Wiring diagram for a kinetic 8100 home theater system
Benimur
  • 6966 Answers
SOURCE: ciruit or block diagram of pioneer home theater system
The (schematic) circuit diagram is included in the service manual. A downloadable pdf copy is available here.
Hope this be of help. Pls post back how things turned up or should you need additional information.
Good luck and kind regards.
Posted on Jan 13, 2008
pgh_pa_guy
  • 2992 Answers
SOURCE: Philips Home Theater Speaker Wire (can it be cut?)
Sure you can, Joel.
Put the speakers wherever they will go, and cut the wire from the speaker to whatever length you need to reach your wall terminals. Leave some slack so you can move the speakers if needed. Strip off whatever length of insulation you need to make the terminal connection. Note that the speaker wire will have some kind of polarity marking. There will be a colored stripe or other mark on the insulation, or the conductors themselves may be different colors (usually one wire is copper, and the other tinned so it's silver colored). It doesn't matter which you use for positive as long as you're consistent and use the same one for each speaker.
At the other end where the prewiring comes out for your home-theater system, splice the connector ends you cut off onto the installed wires, following the same polarity. I recommend using an appropriate size insulated **** splice to make the connection. The crimper and splices can be found at auto parts stores, Radio Shack or most hardware stores. It's quick, reliable and makes sure there are no bare wires to short out.
Plug the speakers into the system and you should be good to go. Whip up some popcorn and enjoy the show!
Posted on Jan 28, 2009
ginko
  • 19396 Answers
SOURCE: sony home theater system started blinking protect
Protect mode will kicking whenever a fault is detected.
Causes that can start protect mode are:
Electrostatic harges on internal circuits.
Leave the unit unplugged for power for one hour or so, this will allow discharge.
Bad speaker wiring.
Check speaker wiring, try unplugging and plugging back, or start after removing one speaker at the time.
Internal fault.
Internal fault is the natural cause for protect mode. If all the above did not work, then the problem is a blown component or an internal fault. In this case the unit must be taken apart , tested and repaired by an experienced person.
If the unit is less than one year old, or if you want to get service, call Sony at the phone number listed on the product documentation.
Regards.
Posted on May 04, 2009
  • 15 Answers
SOURCE: How to extend speaker cables of Philips MX6050D DVD Home Theater
Go down to your local RadioShack or any place that sells wire of any sorts (heck, even Walmart might carry it now) and ask them for speaker wire. I'm not sure what the impedance of this particular model is, but you should be able to find it printed on the back of the speakers, or in your user's manual. This guide will help you to identify what size speaker wires you need, that way when you go in looking for speaker wire, you'll at least sound like you know what you're doing.
Posted on Jun 02, 2009
Wire diagram pioneer http-100 sub woofer
If you wish to get some details; check the site linked here. Pull up older posts.
May 27, 2016 | Pioneer Center Channel Speaker Htp100-cr...
Kinetic Loud Speaker KA-4260
Kinetic speakers are generally 8 ohm, so they should work fine with the Onkyo.Your amp has a rating of 80 watts per channel, but I'm not sure of the power handling of the speakers.
Feb 08, 2014 | Audio Players & Recorders
Sony Amplifier, Sony CD Player, Sony AM/FM Tuner, Sony FM Stereo/FM-AM Receiver, Stereo Cassette Deck........I need to know how to connect all of these components so I can use the stereo system...........a...
The actual task of hooking up a home theater may take a little time, especially if you are doing a custom installation with lots of separate components, but following 3 links have the basic principle of input and output...pls visit all and than you can easiliy connect all properly..
Take care and if it succeeds please Remember to rate/vote and give me 4 Thumbs Up
for Helping out the Community :)
Hope this helps!
The Basics of Home Theater:
Sample Wiring Diagrams
http://www.prillaman.net/ht_info_8-wiring.html
Home A/V Wiring Diagram
http://www.unicom.com/blog/entry/521
How Do I Hook Up My Home Theater?http://hometheater.about.com/od/hometheaterbasicsfaq/f/htbasicfaq7.htm
Jun 22, 2011 | Sony Audio Players & Recorders
Kinetic ka-5100 manual?
I have KA- 5100 5.1 ch home theater wht amplifier ineed to conet
Sep 02, 2010 | Audio Players & Recorders
I need a wiring diagram for my home theatre system
Please provide the full details of which wiring diagram you need? for what you need?
is that for tv or a dvd player or a home theater system?
So please provide the details to get solution.
Mar 29, 2009 | Audio Players & Recorders
Wiring diagram
hi i have a bose home system. it has a 5 pin L shaped rca plug that goes into the bose receiver. that wires got rip out of. i wanted a diagram of the plug to know which wires went where so i could repair it..
Jun 16, 2008 | Audio Players & Recorders
95 people viewed this question
 Grubhead
Grubhead
