Question about Hobart HL600 Legacy Stand Mixer
Hobart A200 MIXER ON/OFF SWITCH
The ON/OFF button need changing,the one i have on/off functions come integrated in one button.
ON is in the inner circle cavity by putting a finger and OFF function is by pressing with a palm to stop the mixer.
is this momentary switch or latch.
what's thr best option for me.
many thanks for your help
    Scholar:
  • 109 Answers
To be precise, you should post your ML (material list) number from the date plate. That would allow techs to see exactly the build of your machine. It sounds like you have a momentary start button that would be Normally Open, and a Stop button that is momentary and Normally Closed. together, they would operate a control relay for an A200 or contactor for larger models.
try www.hobartservice.com and select smart parts,
or call you local Hobart office with the model, and ML number.
Posted on Oct 05, 2009
  • 20 Answers
I would call hobart and have all the information about your machine you can find on the data plate they have more that one style of switch
Posted on Aug 08, 2009
  • ragtime27 Jul 17, 2011
    I had the same problem over a year ago.
    like for like switch from hobart would cost you a fortune,they're not doing them anymore,you have to change the switch and the metal panel,to do that it would cost you over 100pound.
    what I did,I went to maplin they do have a normal switch would fit right inside the inner circle.
    here's a link for the same switch I have used,it is a square one,you will end up with a small gap on four corners,what i did I took paper tape rolled it enough for the switch to become a circle and big enough to fit nicely and tight.
    it works perfect,everyone who sees it would think it's the original one,all that would cost you £2.39.http://www.maplin.co.uk/locking-push-swi...
How do I bypass Hobart A200 safety switch
we dont advise on how to disable safety devices ---and you dont want to disable a safety on a mixer that can rip a limb off and not even bog down
Aug 13, 2016 | Hobart A200 Stand Mixer
Hobart mixer
hi Gassman, below you will be able to find a link on parts assembly for the mixer, you will have an idea on how to tear off the parts, get them cleaned and place them back, like a regular maintenance.
Hobart A200 Mixer Parts Assembly
More parts assembly for Hobart A200 Mixer
hope this helps.
Aug 19, 2008 | Hobart A200 Stand Mixer
How to invert motor turning direction?
Beatriz, I looked through the entire manual, it shows no reverse option. Did you just get the mixer or did you have it repaired. It seams the mixer is either wired wrong or the gears that rotate the mixer were not assembled correctly.
Check the attached link,manual,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
https://my.hobartcorp.com/kroger/TechnicalServiceManuals/A200%20Technical%20Manual.pdf
A200 Hobart Service
Apr 06, 2016 | Hobart A200 Stand Mixer
Stationary Start Switch part needed
Go to your local Motor repair shop. They usually have used ones laying around or can sell you a new one.They wont try to sell you the new improved solid state controlled version!
Dec 14, 2009 | Hobart A200 Stand Mixer
Hobart mixer A200 Rotation
Assuming the unit is 120v, single phase, my money is on a bad electronic start switch (not to be confused with the on/off switch) It's not visible without some disassembly. Usually, it is located at the rear of the motor cavity. Take note of all the info on your model data plate then go here to obtain a parts breakdown on your particular mixer. http://www.hobartservice.com/Parts/
I'd suggest replacing the capacitor as well.
Sep 28, 2009 | Hobart A200 Stand Mixer
Hobart m-802 mixer won't start up
call Hobart for the correct oil any way and an elcetrican will just add more problems for yoy
May 30, 2009 | Hobart A200 Stand Mixer
On and off switch for hobart stand up mixer a200
I'm a hobart tech---what is the ml number on the data plate?
Feb 23, 2009 | Hobart A200 Stand Mixer
Hobart A200 Mixer not working
Sundance,
Please visit the corp website www.hobartcorp.com and click on the "Sign In" link in the upper right hand corner. You'll need to complete a brief registration form, but then you'll land in the Hobart Resource Center.
Hobart no longer manufactures the A200 mixer - but you can review and download a user manual and a parts catalog from the Resource Center on your mixer. That should help you understand the parts need.
We do sell replacement parts direct to end users, just visit our service website at www.hobartservice.com - and click on the "Locate on Office" link. You'll be able to contact your local Service branch to purchase a replacement part OR to have them take a look at the unit and provide a quote on fixing it.
If you have additional questions on Hobart products - please contact me at sherri.wilmoth@hobartcorp.com .
Thanks!
SHerri
Oct 11, 2008 | Hobart A200 Stand Mixer
Hobart mixer
Please be more specific of what part you need.Whats the problem with the mixer?Im a hobart tech and service these mixers often.
Feb 18, 2008 | Hobart A200 Stand Mixer
NEED A WIRING DIAGRAM FOR A A200 HOBART MIXER
I had a look on google and came up with a service manual. not sure if this has the wiring diagram but the only other thing i can suggest is to contact te manufacturer direct. Go to http://cgi.ebay.com/HOBART-A200-20-QUART-MIXER-SERVICE-PARTS-MANUAL_W0QQitemZ160203114233QQcmdZViewItem
hope this helps.
Feb 02, 2008 | Hobart A200 Stand Mixer
Hobart HL600 Legacy Stand Mixer Logo
287 people viewed this question
Top Hobart Food Mixers Experts
Ross Keen
John Tripp
John Tripp
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hobart Food Mixer Expert? Answer questions, earn points and help others
