for broken wire that supplies it .
Jan 23, 2013 | Whirlpool Duet GHW9150P Front Load Washer
What does LF mean?
It is a long fill error. It flashes when the machine control board detected no change in the water level or the water level is not reached in a certain period of time during the fill cycle. Water is probably not entering the tub due to the water inlet valve not functioning or water enters the tub but not properly due to clogged fill hose screens.
Press the Pause/Cancel button to clear the error on the display. Remove the fill hoses from the water inlet valve assembly at the back of the machine and check the screens. Clean the screens and replace it if necessary. Make sure that the water supply valve is open and water is present.
Put the machine in standby mode (only the Clothes Clean indicator is on) and activate the Manual Diagnostic Test Mode to check the operation of the water inlet valve.
  1. Select any one button except Power, Stop, and Stop.
  2. Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds-->Release the button for 3 seconds--> Press and hold the button for 3 seconds
  3. Press the same button when all indicators on the console are illuminated and "88" is displayed on the Estimated Time Remaining display. A single beep sounds and display shows the two digit console ID number for 3 seconds. The displayed ID number will change to "00" and the Add a Garment indicator will flash.
  4. Select Whitest Whites cycle.
  5. Press Start>Wash/Rinse Temp. The water inlet valve should turn on and fill the tub according to the Wash/Rinse Temp selection.
  6. Press Start to turn off the valve.
  7. Press Stop or Power button to exit diagnostic test mode.
Feb 04, 2010 | Kenmore Elite Oasis 27052 Top Load Washer
Flashing FL
Hi
If you have error code FL it means flood condition i.e. FL flashes if any overfill condition occurs. This condition occurs when excessive water in the tub causes the overfill switch to trip. The control must realize that the trip was due to an overfill condition instead of a suds lack condition in order for FL to be displayed. With an overfill condition, the beeper repeats a warning every 10 seconds with no time-out. The pump is cycled in drain mode for 30 seconds on, 30 seconds off until the overfill switch resets or power is discontinued to the unit. Press STOP/CANCEL to clear the display.
If its LF which means long fill i.e. when the water fill time exceeds ten minutes, the water valves are turned off and LF is flashed. Press STOP/CANCEL to clear the display.
Please do rate the solution and revert for further assistance.
Thanks
Rylee
Sep 10, 2009 | Kenmore Oasis HE 27082 Top Load Washer
On the normal cycle of my Duet front load washer at 37 minutes the machine stops and flashes F5. I push the reset button then the start button and the machine works fine after that.
HI. This is a Water temperature sensor error.
If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
Potential Causes
• Check the Water Temperature Sensor, Heating Element and Element Relay
• Check connections to the Sensor, Heating Element and Relay
Replace failed component.(Most common issue will be a failed water temp sensor)
Jul 25, 2009 | GE WBVH6240F Front Load Washer
Code pf came up and the washer does nothing
PF Power failure "PF" flashes if the washer loses power during a running cycle. The washer does not flash "PF" when it is first plugged in.
Press START to continue the cycle from the moment that power was lost.
OR
Press STOP/CANCEL to clear the display and completely cancel the cycle.
Apr 01, 2009 | Whirlpool Calypso GVW9959K Top Load Washer
After a power failure I am getting the code e1 f1 flashing on my display board and it will not go away.
q.gif Why is the display showing E"#"-F"#," for example, E1-F2?
Answer Is "PF" displayed on the control?
A temporary power failure has been detected. Press the Stop/Clear keypad to reset your control. You may need to reset your clock.
Is the display showing E0-F5?
The Self-Cleaning latch may be interfering with the oven door causing the Self-Cleaning cycle not to work. If the oven door is open and will not lock, press Stop/Clear to clear the display, press and hold the door switch plunger (located in the upper-right corner of the oven front), and the door latch will unlock. If the oven door is closed and locked, press Stop/Clear to clear the display; apply pressure to the upper-right corner of the oven door, and the door will unlock.
Is the display showing E"#"-F"#," for example, E1-F2?
You will need to schedule service.
please do not forget to rate and comment about your experience today. Thank you
Sep 03, 2008 | Whirlpool Kitchen Ranges
Kenmore 22082
OL on my washing machine
May 17, 2008 | Kenmore 22062 Top Load Washer
Washing Machines Logo
37 people viewed this question
Sal De
Gerry Harvey
Gerry Harvey
