Question about Amana Microwave Ovens
Rc17s Display reads HOT, and will not respond
I have a whirlpool over the range microwave the display won't work
The display may have an internal fuse. If everything else works fine then the display itself is faulty.
Aug 09, 2015 | Microwave Ovens
Replaced 20A fuse - now have blinking lights
either the cutoff is open circuit or closed circuit if you get any reading at all it is good. I would look at the control panel look for overheating components. Tap any relays to release them if they arced inside. Whenever a microwave blows a fuse it is time to replace the huge capacitor at the back and possibly the magnetron. I resurrected my Sharp R9H66 Microwave Convection Oven easily. Had to replace the magnetron twice in the last 5 years
Nov 08, 2013 | Sharp R-9H84B Microwave Oven
GE Microwave (Over the Range: Model HVM1540DPBB) was stopping operation. It would beep, and the display would show garbage. I would unplug it, then plug it into the outlet, then it would display "keypad...
make this test and fix it. God bless you
  1. Inspect the power cordUnplug the power cord and check for voltage at the outlet. Also inspect for damage, shorts, or burn marks that can be a possible safety hazard.
  2. Bad door switchIf your microwave does not work at all and you know everything is plugged in properly and the outlet is functioning, then also check the door hooks and the door release button. Using a volt-ohm meter on RX1, check your terminals. When your microwave door is closed you should have a reading of zero. Once the door is open the reading should change to infinity. If these readings do not match up, replacement of the door switch is necessary.
  3. Blown fusesTo determine if your fuse has blown out, which may attribute to your microwave not running, you need to pull the fuse out using a pair of fuse pullers. Lay it down and using a volt-ohm meter on RX1, check both ends of the fuse in question. If you do not get a reading of zero, then you will need to replace the fuse.
  4. Bad fan motorLocate the fan and remove the leads. Again using the volt-ohm meter on RX1, check the terminals. If an infinity reading is displayed, it means that the fan has gone bad and requires replacement.
Nov 02, 2013 | GE Microwave Ovens
My microwave keypad wont work the light is on and the reading says please touch clock and set time of dry
SEE THIS CAUSES AND FIX IT. God bless you
Touchpad and Control Panel If the microwave buttons don't work the touchpad and control panel assembly are probably defective.
Touchpad If the microwave buttons don't work the touchpad might be at fault. Generally speaking, if the display is working and some of the buttons respond correctly but some don't, the problem is with the touchpad.
ser Control and Display Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Main Control Board If the microwave buttons don't work the main control board is most likely defective and will need to be replaced.
Oct 01, 2012 | Kenmore 80809 Microwave Oven
I have a Frigidaire Electric smooth top range and oven. when I set turn on the burners they do not light up or get hot. When I try to bake I press the Bake button and set the temperture but the oven never...
HI.CONTROLS MIGHT HAVE BEEN LOOSE.oR LOOSE CONNECTION BETWEEN the control.Check the control connection inside .It might respond but connection has been loose.hope this helps..
Jun 21, 2011 | Frigidaire Microwave Ovens
My faema e91 turns on but only reads p0.0 on the display. It won't steam and the espresso part works but isn't hot when it comes out.
theres a tempature probe on the upper right side of the boiler that tends to go bad, its a brass screw in sensor with two wire sticking out leading back to the board, replace this. also verify correct water pressure, if its not the sensoe then check your elment for continuity. e
Nov 15, 2010 | Microwave Ovens
Display panel has lost most of its dots. can't read it
debe ser revisada por un tecnico por que parese ser la targeta de control da?ado por incectos o por cucarachas
Oct 05, 2010 | Sharp R-1750 Microwave Oven
Ge microwave works intermittent, when not working display reads F-3 and key pad does not respond
This code will occur if a shorted key panel is detected continuously over 60 seconds. Replace key panel (also called touch pad).
Sep 22, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
My microwave panel is not working.
Sometimes if the door switches are faulty then the touch panel may not respond. There are usually 3 switches, and I'd recommend if one if faulty replacing all of them as a set. Otherwise it may be a Control Panel fault.
Mar 18, 2009 | LG LMVM2055 Convection/Microwave Oven
Goldstar MV154SJ Over the range Microwave oven
check the touch pad , and check the control panel...
Sep 23, 2007 | Goldstar MV-1501 Microwave Oven
Microwave Ovens Logo
22 people viewed this question
Top Amana Microwave Ovens Experts
William Miller
William Miller
Shehu Pro
Shehu Pro
Are you an Amana Microwave Oven Expert? Answer questions, earn points and help others
