Question about Hotpoint Aquarius WMA56 Front Load Washer
The belt has come off my hotpoint WMA5 washing machine
The belt has come off the flywheel connected to the main drum, causing it not to spin on spin cycle, is there an easy way to put it back on?
    Problem Solver:
  • 6 Answers
Offer the belt around the motor pulley first , feed one side of the belt to drum pulley , whilst holding this side to drum pulley turn pulley using other hand , belt should follow natural path onto pulley .
Posted on Jan 23, 2013
  • 14 Answers
SOURCE: Hotpoint WMA42 - Noise!!
appliance sounds like it has bearing failure.common on this machine.advise looking for a new machine.sorry
Posted on Dec 30, 2007
gittos73
  • 244 Answers
SOURCE: hotpoint washing machine belt come off
u need to take the lid off and keep the small panel off now 2 ways u can do it 1)undue the botls on the motor just enough so u can move the motor now put the belt around the pulley wheel by placing your hand through the small panel once done put the belt around the motor wheel now last thing pull motor so it tightens the belt and tighten the bolts on the motor 2)place the belt around the wheel on the motor now with your other hand put the belt on 1 side of the big pulley wheel and hold it in place as u turn the pulley wheel it will slide on but with tension once on spin the pulley wheel and it will line up the belt
Posted on Jan 27, 2008
  • 108 Answers
SOURCE: hotpoint wd64 washer dryer
mits86 , you are correct - it could be the belt.
REMEMBER TO UNPLUG BEFORE STARTING ANYTHING!
To do the belt...
1. UNPLUG the washer.
2. check you've unplugged.
3. Open the top of the machine - see the sides of the lid about 10 cm from front, remove plastic caps on each torx head, undo torx. (torx set required)
4. Remove concrete block from top - large spanner is required - remember the sequence so you can replace later.
5. Lean over the drum and see the large drive wheel.
If you see a broken belt then remove it and re-order one from hotpoint...see http://www.4hotpoint.co.uk/cgi-bin/product.pl?PID=634224&brand=&model=wd64&part=belt.
6. to replace belt - see motor shaft at bottom of unit. Dangle new belt round shaft of motor and gently pull so it does not come off motor.(This is not easy!)
7. At the same time Ease one side of the new belt back on to drive wheel on the back of the drum.
8. Turn Drive wheel until belt is on.(This is not easy and requires alot of hand strength)
9. Replace concrete block with bolt and spanner in reverse sequence you removed it.
10. replace lid, torx and cover for torx.
- If the belt is not broken in your case - it could be the brushes on the motor - I can give you info on this if required!
Please dont forget to rate me as fixya.
Posted on Mar 26, 2008
IFIXALL
  • 868 Answers
SOURCE: hotpoint wf250 drum wont spin
Well if you see the drum move in the wash cycle than the belt is still attached.Your door latch is the first thing to check.And the control board is the next and most likely problem.
Posted on May 24, 2008
tborn6
  • 700 Answers
SOURCE: WMA54 Hotpoint Aquarius drum does not turn during wash or spin
sound like the contact points on the timer are probebly dirty or arched to where they are not making good contact. you can take and clean them with a piece of emery cloth if you are mechanically inclined and can take the timer apart. Also there's a set of contacts down by the motor ti check too.
Good Luck,
Posted on Jan 06, 2009
Lg model DLGY1202W Dryer. When I try to start a cycle, I hear a slight click in the back of the dryer and nothing happens. I've tried unplugging it for a couple of minutes and nothing changes.
there are 3 things i find on lg dryers that can cause that. one, main control board would be worse case relay on ctrl board may be stuck causing clicking noise. 2nd, you could have a broken/slipped off belt. test for that would be turning the drum by the fins inside drum without any clothes. It should have a little bit of force to turn. if it spins rather easy. you probably have a broken belt. 3rd lastly, there is a re settable thermostat inside dryer if it pops is cause the dryer not to run.
May 25, 2017 | LG Dryers
MY SAMSUNG WASHER HAS AN ERROR MESSAGE THAT SAYS E3 AND IT WONT SPIN
This video will help you diagnose the fault on 3e error codes and the video will help you solve the problem hope it helps
Jul 08, 2014 | Samsung WF337AA Front Load Washer
AEG lavamat 86800 drum doesn't spin
see this causes and fix it. God bless you
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace
Door Switch
This can cause the washer to not agitate or go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Main Control Module / CCU
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace .
Motor Control Module
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The motor control is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Oct 16, 2012 | AEG Washing Machines
Slow spin
Belt
The belt may have come off or broke. If you hear the motor running but nothings moving the problem is likely the belt. This is easy to check and replace.
Door Switch
The main control unit is the circuit board located behind the console. If the door switch tests good the main control is usually the problem. Check all connections for a goood tight fit. You will need to refer to the tech sheet or service manual to check this further. The main control is easy to replace.
The motor Control Module is located inside the cabinet down near the motor. This recieves the signals from the main control module then relays this information to the motor. Check all connections sometimes a communcation problem is just a loose connection. The Motor Control Module is easy to replace. To check this further you will need to refer to your tech sheet or service manual.
Sep 30, 2012 | Crosley CW6000 Front Load Washer
Whirlpool washer constantly has a "add a garment " light on and wont spin
Belt
Door Switch
Sep 27, 2012 | Whirlpool Washing Machines
Whirlpool Duet GHW9100LW wont spin. Drains fine, but no spin.
Door Switch
This can cause the washer to agitate but not go into the spin cycle. You will need to remove the door switch to check it. You will perform an ohm reading on the bottom terminals. The reading varies from manufacturers most Frigidaires is around 1500 ohms others like the whirlpool duet is checked at the main control board with the door closed should be around zero ohms. You will need to refer to the tech sheet or service manual for the proper reading.
Sep 27, 2012 | Whirlpool Duet GHW9150P Front Load Washer
Problems with zwf 1437w. Drum not turning durin wash
Belt
Door Switch
Sep 25, 2012 | Zanussi ZWF1230W Front Load Washer
There is a grinding noise during the wash and spin cycles.
hello,
the problem is from the jet strew it indicate that the jet strew need to be reset it at the back of the washer it is connected to the main drum it is commonly call propeller or roller it is the cost of the noise
because it has loss it position connected to the drum
unscrew the washer and see the propeller connected to the drum .
thank you and thanks for using fixya.
Jun 11, 2010 | Maytag MAH2400A Front Load Washer
I have a indesit WIB 101 (uk) washing machine.
Remove the belt, and from the front, spin the drum by hand.
If it is noisy or rumbling or feels rough, then the main drum bearings have failed which would explain why the belt was off.
Also check the drum pulley for a brokem or cracked spoke, again this will give you the same symptons.
Please rate my solution.
Thankyou.
Jan 13, 2010 | Washing Machines
No spin cycle
when it does it only in the spin cycle:
Either bearing or motor.
Best thing to do is: Open the back up and put it in a regular cycle. See if the back of the drum has a lot of play.
take off the belt and feel if there is a lot of play in the shaft of the drum. If not and it moves freely with no grinding sound it is your motor.
Jun 14, 2008 | Washing Machines
Hotpoint Aquarius WMA56 Front Load Washer Logo
228 people viewed this question
Top Hotpoint Washing Machines Experts
vince
Todd Arndt
Todd Arndt
puggy666
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
