Question about Weather King Heating & Cooling
What are the blower motor specs for a weatherking 9000 furnace
Need specs of the blower motor
the dr
  • 447 Answers
SOURCE: Furnace Blower Motor Specs
That information is usually on the data plate on the furnace and on the motor itself. All you need to know now is the HP. Other than that a universal consolidator motor is an easy fix too. It can handle 1/6-1/3HP.
Posted on Dec 18, 2007
  • 85 Answers
SOURCE: Where can I find weatherking acclaim II filters
Your best option is to contact your nearest wheather king/Rheem dealer. They may have replacements. The filter store online, they offer any size and cheap too!
Posted on Dec 02, 2008
  • 306 Answers
SOURCE: Have weatherking furnace, Pilot lites
I am thinking the fan is bad if you can disconnect the fan motor leads and ohm them out. White is common Red is low speed Black is high speed. You might have other colors like blue which would be med speed and maybe orange witch would be med low. There is a small run capacitor on the fan so replace both fan and capacitor at same time. After you ohm out the motor of course. You should have resistance on all leads. Use white as the main one and check each speed. Replacing the motor isn't too tuff little hard getting it out of squirrel cage
Posted on Dec 20, 2008
  • 659 Answers
SOURCE: weatherking furnace flashing 5 times.......
Sounds like it it isn't the igniter but probably the pressure switch. You can only tell by the clicking noises as they system goes through it's safty checks prior to the call to the igniter.
Posted on Mar 17, 2009
farfield
  • 462 Answers
SOURCE: Need original blower motor and cap. specs for Ruud Deluxe 90+
The motor specs can change from time to time depending on what the manufacturer has in mind.
If it has locked up check first and make sure the squirrel cage fan has not moved and is binding on the housing.
If it is clear to turn and wont turn,, the bearings must be bad, and this is probably NOT a problem with the motor being "wrong". Its just the way things are made.
Contact a RUUD distributor for the specs you request.
Posted on Jul 10, 2009
Ever limit switch i changed in my Weatherking furnace, it breaks the switch, what could cause this?
You need the model number of the furnace to determine what the flashing light is telling you. Many times the part that looks to be at fault is not the true fault in the furnace. A slow running blower could cause the limit switch to trip. The circuit board tells you that the limit tripped, but the real cause is the motor or clogged filter.
Jan 02, 2016 | FACTORY AC PARTS Limit Switch Double Pole...
I am getting one light flash indicator limited circuit issues. The furnace fires and heats up but blower does not come on
Remove the blower motor, With the furnace circure breaker off!!!!!!!!!!
Put a universal 115 v plug on the two wires and hold it on the floor and plug ER in. It's a 115 motor, look at specs to make sure. If she don't , check wholesale house to get a motor. If not that, motor capacitor, then contact switch if capacitor don't do it. Be very safe!!!!!!! . The capacitor will need to be discharged and if checking it, do NOT
Touch both post. Discharge it before disconnecting it by turning all power to furnace off, taking a screw driver and putting it across both terminals. It will arc. Do that a couple three times to get rid of stored electricity. If it does arc with a little snap and spark, it's good.
BE SAFE. Hope that helps.
Jan 21, 2015 | Frigidaire PTAC Electric Heat 9000 BTUs...
04 goodman furnace model GMS8 ciculator blower wont stay on gas fires and runs but high limit trip because of no air from blower any ideas bad motor or control module
You need to check the motor amp draw against the spec tag on the motor. If the motor has power to the motor wires it's either the motor or the run capacitor.
Nov 17, 2014 | Heating & Cooling
I have a Heil furnace (Temp star 9000 I believe) model number NUGS075BG03 that is not working properly. The inducer motor runs fine and I can see a blue flame through the sight glass but the circulating...
you need to check to see if blower motor runs in ac mode, if not then the first thing you want to check is the capaciter for that motor. if capaciter is good, motor may be locked up, you can check the amps of the motor by putting an amp clamp around wires going to blower motor, all ratings should be listed on motor
Oct 17, 2013 | Carrier Icp Heil Tempstar Furnace Blower...
I have a weatherking gas furnace that will not blow
Sounds like a bad blower relay. Check the voltage from the board or relay going to the blower for 110 volts. Replace the relay or board if no voltage.
Feb 07, 2010 | Heating & Cooling
I have an old Magic chef furnace and need to replace the Fan Motor were can I find the fan spec for replacement? It was built in 1987 Model # G8A75DC10-17 Serial# A 10221CKA Forced Air Furnace Categorie I
magic chef furnaces were discontinued many years ago. Pull the motor and take it to your local motor shop. They will be able to match it. Furnace blower motors are pretty standard fractional horse motors.
Oct 06, 2009 | Heating & Cooling
WeatherKing Acclaim II
  1. The sensor that tells the furnace whether the gas is lit has got build-up on it and is giving the furnace bad information.
  2. The flame sensor is often a single wire or rod that sticks up in the center of the flame.
  3. You can shut off the furnace and the gas and clean the sensor with some sandpaper.
If that still doesn't work, the sensor may need to be replaced.
Please rate this solution.
Jan 16, 2009 | Heating & Cooling
Furnace Blower stops working after 15 minutes
Replace the blower motor. Cleaning of the blower and motor will help in the moving of more air but will NOT eliminate the real problem in the motor bearings. Over time the lubrication will dry out and bearing wear results.
Nov 12, 2008 | Heating & Cooling
Dec 17, 2007 | Heating & Cooling
Heating & Cooling Logo
16 people viewed this question
Top Weather King Heating & Cooling Experts
Donni Steen
Tim Whalen
John Tripp
John Tripp
Are you a Weather King Heating and Cooling Expert? Answer questions, earn points and help others
