Question about HP LaserJet M4345 MultiFunction Printer
Grinding noise new fuser and fuser drive gear, loud grinding noise as motors start
  • HP Master
  • 1,121 Answers
"Swing plate assembly" (RM1-0043-020CN) need to replace to avoid grinding noise. ..Note: Only professionals can perform this activity..
Posted on Jan 26, 2013
5 Suggested Answers
  • 300 Answers
SOURCE: Grinding Noise
Common problem on the HP 4200/4300's it's caused by the swing arm (the gear assembly that drives the fuser) HP have modified this. If you contact them direct they may replace it free of charge
Posted on Oct 07, 2008
  • 193 Answers
SOURCE: HP P3005 making grinding noises
this is a problem that HP refuses to acknowledges. Its caused by the gear that meshes with the main fuser gear..it wanders to the right as the printer prints. we are checking into a fix for this, since we are getting no cooperation for the manufacturer, Canon or HP. Canon makes the print engine
Posted on Apr 13, 2009
seeker5211
  • 1089 Answers
SOURCE: HP LJ3005n printer is making loud grinding noises
Common problem. The fix is to change the fuser AND the fuser idler gear - RU5-0957-000CN. It is a 20 tooth gear. As the teeth wear the noise gets progressively worse.
Posted on Jan 24, 2010
Testimonial: "That was good advice "
  • 261 Answers
SOURCE: Loud Thumbing noise coming from near fuser assy.
Hi need service
Posted on Oct 21, 2010
HP Color Laserjet 8550 - Loud grinding noise near fuser
Hi Harden,
Thats an issue with the fuser assembly,try to check the teflon condition/ teeth gear might have worn out.
Jan 30, 2014 | HP Color LaserJet 8550dn Printer
95 Buick lesabre making loud grinding noise when starting. Once started runs and drives fine no noises
Yes, you are probably right about the spacer or shim. A salvage yard should have lots of them for little or nothing. When you remove the starter for the spacer, check the drive gear end of the starter for severe wear. If it is chewed off very bad, have a new drive gear put on, or replace the starter.
Nov 05, 2012 | Buick LeSabre Cars & Trucks
I have a CL4000DN making a grinding noise when first turned on any ideas?
it is possible that the drive gear in the fuser has failed. this will cause a very loud grinding sound in the back of the unit where the paper comes out. you can order new gears for it but sometimes its easier to replace the Fuser.in saying all this where is the noise coming from?
Feb 09, 2011 | Ricoh CL4000DN Laser Printer
When i close the back door it is making a loud noise. sharp al 1631
If it sounds like gears grinding it may be the fuser unit. The bushings and gears need replaced or new fuser unit.
Aug 31, 2010 | Sharp AL 1631 Copier
No error messages, but there is a loud banging noise during printing that just started. Cannot locate the source.......
Could it be more like a clicking or grinding noise? That would be the swing plate assembly gears. Those gears connect the drive system to the fuser, driving the fuser gears. There is no workaround, it is a replace only. I would suggest contacting a service provider. The swing plate assembly has either a quick 15 minute fix or a tiresome and complicated up to 2 hour fix, especially if the screws get stripped out.
What happens is the fuser gears and the swing plate assembly gears bounce slightly, creating wear on the fuser drive gear and the swing plate gears. Over time they wear down enough that they start making noise and will eventually start causing jams in the fuser. If you notice a bunch of white dust that has an oily texture when you rub with your figures on the drive side of the fuser, that is the gear dust.
Apr 09, 2010 | HP LaserJet 4250n Printer
HP Color Laserjet 2840 now makes ear-splitting whine every time
Did the noise start right after you replaced a toner? If so it must be a bad toner which is causing the gears to grind. If this noise happened out of the blue then it might be a bad fuser drive gear which is the gears that connect the fuser to the machine.
Jun 25, 2009 | HP LaserJet 2840 All-In-One Printer
Apr 01, 2009 | HP Hewlett Packard LaserJet P3005 Printer
Grinding Noise
Oct 07, 2008 | HP LaserJet 4250dtn Printer
Gear making a grinding noise
Not too good news I'm afraid. It sound like the fuser gear has failed. Generally the fuser unit (hot section or hot rollers in the back) need to be replaced. Usually when the gear has worn or failed the fuser rollers are also worn and need to be replaced. The gear can be replaced seperately but is a very risky operation and usually results in parts in the fuser unit falling appart due to age and wear, so it is best done as a unit. If possible do not run the machine as it can cause damage to gears around the fuser unit. The best option is to find out how much a fuser unit and labour to fit would be at your local service centre.
Jan 29, 2008 | Brother IntelliFAX 4100 Laser Fax
HP LaserJet M4345 MultiFunction Printer Logo
534 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
