Question about Acer Aspire 9300 Notebook
Laptop does not start - Acer Aspire 9300 Notebook
    Problem Solver:
  • 5 Answers
Is it really old? Take it to your local computer shop and see what they can do about it.
Posted on Jan 24, 2013
My laptop does not start even after prolonged press of start button
Will it work on the 110 volt power supply ? If not then a new one is in order. Another source of a no start is the coin cell battery inside the laptop. I wouldn't think this is a problem on a new laptop.
Mar 20, 2014 | Battery Biz WIPRO AcerNote 350cx AC...
Hp laptop hp 430
Maybe the cpu fan is fubar - check that out.
Mar 18, 2017 | Computers & Internet
Fix a compaq presatio cq57 iz
you start on take the disc of windows & put in the laptop and you restart your laptop then you can start to intoll your windows on the laptop when you done you have to restart again then your laptop is goin to work.
May 20, 2013 | Computers & Internet
I undocked my compaq 6320 laptop - just after accidently hitting the dock- power button (before hitting the eject button). I ejected the computer but noticed it began to start-up but shut down because my...
Try removing the laptop from the doc, pulling out the battery, hold the power button down for 10-20 seconds, and re-install the battery.
This should drain out the laptop and it should boot up properly without the dock.
May 27, 2011 | Computers & Internet
Laptop will not start at all...
Start taking your laptop apart piece by piece and test it after each removed component:
1. Remove the hard drive and test the laptop.
2. Remove the DVD drive and test the laptop.
3. Remove the wireless card and test the laptop.
4. Unplug the display panel from the motherboard/video card and test the laptop.
etc....
Continue taking it apart until you have only three major components connected: motherboard (with video card), processor, and memory. If you still experience the same problem, most likely it's bad motherboard.
By the way, before you start, try reconnecting the memory module. If you have two modules installed, try removing them one by one and test the laptop with each one separately
Sep 22, 2010 | Acer Aspire 5500 5570-2609 Laptop
When I start the laptop or when the screen is
If your laptop is out of warranty, then you can fix the problem by resoldering DC-IN ... Power LED and battery charge LED start flickering when you wiggle the power .... HP Pavilion dv7-4080us 17.3-inch Desktop Replacement Laptop PC ... High-Capacity Battery For Hp Pavilion Zd8000 Series Laptops ...
www.articlesbase.com › ComputersLaptops
Jul 19, 2010 | HP Pavilion zd8000 Notebook
My laptop tx1320us starts up really slow.. What can i do
assuming your OS as vista.
check msconfig
start -search-msconfig- remove unnecessary programs.
start-search-%temp%.- delete all files.
this will speed ur laptop.
also you can delete- temp internet files as wel as delete history files and cookies.
this will spped up ur laptop.
May 14, 2010 | HP Pavilion TX1320US Tablet PC
Wont start up
We will see if the problem is due to the static charge accumulated on the laptop. Disconnect the power cable from the laptop and also take out the battery. Also, disconnect all the external devices attached to the laptop e.g. external mouse, keyboard, printer. Now keep on holding down the power button on the laptop for the next 30 seconds. Put the battery back and plug the power cable. Now try turning on the laptop and let me know if it works. Thanks!
Jan 04, 2010 | Dell XPS M1530 Laptop
Tried to recover hard drive on laptop with my pc recovery disc.
switch on laptop. Press F8 continously until you see safe mode screen, select safe mode and press enter. start it and see if it starts with safe mode. and delete whatever you install had affected laptop and restart it normal mode back
Apr 02, 2009 | Computers & Internet
Labtop wont start up
Hi I am a laptop technician, and it sounds like you have a power problem.
Try removing the main battery and starting the laptop on the mains cable only. If the laptop starts fine then you probably have a problem with either the battery or the power board in the laptop.
If the laptop doesn't start when doing this, remove the mains power lead from the laptop and put the main battery back on the laptop. Try starting the laptop off the main battery only and if the laptop starts normally then you most likely have a broken/loose socket that the power lead plugs into in the back of the laptop (a very common problem) or the power board in the laptop is faulty. If the laptop doesn't start or goes off very shortly after pressing the power button it could just be that the battery is flat as a broken power socket on the laptop often stops the main battery from charging.
I hope this helps.
Jan 03, 2009 | Acer Aspire 5315 Notebook
Acer Aspire 9300 Notebook Logo
13 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
