Question about Lexmark X7675 AllInOne InkJet Printer
Lexmark X7675 printer cover hinge is broken can't close properly how can i fix it..
5 Suggested Answers
SOURCE: X7675 Aio Wl USB Adf 32/27PPM Ocr Dir Prt Pbridg Dplx All-In-One Printer: My lexmark x7675 can not download scan application...
No solution here - just confirmation. Mine say that it (the scanner) cannot save files to my hard drive, that it is full. That's far from true, but to a dumb accessory a locked target folder/directory will look like a full disk. Does anyone know where Lexmark parks it's temporary files? I've looked in all the usual places on my Mac, and can't find anything yet. (I have previously found a Brother parks it's initial scans, before you save them, deep in a normally inaccessible corner of the System folder.)
Posted on May 24, 2010
sayedmohu
  • 633 Answers
SOURCE: The left hand plastic hinge on my lexmark x6575 is
I am including the details of teh Lexmark Parts Center.
Customer Support Representatives are available Monday - Friday from 9:00 am - 6:30 pm EST
E-mail: lpcorder@lexmark.com
Phone: 1-877-577-2787
Fax: 1-800-258-4880
Posted on Dec 05, 2010
Printtech
  • 1087 Answers
SOURCE: Lexmark X342n front cover, hinge
Please click on the link provided below. http://bitly.com/l7yPlU
Posted on Jul 11, 2011
  • 12 Answers
SOURCE: hinge is broken on my lexmark X6500 so cover
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to pus it back into place with no luck.
Here's what happened and how to fix it:
There are two plastic hinges at the back of the 6500 series printers that allow the top cover to open for access to the ink cartridge carriage. The lower ends of the hinges are cylindrical shaped and each contains a very stiff steel spring inside. They are designed to prop the cover of the printer up and hold it open when opened. As the plastic material ages, it may weaken and the tension of the internal spring may break the round end of the hinge off. This causes the printer cover to not fully close (even though it may appear so). There is a switch in the main printer body that detects when the top cover it open (even partially), and the printer won't work in this condition.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover or the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
I am not sure if new replacement hinges are readily available from Lexmark or other sources.
Posted on Oct 20, 2011
Lexmark pinnacle pro adf cover hinge won't close
Go to this link on You Tube and watch the revised video. It will correct the problem for you.
Jun 03, 2012 | Lexmark Pinnacle Pro901 All-in-one Inkjet...
Lexmark x6570 hinge is messed up so im getting cover open message
I have a Lexmark X6570 All In One Wi-Fi model. Just had the problem where I went to print and received an error message saying that the cover was open (when it wasn't). I noticed that the back right hand corner had slightly popped out of place for no apparent reason. Tried to push it back into place with no luck.
To fix this, open the top cover and carefully disconnect the 3 wire harnesses and the ribbon cable that run from the top cover to the base of the printer. Then remove the 'paper jam' hatch cover from the back of the printer. There are two phillips screws on the back panel of the pinter (one is located behind the paper jam hatch cover). Remove these screws (they secure the plastic hinges in place). You should now be able to lift the complete top cover/ scanner table assembly off the rest of the printer. Look for a steel spring about 3 inches long...remove this along with the round base of the hinge which may have broken off and remained down inside the printer. Glue this piece back onto the end of the hinge, but leave the spring out. Now reassemble the printer in the reverse order of disassembly and you should be good to go. Note that the top cover of the printer will not stay propped open on it's own with the spring removed, but this is not really an issue.
Oct 05, 2011 | Lexmark X6570 InkJet Printer
The scanner lid won't close properly. I see the right back corner of the lid has popped out of it's socket. how can I fix this?
Aug 26, 2011 | Lexmark X3470 All-In-One InkJet Printer
Hinge is broken on my lexmark X6500 so cover won't close
Jul 23, 2011 | Lexmark X6570 InkJet Printer
Lexmark 7600 printer cover is not seating properly after installing printer cartridge
The two hinges are attached to the back of the printer by two screws. I removed the two screws and lifted the top off, freeing the two hinges (the one on the right was broken so part of it stayed in the printer). There is a restraining line on the right side that keeps the top from coming completely free of the printer, but it can be worked around while still attached. I removed the broken pieces and the internal spring from the right side hing. The spring is what was keeping the top from seating correctly. I assume you could order a new hing, but I reassembled the printer without the spring and the top seated properly. The printer works, but I will now need to be very careful when replacing the ink cartridges because of the missing hing on the right side.
May 10, 2011 | Lexmark International Lexmark 7600 Series
Broken hinge where do i find areplacement lexmark x7675
You can download the Manual to dis-assemble the Printer and purchase Parts for your Printer fro the below link:
https://parts.lexmark.com/wpo-catalog/US_en/search/data_type:model/machine_type_model_id:782
Please let me know if I was Helpful...
Mar 05, 2011 | Office Equipment & Supplies
Mess. saying cover open i cant seem to close the top down. the top cover seem to be off track or broken
Feb 05, 2011 | Lexmark X6570 InkJet Printer
Have lexmark x7675 installed factory new cartridges still reporting out of ink
Hello. The cartridges may not be seated properly or just needs cleaning. Remove the cartridges from the printer. Make sure the protective nozzle tape is already removed. Wipe the nozzles of the cartridges using a damp paper towel. Unplug printer from power source, plug it back in after 10-15 seconds. When the printer's ready, reload one cartridge first. Close the cover, check if "out of ink" message is displayed. If not, proceed on loading the other cartridge. This is to check which cartridge is causing the problem. Try this steps maybe 2 or 3 times until the printer recognizes the cartridges. If problem persists, I strongly advise you to contact Lexmark at 1-800-LEXMARK(1-800-539-6275). You probably got defective cartridges.
Apr 21, 2010 | Lexmark X7675 Wireless All-in-One Printer
Printer cover
Jul 28, 2008 | Lexmark X1270 All-In-One InkJet Printer
Cover open Error message
I'd say maybe the switchs is broken and your machine reminds me of a lexmark fault. Look for the cover switch, under lid on base, at rear, small hole, find the switch that get's activated when openning and closing the top, maybe it is missing, or broken.
link to lexmark fault, that I think you will find your answer.
Feb 06, 2008 | Canon MultiPASS MP360 All-In-One InkJet...
Lexmark X7675 AllInOne InkJet Printer Logo
26 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
