What's your problem?velleman p2579 farnell schematic diagram
Velleman p2579 farnell schematic diagram
K-4040 left channel lost. How solve this problem?
Look for shorted capacitors and driver stages. You'll need an audio voltmeter and an oscilloscope to trace the signal path. A schematic diagram is a must.
Sep 26, 2016 | Velleman STEREO TUBE AMPLIFIER KIT /...
I need a new display for this model. Where can I get one or an equivalent substitute?
This model sells for $9.99 on Amazon, buy a new one
https://www.amazon.com/Velleman-DVM850BL-Hold-Function-Backlight/dp/B00068U24A
Jan 20, 2016 | Velleman Dvm850bl 3-1/2 Digit Handheld...
How do I fault find my Velleman amplifier kit?
Something's REALLY wrong. Send me the schematic, and I'll look at it and TRY to help you.
Jul 26, 2014 | Velleman SA K8060 200 Watt Audio Amplifier...
Most common fix for code p2579 2012 ram 3500
Check the oil pressure to the turbo. There is a filter in the line that could be needing attention. When the oil pressure drops, the turbo speed varies and it can show a code.
Jun 04, 2014 | Cell Phones
I own a velleman K4040 6550B it requires 220Volts to operate but i would like to turn it to 110-120 Volts operation, any recomendations?
Rather than modifying the unit (which may not be possible), you should be able to locate a voltage transformer that will convert the 110 into 240. Many of these types of units utilize different power transformers depending upon the source voltage. If you'd rather not use an external transformer, request a source voltage change kit from Velleman. If they utilize different parts, the required parts will be included in the kit.
Dan
Sep 19, 2009 | Velleman Audio Players & Recorders
HITACHI 43UWX10B SERVICE MANUAL
Good Day;
If you order KIT 10 from B&D ENTERPRISES at 1-800-458-6053 The KIT will include all parts neede and layout of part value & locations on simple paper lay out diagram.
Good Luck, big IRISH.
Sep 04, 2008 | Hitachi 43UWX10B 43" Rear Projection...
HITACHI 43UWX10B I NEED REPAIR MANUAL
Good Day;
Televison & Video Logo
65 people viewed this question
Top Televison & Video Experts
Electro Med Services...
