Question about Panasonic Lands Phones
Screen is blank on panasonic kx-tga244w - Panasonic Lands Phones
3 Suggested Answers
SOURCE: Screen gone blank
I had the same fault with the handset losing it's display, phone worked great but could not see to access internal phone directory.
To strip down the phone you need a very clean hard plastic/granite
work surface and a small philips screwdriver and a small flatblade screwdriver.
First of all remove the battery cover and the batteries, put them in safe spot on the work surface (Tip: take the top cover off an aerosol tin to use for holding the screws and small parts you remove)
Remove the front facia by gently teasing it away from the body of the phone, there are 2 plastic lugs either side of the battery compartment, ease them towad the edge of the casing to release the front facia, it should then unclip easily with your thumbnail.
Near the edge of the phone you will see 2 small screws, remove them carefully and set them aside, please note these are longer than two other screws you will encounter later in the disassembly.
Seperate the two main parts of the case from the battery compartment end of the phone and work towards the other end, there are two release points on the outside of the casing, gently insert a small driver into the recess whilst applying a small amount of lifting pressure between the two casing halves and it should spring open. (Note that the case hinges on a clip at the top edge of the phone which helps with its re-assembly later.)
Please be aware that the speaker wires are soldered to the main board and should not be disconnecetd or cut!!!
At the battery end of the phone is a small strip of white plastic tape covering two short screws, these hold the cradle charging contacts to the circuit board, remove them with the metal contacts and keep them safe.
With a little coaxing the rest of the phone should now come out of the casing. Be very carefl not to touch any of the gold contacts on the circuit board or the buttons may not work, you may gently clean these using a dry microfibre cloth. DO NOT SCRUB THEM, simply rub gently a few times.
Unclip the display holder andnote the earpice comes loose, this can be fed through the plastic holder byturning it sideways and pressing it through. DO Not damage wiring!
You should now see the tiny ribbon cable on the display itself, either side of it are a thin white plastic lug which can be slid carefully away from the edge of the display to release the cable. Remove cable gently and re-insert it back into the connector it came from, ensuring it is fully home and is perfectly aligned at right angles to the display, then carefully slide the retaining lugs back into place which will lock the cable back into place.
You can now re-assemble the phone, carefully.
It worked for me, hopefully it should for you unless the display is damaged prior to or during disassembly.
Posted on Mar 09, 2009
  • 17 Answers
SOURCE: Panasonic cordless telephone KX-TGA101CS troubleshhot
you can contact the service provider..
Posted on Dec 15, 2011
No display panasonic cordless phone
The display on that particular phone may have to be replaced.
Dec 28, 2013 | Lands Phones
Led display does not work on my panasonic 5.8Ghz phone KX-TG5632
I just spoke to Panasonic Tech Support about the LED screen being blank. FYI its blank on both my handsets - one which I never even use. He made me do a few button presses, etc but nothing worked. So he tells me I have a "loose connection on the LED" so I must have dropped the phone or something. I said NO, I never dropped the phone, and one of the handsets I never even used - and its happening on that one too. So bottom line you have to take it to a Panasonic repair center at your own expense if its over the one year warranty - for what I personally think is a flaw on their phone design. I think after so much time the LED screen just goes away...since its happening on both handsets, and neither of them were dropped. Its a shame because the phone works fine, but I need the LED screen for the mute button, etc. So my solution for you is to stay away from Panasonic phones and the lame customer support, and go buy a different brand.
Apr 02, 2011 | Panasonic KX-TG5632 Phone
Display screen has gone blank
You would need to change the screen. Go to a phone repair shop to assist you in changing the screen. It will cost you a little.
Best regards
Jun 06, 2010 | Panasonic GigaRange KX-TG5432 Cordless...
The display screen is blank, phone still works. How to fix?
I am having the same problem with my KX-TGA234W. One day the screen just went blank, so I changed the battery, but it still is blank. I hope that someone can help both of us.
Apr 18, 2010 | Panasonic KX-TG5632 Phone
Panasonic kx-fl511 has blank vertical lines on fax when printing.
It's important to gently move the toner cartridge from side to side to distribute the toner evenly through the cartridge. This could be causing your blank lines. Also, clean the Corona wire when installing a new toner cartridge. Best of luck.
Greg
Jun 10, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Panasonic KX-FL511 fax machine always prints blank page
make sure that "autoreduction" is set to on. should be in your owners manual. also, make sure your paper size is set correctly.
razors
Apr 13, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Kx-tg5634m
i cant get my phone to work. it says no link to base move closer to base,try again.
Sep 18, 2008 | Panasonic KX-TG5632 Phone
Faxes are incomplete or non-existent for Panasonic KX-FPC166
check the cover if it has been closed properly, if not check the cover lock and hinges.
Jul 16, 2008 | Panasonic KX-FPC95 Plain Paper Thermal...
Lands Phones Logo
107 people viewed this question
Top Panasonic Lands Phones Experts
john milligan
george  peters
george peters
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
