Question about Aprilaire 700 Humidifier
Water runs when furnace is off, but stops when furnace is on.
We just moved into this house, and it had the Aprilaire 760 installed, but disconnected. When I put it back together and turned the water on, the water kicks on when the furnace is off and the humidstat is turned up. When the furnace comes back on, the water cuts off. It's clearly wired backwards, but I can't figure out what's wrong.
There is a 24V transformer near the humidstat, and one of the feeds runs through it. It has constant power being fed to it. The plug for the humidifier is plugged in to an outlet on the furnace that only has power when the furnace is running. The brown wires coming off the humidifier are wired to the humidstat (one of which has the 24V feed).
Hopefully that gives enough detail to help.
Thanks!
  • sheff528 Jan 30, 2009
    You nailed it! I hooked up the leads from the humidstat to bypass the transformer, and everything worked great! My humidity has come up a couple of % points to 27%, so we're headed in the right direction.
    One question, though. I noticed water runoff through the drain while the furnace was on. Is that normal? It wasn't a whole lot, but seemed more than I expected.
    Problem Solver:
  • 17 Answers
The 760 humidifier does not need a transformer wired externally. the 760 has its' own 24v transformer inside the fan compartment. this transformer will provide the power to enrgize the water solenoid as needed. it sounds like to me the additional trasnformer is hot all the time. when the furnace comes on, the unit gets power and the internal transformer is cancelling the power from the external transformer. this would explain why it quits running when the heat is on. since the external transformer is hot all time, when the heat shuts off, the solenoid is getting energized by the external transformer. to make this run correctly, you need to get rid of the external transformer. leave the humidifier high voltage wires hooked up so they are only hot when the furnace runs. if you have a humidistat that has a r and c terminal, you will need to wire these directly to the r and c on the furnace control board and move the switch inside the humidistat to "power". make sure it is not on "bypass". then wire your 2 brown wires from the humidifier to each of the "h" terminals on the humidistat. if you have a humidistat that only has 2 terminals, wire one brown wire to each of the terminals. this should allow it to run properly.
Posted on Jan 28, 2009
  • brian baldwin Jan 30, 2009
    that is one of the drawbacks of this type of humidifier. you will have water go down the drain and not into the air. there is an orifice on the inlet side of the water solenid tubing that controls the flow rate.
Water and motor always run on Aprilaire 760, even when furnace is off.
Hope this solves your problem, look for the humidistat, it should be located on cold air return duct near furnace, make sure it is not set in the on position, if it is, then this is why it is staying on, please set humidistat any where from 20 to 35%, never over 40%. If the humidistat is set properly and is still running, you may have a electrical problem, humidifier circuit should only receive power(24 volts) when the indoor blower motor of furnace receives power, also if you have galvanized plumbing in your home, you may have a piece of rust or lime deposit in the humidifier solenoid valve preventing it from closing, turn water off to humidifier and disconnect water supply line entering solenoid valve inspect & clean protector screen. Good luck.
Mar 03, 2010 | Aprilaire 700 Humidifier
Aprilaire 600 humidier: water continuously runs
sounds like you may have it wired to a continuous power source vs one that shuts off with the furnace. The most common wiring is red to C & white to W
Jan 08, 2010 | Aprilaire 600 Humidifier
How do I know my aprilair 760 humidifier is working?
A simple check you can perform on your aprilaire 760 is the following:
1) locate the two brown wires coming out of the 760 (these wires will be wired to tell the 760 to turn on when the hvac bower is on and the humidistat is calling for moisture).
2) temprarily disconnect the two brown wires from the external wiring and then short the wires together. All you're doing here is bypassing the your thermostat and bower-on indicator.
With the 70 unit plugged in to the wall outlet and the two brown wires connected together, both the fan and the solenoid valve (water inlet valve) should both be activated.
Dec 13, 2009 | Aprilaire 700 Humidifier
My water never stops running into Aprilaire 112
Disconnect the two yellow wires. The water should stop. If it does you have a bad (or miswired) humidistat. If the water does not stop the solenoid valve is bad. These valves are known to be expensive. You might want to consider replacing the whole unit.
Good luck
HVAC Teacher
Feb 19, 2009 | Aprilaire 1120 Humidifier
Water does not stop.
soliniod may be stuck. you will need a volt meter to test
Dec 13, 2008 | Aprilaire 700 Humidifier
Aprilaire 700 operating at wrong time
You want the humidifier to run in heat mode which is the r-w1 terminal on the stat.
Nov 17, 2008 | Aprilaire 700 Humidifier
Lots of water run-off from Aprilaire 760 Humidifier
HI would check the filter in side might need changing or cleaning clean out wter tray in side, it could be just a blocked filter , hope this helps
Jan 03, 2008 | Aprilaire 700 Humidifier
Aprilaire 110
Modle 110 has a relay in it see if it is stuck.Hope this helps
Nov 05, 2007 | Aprilaire 600 Humidifier
Aprilaire 760 Humidifier water continues to run
You need to determine whether the problem is in the solenoid or in the furnace electronics. You could put a voltmeter on the solenoid connection to see if the furnace is still holding the solenoid open after the blower stops. This will tell you whether it is the solenoid or not.
Feb 18, 2007 | Aprilaire 700 Humidifier
Aprilaire 700 Humidifier Logo
346 people viewed this question
Top Aprilaire Humidifiers Experts
Paul Carew
jdthefixer
Mack Baxter
Are you an Aprilaire Humidifier Expert? Answer questions, earn points and help others
