Note the instructions about some not having an upper button and some users using a shoe lace around the neck for the upper end of strap... boy that is a "kludge"... but I guess that is what they do.
The fuel pump is located in your fuel tank...you have to drop your fuel tank to replace it...before you do so you will have to sifion [sp] most of the gas out as gas is heavy...when you get out all you can leave the gas cap off and remove the bolts holding the filler neck in place...Then jack up vehicle and place on jack stands....Remove battery ground cable,go under and remove sheild covering fuel tank,while there remove the ground strap attached to the filler neck...Once the cover is off this will expose the 2 tank holding straps.....at this point you will need a jack or holding and lowering devise to support the gas tank..... make sure it is supported well before you loosen the strap bolts!!!! disconnect the EVap hose from canister it runs to tank then remove the strap bolts ...move them aside and lower the tank enough to expose the top where the fuel lines are disconnect them and the electrical connector,ground ...then lower gas tank slowly checking nothing is still hooked to it ...After the tank is down remove it from under vehicle and use a BRASS punch or piece of wood not a regular metal punch to remove the pump retaining ring ...once ring is removed CAREFULLY remove the pump from the tank.....replace pump and new strainer... Then Carefully put the pump back in the tank...if needed replace the ring seal before you place the pump back in...tighten up the retaining ring ....take back to car and put on supporting devise and lift just high enough to reattach all your connectors...then jack up the rest off the way attach holdings straps ,cover,ground ******** filler neck,filler neck bolts,battery cable install gas cap and start hopfully
Hi, if you go into any phone shop and buy one of their straps they come with a cord that you loop through the hole and back on itself and this cant then come undone by mistake, its like a nylon thread that you feed through the hole and then put the end through the whole and pull tight you then just clip the strap onto the clip on the loop part, this is very secure and strong as its made to hold the weight of a mobile phone worn around the neck, how ever if you dont want the long strap you can just use the small loop part to attatch it to a key ring or similar.
I know you may be a bit confused but if you go into a phone shop and take the usb drive with you you will see exactly what i mean, these straps also cost near nothing so you cant really lose.
go into any small phone shop or market stall that sells phone accessories and you will see the neck straps im going on about you have the long neck strap part and this attatches to a small nylon loop that you can feed through the tiny hole on the flash drive
the center of the belt will be under the seat coming up through the holes, place the two clips on the strap followed by the chest clip, then the neck protector pads. Push the ends of the strap through the two top holes. Route it down over the metal but under the plastic (on the back side) and attach both ends to the metal adjuster underneath. The receiver clip, you just turn 90 degrees and push through desired hole until the end catches.
My dear! first install software only without attaching USB when your USB required the software or driver then attach it or if your software does not required USB attach during installation, you have to attach it after the installing software. May it require reboot your system. Now your USB sandisk u3 cruzer micro device will work.
thank you
