MIELE W524 "CHECK INLET" IS ON BUT INLET IS CLEAR
Some washes complete OK, others (eg Woolens) stop after first water dose. The two inlet filters & the drain have been cleaned,(they weren't blocked). When filling the water flows in freely. On the Woolens programme there is a long pause after the first water dose then the Check Inlet light flashes continuously. Eventually the timer shows three bars and nothing else.
3 Suggested Answers
SOURCE: miele novotronic w/m fault light flashing
We had the same problem on a Premier 500 and solved it by tilting the machine forward. Some more water ran out and the lights went off.
Posted on Jan 05, 2008
odiebugs
  • 949 Answers
SOURCE: the check inlet light flashes. I have cleaned the
If your sure the water way is clear, unplug the unit, plug it back in,
and see if the error is gone, if not, place the water lines into the tub and turn on the water to make sure water is coming into unit, if so the problem lies somewhere else.
Re-post if this didn't help, and say you did this but still have the error.
Good luck, hope it helps.
Posted on Feb 05, 2010
Miele Novotronic 500, 10 years old, noisy filling, no error light, inlet filters clean. Any suggestions please?
Hi dear,
As I know it's a indication on inlet valves going to fail. I hope that helps. Thanks.
Jan 21, 2016 | Miele Washing Machines
I have a Miele w828. The wash programme stops and the check inlet indicator light is flashing but the stopcock is on ,the hose is not blocked and the filters are clean. What do I do?
If you have water going in to the machine then it is probably a blocked pressure bag.
If no water is going in to the machine then its probably a faulty inlet valve or blocked inlet filter.
Sep 21, 2014 | Washing Machines
CHECK INLET LIGHT ?
Mains off the wall, unplug. Shut your wall faucet and disconnect your hoses coming to the machine - at the machine end. Get an old tooth brush to clear out the dirt which may be blocking your inlet valve. If possible gently pry off the fine filters to clean well. Re-insert the filters carefully and re-connect, the hoses. Things shd be okay. Otherwise you just hv to change your inlet valve.
Please click if helped, would help others.
May 26, 2013 | Miele Novotronic Premier 500 Front Load...
Dishwasher is not working. The red 'Inlet/Outlet' light is flashing. Any advice please Thank you
There are a few things you can check. First set the washer cycle to Stop and turn off the unit. Next make sure that the stopcock on the inlet valve is fully open. Then close the stopcock/valve and disconnect the inlet hose. Remove the seal and then the filter (use pliers). Clean this inlet filter with running water. Replace the filter and seal and reconnect the hose to your inlet valve. Reopen the valve (check for leaks from threading problems). Make sure the valve is fully open when you try to restart the dishwasher. Check your incoming water pressure at this valve as well - low water pressure will also trigger the inlet error. Make sure the hose is not kinked.
If the washer did any parts of the wash cycle, then try cleaning the outlet side of the system.
Next clean the combination filter, drain pump and non-return valve. For the filter (near the lower spray arm), turn the handle counter-clockwise. Lift the filter out and remove all debris. Rinse under running water and use a nylon bristle brush to get stubborn stuff out. Pull back the yellow clip and open the filter flap. Clean the underside of the filter with running water again.
Remove the water from the cabinet with any container that works. Raise the locking clamp for the non-return valve. Lift up the valve and clean it under running water. Carefully check the drain pump (now visible with the non-return valve out) and remove any debris. Sharp objects may be present. Move the impellers and completely check the pump for foreign objects and remove them. Replace the non-return valve and secure it with the locking clamp. Replace the combination filter so that it lays flat and secure it with the handle. Make sure that the drain hose is not kinked.
If neither of these solve the problem, you need to call for service. The Waterproof safety system has been triggered and water got into the electrical system of the unit.
Many Miele appliance manuals are here: http://www.miele.co.uk/customer/OperatingInstructions.aspx . The manual for the Miele G641 is here: http://www.miele.co.uk/Resources/OperatingInstructions/G%20641%20and%20G%20841%20Plus.pdf . See this manual for pictures of the filters and drain pump area.
I hope this helps.
Sep 14, 2011 | Miele 24 in. Novotronic G641 Plus Built-In...
Meile Novotronic W 828 Washing machine half way through the cycle it stopped and the screen shows a message saying "check the inlet"
It means what it says! i.e. water is not getting into the machine, the inlet hose or path is blocked or the inlet valve has failed. You need to turn off power and water and check it is getting water through inlet hose and that the inlet filter is clear, the filter can be seen on the valve when you remove the hose. You will need to open the machine to check the inlet valve and tubing. Hope that helps please vote
Feb 04, 2011 | Miele Washing Machines
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Miele W1926 check inlet light flashes at the end of rinse fill. When the fill ends, the light goes off. I cleaned all 4 filters at the intake hoses. The problem still exists. What does it mean?
Hi dear.It sounds like you'll need to change water inlet valve very soon.Because,machine waiting water level to be reach,in specific time frame in chosen program parameters to be get completed.If that does not happen,then it starts giving fault indication.Indication stops after fill,because task been competed & computer disregards the fault.If that won't happen then machine going to get stop completely & indication will carry on.Chage the water inlet valve if you can.I hope that helps. Thanks.
Jul 25, 2010 | Miele W1903A Front Load Washer
The check inlet light flashes. I have cleaned the
Feb 05, 2010 | Miele W526 Front Load Washer
Miele washing machine
All Miele washing machines and dishwashers need to fill in a required time. Flashing inlet (Tap icon) indicates that the machine can not fill in time. There are filters in the end of the hoses which connect to your water supply from the machine and filters in the inlet valves which you can get at by removing the hose from where it fixes onto the machine it'self. You will need some long nose pliers to grab the little tab on the small filter to get it out. Clean all filters and hoses. Still same problem then check the pressure of the water coming into the machine. There should be a good pressure coming out of the hose and will be difficult to stop the flow of water with your finger.
Dec 20, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
19 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
