Question about Philips DVD Players DVP3620/F7 DVP3620 - DVD Player
I get no sound or color - Philips DVD Players DVP3620/F7 DVP3620 - DVD Player
We moved our tv upstairs, we have a nice picture and sound but no color!
check for a loose connectors and fixed it to the pin terminal .
Oct 27, 2012 | Televison & Video
Philips 32PFL3505D 32 in LCD TV How can the TV be set to factory setting?
Hello
There is no details about the factory reset of your tV in its user manual. But intvidual reset for picture, sound etc can be selected and can be reset to factory reset.
Summary of picture settings
The following picture settings can be confi gured. Depending on the
format of the picture source, some picture settings are not available.
• [Auto Picture]: Sets all picture settings to the factory default.
• [Brightness]: Adjusts the intensity and details of dark areas.
• [Contrast]: Adjusts the intensity of bright areas, keeping dark areas
unchanged.
• [Color]: Adjusts color saturation.
• [Tint]: Adjusts the color balance in an image.
• [Sharpness]: Adjusts the level of sharpness in image details.
• [Color Temperature]: To set the color temperature to [Normal],
[Warm] or [Cool].
Summary of sound settings
The following sound settings can be confi gured. Depending on the
sound source, some sound settings are not available.
• [Auto Sound]: Sets all sound settings to the factory default.
• [Equalizer]: Adjusts individual sound frequencies.
• [Virtual Surround Sound]: This selects the modes for more spatial
or surround sound reproduction.
• [Auto Volume Leveling]: Reduces sudden changes in volume, for
example, during commercials or when switching channels. Select
[On] or [Off].
• [TV Speakers]: Select [On] or [Off], or output sound to an
EasyLink compliant device. When [Speakers EasyLink] is selected,
the TV speakers are disabled and TV sound outputs to the speakers
of the compatible EasyLink compliant device. Adjust the volume
using the unit's remote control.
OK.
Mar 08, 2011 | Philips 32PFL3505D 32 in LCD TV
I have a samsung model #HL-R4266W tv, It is making a humming sound, and has no color other than it being in black and white the picture looks fine, what could be the problem?
This tv design have a colors wheel in it,have humming sound or loud motor noises.The colors flashes Black&White or lost all colors.The colors wheel is dying and the causes.The colors wheel replacement are not a do it ur self project.Hire a tv Tech. to do it right the first time.Colors wheel sit way back close to the Light Projection Engine itself.
Dec 30, 2010 | Samsung HL-R4266W 42" HDTV-Ready...
Noisy sounds like a fan and the picture starts to flickers multiple colors and picture is scambled.
This tv have a colors wheel.The colors wheel is dead.The colors wheel is dying,going to be dead.The tv make loud humming,noisy sounds like a loud fans or motors noises.Also the tv colors flashes black&white or multiple colors pictures and scrambled.Colors wheel replacement is difficult,never done tv repair before.Hire a tv Tech. to replaced the tv colors wheel.
Nov 16, 2010 | Samsung HLN5065W 50" Rear Projection...
Started making a humming or vibrating sound, and the color and resolution went bad at the same time. Now when I attempt to turn it on, I get the same vibration sound and nothing else.
This tv have a colors wheel,it dead.Require changing.Humming or vibrating sound,Flashes pictures black&white.The colors wheel is dead and it not spinning in it axis motor correctly anymore.Hire a tv Tech. to change the colors wheel,it very hard to change the colors wheel.Because u have to take out many machanical parts,even before u can get to the colors wheel itself.
Oct 14, 2010 | Samsung HL-R5656W 56" DLP HDTV
My Samsun tv is having problems. It is 57 inch and
Sounds like it's the color wheel. The color wheel is responsible for colorization on your DLP. If that color wheel fails, you'll get funny and funky colors on the TV. You'll also hear a winding sound or a whirring sound. Not all cases you'll hear sounds from the thing, but those are the tell-tale signs that the color wheel is out, or going out.
Feb 03, 2010 | Samsung HLR5667W 56" Rear Projection HDTV
Loud high pitch humming noise over powering sound from TV
Yes you can repair this your self it is the color wheel also keep in mind that if set does not play after replacing color wheel and lamp lights,color wheel working with all 3 fans running and set shuts off within 30secs of turn on BAD LIGHT ENGINE!!!!!!!! also they are NO LONGER Available cost of that part was 1,000.00
May 30, 2009 | Samsung HLN5065W 50" Rear Projection...
Loud buzzing noise
sounds like the color wheel needs to be replaced very easy repair on that model Samsung.
Jul 05, 2008 | Samsung HLR5067WX 50" Rear Projection HDTV
Pretty colors
Sounds like the other DVD player went bonkers. Try unplugging power on the DVD player you were playing the game on for 5 minutes, then plug it back in.
Apr 02, 2008 | Sony DAV-FC8 System
Philips DVD Players DVP3620/F7 DVP3620 - DVD Player Logo
29 people viewed this question
Top Philips Televison & Video Experts
matt martin
matt martin
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
