Question about Sharp Microwave Ovens
No power May have overheated
    Top Expert:
  • Sharp Master
  • 12,223 Answers
Follow this steps and fix it. God bless you
No Lights or Power, Unit seems Dead First check is the main fuse of the unit. On countertop units, you will need to take the shell off. The fuse will be close to where the cord comes through into the unit. OTR units, this main fuse is usually behind the control panel or possibly behind the vent. Usually the fuse is obvious if blown, otherwise test with an OHM meter, if open, replace fuse.
Some brands will also have a thermal cut-off fuse in the incoming voltage line to the control board. Older Maytags and Samsungs have this fuse in it. This thermostat looking fuse is usually above the oven cavity somewhere under the outside shell. Sometimes you can get to it through the vent of OTR models. Test with an OHM meter, replace if open.
Posted on Jan 23, 2013
How do I set up the power level on a Hamilton Beach microwave model number is p100n30als3b
I believe all you need to do is first press the 'Power Level' button, then select a number on the keypad between 1 and 100 (where 100 is full power, 50 is half power, etc), then Press 'Time Cook' and enter the number of minutes and seconds as usual. I'd suggest testing on a cup of water so you don't risk overheating anything. And never run a microwave completely empty.
Good luck.
Mar 21, 2015 | Hamilton Beach Microwave Ovens
A don't heat oven
Magnatron ( power unit in Microwave ) DEAD , cheaper to buy another Microwave .
Mar 15, 2015 | Microwave Ovens
We had a small fire in our GE profile pvm2070 microwave. Now we have no power, anyone have any suggestions?
see the diagrams., and see what is burns, unplugged the equipment
Possible the fan motor can be stopped, for some times ago, and this produce overtheating in the wires or winding from transformer, this produce fire inside.Of course there are spike or glitching in line and this produce overheating and deterioring the insulated material. The fuse and c.breaker ARE not device for fire only for to protect the device for short and NOT overheating or fire.
God bless you
Jul 14, 2012 | GE Microwave Ovens
Microwave lost power in the middle of heating a lunch. Later power came on with PF in the display. Is this normal?
it seems the thetmal cutoff(TCO) mounted on the magnetron to protect it from overheating is going off.it opens out when magnetron overheats and cuts the power to the control board and after the magnetron cools down tco resets and power to control board is restored with the sign PF(power failure).the fan that cools the magnetron may have gone bad.i think u will need a tech 2 chk it out.
Aug 17, 2009 | Hotpoint RVM1625 Microwave Oven
Whirlpool Microwave, No Power
could be a damaged door saftey
Jun 14, 2009 | Whirlpool Microwave Ovens
Terminal connector to the door switch overheated & fuse blown
Just cleaning is not enought.The terminal is loose and that isusually the problem most of the time.Replace them with new ones and I think you be happy.
Mar 12, 2009 | Panasonic NN-P794SF Microwave Oven
Magic chef over the oven microwave shuts off.
Is not normal for a microwave to shutdown after 4 minutes of operation.
From the info you are providing, It looks like the magnetron might be overheating causing the thermal fuse to shut it down until it cools down. There may also be a loose connection in one of the switches or a cold solder joint in the low voltage power supply.
I would suggest to check and make sure that the fans are functional, If always did; it could be that there isn't much air circulation where the appliance was installed.
Mar 03, 2008 | Microwave Ovens
Sudden power loss
Is the internal cooling fan running? (I don't mean the hood vent exhaust fan)
It sounds like your magnetron is overheating, tripping the magnetron thermostat, which protects your magnetron from overheating to the point of destruction.
It may be because the internal cooling fan is bad or the magnetron is just failing.
(Do you hear the cooling fan running behind the control panel when you microwave?)
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
Jan 06, 2008 | GE JVM1870 Microwave Oven
Maytag microwave overheated.
There is a fuse that should be easy to get to behind the control panel.  Will need to take the grill off first to get control panel off.  Make sure unit is unplugged first.  There are high voltage parts in a microwave so you should have a professional do the work if you are not comfortable with it.  Would appreciate a solved rating for expert advice.
Oct 17, 2007 | Maytag MMV4205 Microwave Oven
Microwave Ovens Logo
66 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
